I picked this up last Saturday.  2021 GMC Sierra 1500 Elevation 4x4, X31 package, 3.0l Duramax, Cayenne Red tintcoat.
Not new to the forums just new to this section 🤪
Just picked up my 2021 Denali 3.0 Duramax yesterday, traded in my 2015 LT Z71 CC. Love this new truck.
it’s crazy the trade in value on trucks right now, it was too good of a deal to pass up!
Hi guys - new to the forum.  Here is my 2021 AT4 with the Go Rhino RB20's installed.  I put them on "backwards" but I may reverse them back to regular orientation.  I can't decide.  My uncle is a GMC/Chevy dealer and I was fortunate enough to get one of the last available trucks with the full technology package.
This one replaced a 2018 Sierra that had KO2's and a leveling kit.  More mods to come.
D0BC90B1-012C-4CC8-8266-2CA1C66C3374.heic
Edited by drivebydawg
Really happy I went with the bronze wheels with a blue truck
Traded in my 2018 GMC Sierra SLT (w/ Denali grille) for a 2021 GMC Sierra Denali.  Dealer gave me more than what I paid for the '18 a year and a half ago so it was hard to turn down.  Loving the new 10 speed.
Scheduled the window tint this week.  Kept my Ridge Grapplers from the 18 and will swap at some pint. Probably end up doing a level kit along the way as well.
530282360_2021-06-2809_37_23-Photo-GooglePhotos.thumb.png.ab72e07fa0d894ca3c9e76c0ff4ab16c.png160359305_2021-06-2809_36_38-Photo-GooglePhotos.thumb.png.a1daee3828f7b08da53b37b392e92507.png616436306_2021-06-2809_36_23-Photo-GooglePhotos.thumb.png.c54fe3cf512fa4b1581591ae18613649.png
Out with the old and in with the new. Great truck but they offered me $5k more than I paid for it after 30k miles. I wanted some of the extra safety features on the ltz. Very happy with my decision even though it’s probably a wash.
I thought I'd throw this out there since I looked alot prior to matching my satin steel metallic fender flares and found nothing.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
