9 hours ago, Donnyb313 said:
I sprayed mine a bit in the car wash today, didn't seem to leak. Build date of 01/21/19 plant G Silao Mexico :sigh:  I'm going to keep an eye on it first time it rains..
You may very well be fine with that late of a build. GM knew there was an issue for some time before that.
That said, I have a US built 10/14/18 truck and I haven’t had any leaks. I’ve been watching it like a hawk, but I’ve taken it through at least 20 high pressure washes and no problem. I’m sure it’s still a somewhat isolated issue but concerning for sure.
How do you figure out the build date from the last 6 digits of the VIN number? Or is it listed someplace on the truck or window sticker?
I asked the dealer for a build sheet, it lists all RPO codes and other info. I couldn't find it on the truck anywhere
The trail boss I am buying has a couple dates listed late August 2018. Vin 107xxx. I looked at the back seat on the final test drive the other day and didn't notice any signs of water. It has been sitting on the lot for 6 months I am sure if it was going to leak it would have by now.
There's a sticker on the drivers door jamb, at least on my 2018 there is.  Mine shows a build date of 11/18 top left of sticker and a bunch of other numbers and info
Mine was built in 9/18 and i have also been watching for leaks. So far, it stays dry. 9/18 is early in the build so i agree with OntheReel, it appears isolated.
Sent from my SM-G892A using Tapatalk
Build Date Aug 2019. Dozen handwashes, Dozen power washes, couple of heavy rails, no leaking. Light rain most of the day today and a little leaking on the passenger side. Vehicle built
at Fort Wayne.
at Fort Wayne.
Mine was a 9/18 build.  Just like yours, mine only seemed to leak after a long light rain.
They replaced the window on mine
Edited by O Town Denali
Since I am going to start this journey, I thought of keeping some notes of contacts, users etc
Contacts
    Chevy Customer Care
        Email [email protected] or https://www.chevrolet.com/contact/email-us
        Chat https://www.chevrolet.com/contact/chat
        Twitter @chevycustcare
        Phone 1 800 222 1020
    Executive VP and President of the Americas
        Barry Engle [Replaced Alan Batey] Email:[email protected]
    Global Manufacturing GM
         Gerald Johnson
Correction Procedure [GM Bulletin 18-NA-383]
        This Bulletin applies to Vehicles built before Oct 1 2018. We did have a user report Headliner Damage
                               with a Build Date of 1/27/2019.
        Contact the Dealership
       If the Headliner was damaged due to water, the front windshield must be removed for headliner re-installation
                 Allows the Headliner to be inserted thru the windshield for installation
       If the window must be removed, the rear seats will be removed for the process.
        Inspect seating and carpet for dampness and mold and have them replaced. Seats might be a stretch.
        Inspect the paint around the window to insure it is not damaged or chipped
        Inspect Trim in the back around the window to ensure no damage
        Take pics of the outside and inside for future reference and compare to the "after the work"
        So the Dealership will attempt the following  3 procedures.
            Contact Chevy Customer Care and lodge a complaint to get it on the record. Use Chat to keep a record of the convo.
            If need be, send email to a higher up GM Exec which in turn will cause the GM Executive Service Rep to make contact some how.
                   Fish_Guru reached out to the VP at GM and did get a response back. I did the same when I needed a front bumper. So they do
                   followup on complaints. But ensure you follow contacting the Dealership, Chevy Customer Care, state your problem and be
                   COURTESY.
                       1 Pull down Headliner to allow removal of Spoiler. place new sealant on the top edge of the window and check leaks after everything is back together or
                       2 Inspect Window for Sealant crack and clean the old sealant off the window and body and reapply sealant and install window or
                       3 Inspect Window for upper rail cracking and obtain a new window and  reapply sealant and install window
        Try to have all the parts needed on hand and a plan of attack to minimize how many times [once hopefully] they have to perform surgery on the vehicle
Know your Auto Lemon Laws for your State [Example Michigan]
        The law applies to privately owned passenger vehicles and those leased after January 1, 2000, used for personal, family or household purposes.
        Some business-type vehicles may also be covered. The law does not apply to larger trucks, motor homes, motorcycles, or off-road vehicles.
        A defective vehicle is one in which the same problem has not been repaired after four attempts, or a vehicle that is out of service 30 days or more for repairs.
        The first report of the defect must be made within one year from the date of delivery to the original purchaser or lessee or during the term of the
        manufacturer's warranty, whichever period is shorter.
        If the vehicle you purchase is defective, you may be entitled under state law to replacement of it or a refund of the cost of the lease.
        To obtain replacement or refund, you must first report the defect in writing to the manufacturer and you may be required to first arbitrate the dispute.
        In order to protect your rights under Michigan's Lemon Law, follow these steps:
        Keep copies of all correspondence to and from the manufacturer and the dealer.
