I picked up a new '21 Silverado RST a couple months ago.  It has the 2.7 turbo. Mileage thru 2k miles so far is ok (18 mpg avg; best hwy so far - 25 mpg).
For me, the 2.7 has all the power I need. The low-end torque is great, and I've never had a problem passing anyone on the highway. The 8-speed has behaved fine and seems decently matched to the 2.7, at least in my personal experience so far.  Time will tell if this powertrain holds up, but I am very happy thus far.
Pics attached.  I replaced the oem antenna and added nerf bars & a tyger cover. So far, I love the truck!!
  • Like 3
On 4/6/2021 at 4:05 PM, PureZ71 said:
New baby announcement, trail boss version
Congrats!!!
Here's my new 21 Custom Trail Boss.  Options I ordered: 6.2L, Safety Confidence Package, Rear Seat with Storage Package and Multiflex Tailgate.
  • Like 5
Just picked up a 2019 Silverado 1500 RST Z71 (low miles), first two easy mods are going be to installing a dimming rearview mirror and getting my front windows tinted to match the factory tint on the others. Also looking for a good Tonneau cover.
  • Like 3
Played in the dirt today on an off road course
I'm jealous
5 hours ago, Transient said:
I'm jealous
Thank you, it was a lot of fun. There was 60% raptors there. One thing is that with a crew cab and standard bed, the truck did feel a little tight going around some corners.
More photos:
More photos:
Where did you do this at?
    • This is interesting. My quote tagged here is different from my original quote. After I’m driving them longer. That isn’t me. I don’t talk that way. I definitely wouldn’t express myself that way. Interesting.
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
