On 8/15/2021 at 12:20 AM, Luster said:
2021 GMC Sierra AT4 6.2L Satin Steel Metallic, build date 7/7/2021. Purchased 7/24/2021.
Added a Lund Tonneau Cover, Front window tint, Xpel paint protection, and a Borla 40359 muffler.
How are you liking the borla and exhaust
The T1 is mine, and the 2008 belongs to a coworker on my shift.  Its my first GM product in 25 years and I am very happy with it.
16 hours ago, johnsills1 said:
Out on the job, turned around and it looked so good, so I snapped a pic.
Nice.  Been looking for a different front bumper.  The only pics you ever see they are on a lifted truck.  I really wondered what they look like on a stock height Trail Boss.  What bumper do you have?
After searching for a year I found my truck.  Wow.  Love this thing.  Just upgraded to 35's.
Well, my truck is an RST, not a trail boss although I do have a 2” level and 1” lift in the back.
The bumper is a Fab Fours. I have a rough country rear and iArmor side steps to complete the look.
On 4/18/2021 at 6:49 AM, RyanbabZ71 said:
What brand are your running boards? Wanting to get black wheel to wheel that don’t hang down to the ground
On 8/15/2021 at 10:33 PM, JimCost2014 said:
That is a great looking truck!
Thanks to GM, you have made your own "one of one" that they should build.
Long live standard cabs!!!
I will leave the "snow jokes" out, since you did say these were old pics.
LOL to the snow jokes...I'll post up some new pics hopefully soon!  Just installed the SLT grill last weekend, so some new ones are due.
And thanks so much - really appreciate the feedback :)
  • Thanks 1
21' Elevation Crew Cab, freshly shined up.
I was hesitant about the 2.7t at first, my local dealer couldn't get any other engine in, 500 miles and it's been a good runner so far.
Just picked up my new 21 1500 Denali 6.2L. Traded in a Jeep Gladiator. So far I am really liking the room, comfort and power.
Edited by Misbehaven
2021 Custom CC Northsky Blue Metallic, has a gorgeous purple hue in the sun
2” level
33x11.50 falken wild peak at3s
17x9 0mm offset kmc wheels
15% ceramic xpel tint all around with 5% brow
debadged all the chrome nameplates
rear wheel well liner
matte black chevy tailgate inserts
drop in bed liner from chevy
tyger auto roll up bed cover
husky all weather mats with rear bench storage
6k led bulbs hi/lo
led bulbs reverse and plate lights
stubby antenna
the hazey smoke is from the Dixie fire
Edited by northskyt1
2” level
6k led bulbs hi/lo
stubby antenna
Looks good
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
