22 hours ago, Frankielozano214 said:
So here’s my new to me 2023 Sierra SLT in the works right now getting fixed (frame swapped basically everything swapped 😂) but it’s a clean title only has 2063 mile on it, gotta 7” fts lift already on the donor frame ready to go!!! Will swap the lift later so if can fit my 38s on it 👎🏽 still have my 2014 Silverado debating on selling it right now.
This was just purchased from the auction so it will be ready to roll here in a few months or so. With the Denali frontend not SLT frontend cjt_217282558863725.jpeg.f69e482ebb39ae3b653dc88639dec5e2.jpeg
Resized_20230810_165049_217563482440545.thumb.jpeg.4528cea8119d502e675732464cccd106.jpeg
Resized_Resized_20230810_165109_217583489923141.thumb.jpeg.8b148b38026fefb502e951252dd27350.jpeg
Can't wait to see this one Frankie.
This is the lift I want 12” FTS lift kit with the chrome crossmember but it’s like 9k for it so I’m thinking I might sell the my other one to get the lift 😂 no point in having two lifted trucks is there?? (might keep the 26x16 and go 40s on this new one)4920603D-2E7A-448F-9B62-0785D54D3ED2.thumb.jpeg.bcf8dd5f8dedc37c2d729c72a7379244.jpeg
40s all way Buddy. Fawtys rule.
Picked up a new AT4 this afternoon.  2023 with 6.2.  Premium package, Technology package, Sunroof, All weather mats.  Dealer took $8,100 off and gave me a decent offer on  my '14 Chevy.
Edited by White LTZ
Rotate picture
Sorry for the sideways pic.  I've tried 50 times to fix it.  I give up.
Save as a jpeg file then rotate it and save it. I did it this time. Copy this to your device and reload it under your account. I will delete it from mine in a day or two and it will disappear from this post. 😉
Swapped out my 35" on stock rims for my tempory setup for my up coming road trip.   Lt275/60/20 General Grabber ATX  on Fuel Sledge 20x9 rims.   Hope to get better mpg with this setup.
Thanks!!
Just bought this over the weekend. First truck and first Chevy. Super excited.
New 2023 LT 2.7 4WD. Was surprised to see this on the dealer lot. I thought all LTs came with chrome bumpers, but this one had blacked out bumpers and 18 inch blacked out wheels, which I've never seen before. The Chevy website doesn't even let me build it like this, so I'm not sure how the dealer had this stocked. Whatever the case, was super excited to find it and pick it up!
Edited by Baker17
  • Like 3
My new 2023 LTZ and the loaner 2023 Trail Boss I was given to use while the LTZ was getting the bedliner.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,252 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