         Keep copies of all work orders for repairs on the vehicle, including the date(s) the work was performed and the mileage on the vehicle at the time of the repair(s).
         Follow all requirements of the warranty, including any requirement that the repairs must be done by an authorized dealer specified by the manufacturer.
Members with Leaking problems
    Kyleb                       Denali       2/19
    Fish_guru               HC            12/18        Window resealed, Spoiler sealant applied, Window replaced
    SLC                        TB
    Demon                  TB              11/18        Window resealed, Window replaced
    JKD                       Denali        11/18        Window resealed, Window replaced
    TommyboyATL    Denali        12/18
    MTSound              TB              12/18        Window replaced
    HotRdLy                                   12/18        Inspecting a vehicle at a Dealership
    RPH                      HC               12/18       Window replaced
    O Town Denali    Denali          1/19
    Dzen                     AT4              2/19
    The Silverado                           3/19
    Anthony2558       TB                3/19        Glass Shattered, Window replaced
    Smoked                TB                3/19         Window sealed but not fixed, Going for round 2
    Steve841
    rocz3cqg              HC              3/19         Window Caulked
    White94rx             LT               3/19         Window Caulked
    ShamrockShooter TB            3/19         Headliner Damaged [Being inspected by GM Rep 4/3] Window Caulked
    Luke Litten
    Corey Helgemo                       4/19         Headliner Damaged
    Miguel Antonio Quioc David 3/19         Build Date 1/27/2019 Headliner Damaged
    Connor Lee           TB               4/19
    Jeremy Balok        RST            4/19
    George Litourneau
    Scott Daniel
    Richard Fuentes   Denali
    M3Master                                  4/19       Sealed but still leaked, Window replaced
    Eppieguy                HC               4/19
    Ktapper                  TB                4/19       Replaced the Window
    RedhotRST             RST             3/19
    Bowtie2007           Sierra          4/19
    Chris Arruda
    Daniel Glauser
    KevinTM                 LT                4/19
    JosephWS2019    LT Z71        5/19
18-NA-383.docx
Edited by Rocz3cqg
Contacts
    Chevy Customer Care
        Remove rear window, reseal and reinstall
        Remove spoiler and apply sealant
        Replace rear window due to cracking frame
        If headliner damaged, front windshield must be removed.
        Inspect carpet and seats for damaged
    Kyleb                       Denali        2/19
    SLC                        TB
    Dzen                     AT4            2/19
    The Silverado                         3/19
    Smoked                TB              3/19
    Steve841
    rocz3cqg              HC              3/30        Dealership not contacted as of yet
Actions.
     Make notes, take pics of interior and exterior.
     Contact Dealership and find out the determination
     Based on decision [should be replace the glass], Contact Chevy Customer Care and/or GM VP Barry Engle
     Try to minimize how many times they have to take truck apart. Hopefully get all the parts needed together so the surgery can
            be done in a timely manner.
      Find out the procedure, ie what does it take to replace window? Do they need to take the headliner out? Windshield out due to headliner?
So not a single LT or RST with a leak on this forum?
I've been smelling mildew in mine. Haven't found any water until now. It rained last night. Water sitting on the rear window, and a puddle of water down below the rear seat back. They better replace all the carpet and padding that got wet. It's not going to go well for them if I continue to smell mildew.
Sad thing is I knew from the beginning it had a leak. The night I bought the truck, it had condensation on the inside of the windshield. Salesman just said it probably got wet when they were cleaning it. And I didn't trust my gut.eaec9cd39819afec8ae24483f2b66c47.jpg
Sent from my Pixel XL using Tapatalk
Well got my truck back Thursday afternoon. Got same old we got everything fixed and you are good. They said they checked the carpet and seat and said that nothing was wet and no issues, but i am doubtful on that. They said not to wash the truck for 24hrs or more and I decided I would give it 48 hrs just to make sure the sealant had time to dry. Saturday about noon we had a very light sprinkle and I decided that would be a good test and went out and water was all over the seat and down in the floor board. After some further inspection it looks like clear caulk was used. Not sure if the sealant GM wanted to be used is clear, but the one that was used looks clear to me from what I can see. Now I get to take my truck back again Monday and this time I am going to request the rear window to be removed and all the sealant removed and new sealant and window installed. I really can't believe that we are having this issue, pretty sad a the quality control has dropped at chevrolet like most manufacturers and then the dealers can't or won't deal with the issue.
I'll be their worst nightmare customer if they don't get it fixed the first time. That, or they'll be buying my truck back.
I've mentioned this before but make sure you inspect your truck when you get it back BEFORE you drive off.
If they remove that rear window the back seats have to come out. My truck had a gouged interior kick panel, 2 loose screws rolling around and some minor paint chips around the back glass.
Thankfully my dealer made it right after I raised hell.
    Afennell19
    Afennell19
  • Who's Online   1 Member, 0 Anonymous, 907 Guests (See full list)
