This is the rarely seen and not yet uploaded in this forum Oxford Brown color in a 2021 High Country..  I was not a fan of "stick around Brown" before I saw this in person, i felt the color that Chevy uses on the website has a much more generic non-metallic brown color. In real life it's a chameleon color, it goes from Black, to Charcoal, to Brown, to kind of a Mossy Green. It Pops Charcoal. The High County Bronze grill and the Black/Umber Interior make this truck stand out.
That's the color I almost bought, but didn't want to drive 2 hours to the Outer Banks from Norfolk, VA. It happened to be a Trail Boss LT with the 6.2, too.
30 minutes ago, Fubar12 said:
Took it on a trail
OMG, get it washed ASAP!!  🤣
Nice looking truck!  👍
What lift did you go with? and tire size? I have the basically the same truck only the RST Rally with the 6.2 and I put the TB lift and went with 285/50/22 Nitto ridge Grapplers
If your talking to me
It's factory lift
However the wheels I got for 50 percent off for the set for gm oem black wheels from q dealer. Tires are open toyo open country all terrain 22's
Went with 22s I like the look better than 20s and plan on upgrading the brakes for the front brembos
Brought it to a car show and had to take a pic. My recent upgrades: ceramic tint, 3.5” Rough Country lift, Rough Country HD2 steps, spray-bedliner, and Retrax Tonneau Cover
  • Like 4
On 12/17/2020 at 3:43 PM, cc1999 said:
Got my new 2021 GMC 1500 AT4 diesel about 2 weeks ago. So far tinted the window, got my wheels and tires in last night to now have to battle that brake caliper clearance issue tonight. Should be ready for action again later tonight. If all goes well, with it's new rims and tires.
Fuel Anza 17x8.5 +6 with Falken P285/70/17s tires.
What running boards are those? Thanks
3 hours ago, DannyMoe13 said:
2019 RST with the Eibach Pro Lift Kit with Fuel 17's wrapped in 315/70/17 BFGs
Very cool.. any rubbing , using wheel spacers ?
I've removed the brackets behind the carpet and trimmed the mud flaps.  It rubs at full lock on the carpet.  I also opted not to go for the 3rd highest setting on the front coilovers.  No spacers.  I might go a little higher in the front this spring to try to alleviate some of the rubbing but it's not terrible
Those are the OEM boards that come on AT4s, I think they were possibly part of one of the option packages on the truck.
You probably could get them from a GMC dealer .
I would imagine they are offered as an accessory item from GMC parts.
yeah, these are the new low-profile off-road steps that come on some of the AT4 packages. I've seen them on the TB now as well. I really like them. More of a Raptor-style board vs. the one that came on the AT4s before that was bigger and hung lower.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,317 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
