Got my new wheels today.  Went from a 285/60 R20 with stock RST wheels to a 305/55 R20 with 20x10 D672 Anthracite Fuel Wheels. As you can guess, now I have to lift it. My 2” level didn’t do the job. Oh shucks…..
I will post picks after I lift it next Friday.
If anyone is interested in the previous wheels and tires (Toyo Open Country R/T) let me know. Only 15000 miles, just didnt do it for me anymore.
Took some more pictures this morning. I am absolutely loving it.
Also, I just installed a Pulsar LT so that I can tweak some things in the computer.  Let me say this, it’s expensive, but Holy Moly, this truck came alive. I also turned off the auto stop and DFM.
  • Like 4
2 hours ago, Steve-2019 said:
Truck is lookin' good and you'll love that Pulsar LT with all the settings it has for sure!  👍
Thanks, you gotta love that throttle control on the fly. WOW!!!!
Wassup fellas, this is my first post. I’ll start by saying I love all the trucks on this thread.
I’ve had my 2021 RST for almost a year now added the 2” trailboss factory lift, and a 1.5 level. Also I upgraded my rims and tires. I had factory 18s but switched to the wrangler Duratrac (33s) on 20inch rims. Check it out..
Edited by Th3Rea1st
Just purchased my Custom Trail Boss last month. Got the 6.2L with the 10 speed and I absolutely love it. Looking to add fog lamps and front window tint, but won’t be modifying too much.
Nice! I was looking at a truck just like that one last week, but it did not have the nicer 20” wheels like yours. The dealer would not come off MSRP either. Were you able to get a good deal on it?
In this market I’m not surprised. I basically got mine just below msrp and minus the incentives. Not great, but I knew it was exactly what I was looking for so I went for it. I’m very happy with it so far.
Just picked my truck up this afternoon. I had a 4” Rough Country Ready Lift installed. I still have a very minute amount of rub so I’m probably going to remove the mud flap bracket and push the liner back a tad bit. I only need a 1/4 inch to not have any rubbing at full turn. My wheels are 20x10” -18 offset with 305/55 R20 for anyone wondering. Have a good weekend everyone.
2020 Silverado 1500 High Country 4wd 3.0 Diesel
- BDS 6" lift kit
- Bilstein 5100's
- Fuel Blitz 22" x 10" -18 offset
- Nitto Ridge Grapplers 35's 295/55R22
  • Like 3
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
