Went to 2 different wheel places yesterday and struck out on all test fits.  Most places are just assuming that the wheels that worked on the previous body style will work which is definitely not the case.  If you've put aftermarket wheels on and know the specs please post the specs and a picture.  I'm surprised there isn't a thread like this yet.
Wheel Make
Wheel Model
Diameter / Width / Offset / Back Space
Fuel Maverick 18x9.
I don't have the exact specs right now though. No wheel spacers either.
I can get the specs for you after the holidays.7547bb9ee5d425fd819dc703115119f2.jpg
Sent from my SM-N960W using Tapatalk
Wheel Make
Wheel Model
Well this is a problem due to the new big brake calipers on our 2019’s. I tried to fit the Fuel Vapors (D560) and they are a no go. I had a very lengthy conversation with A fuel representative and he explained that GM did not even provide them measurements, they had to get a test truck which they did not get until October to start figuring out they had to re do a ton of their wheels to work with the 2019. When will that happen? They don’t know exactly when these “2019 friendly” wheels will be available for sale but assured me they are in the works.
I had a wheel distributor make me a list. These wheels will fit, of course more will BUT these are just what he had in stock that he could get me within 1 day.....
for Fuel:
       -The Mavericks are a for sure fit
      - Hostage III (D568)
      -Assault (D576)
     -Coupler (D556)
     -Full Blown (D554)
For XD:
      -Rockstar 2 (The Panels you can change out different colors)
Helo:
     -HE900
Wheel Make
Wheel Model
Moto Metal MO969
20x9 0 mm offset
Found some wheels that fit. I have a list of wheels that will work that I’ll share later.
XD 839
20X9 / +18
Does anybody know the stock offset on our wheels?
On 12/23/2018 at 6:09 PM, KA0S said:
Fuel Maverick 18x9.
Are those 33s or 35s
They're 33's. I plan on keeping the same wheels and throwing on 35's once someone comes out with a lift for the AT4.
I run dedicated winter tires and rims on all my vehicles. Picked up a set of these wheels: https://www.oemwheelsdirect.com/product/one-chevrolet-silverado-tahoe-suburban-oem-factory-style-22-inch-sgf-wheel-5696/
And mounted these winter tires: https://www.1010tires.com/Tires/Toyo/Observe+G3-Ice+Studdable/275-50R22
I didn't have any issues with fitment. The tires do kick off a lot of slush that clings to the wheel wells and causes some rubbing after a while. But I chalk that up to the aggressiveness of the tread and not a fitment issue. Below is a picture of the truck with the wheels and tires installed. I hate seeing it that dirty... I had ceramic coating applied just under 2 weeks ago so I have to wait a couple more days before the detailers can wash it.
51548037_1997846216977999_18051980718862
 They look good. How are the Toyo's performing? It looks like someone was playing Tic Tac Toe on your rear door. I cringe when I see someone touch a dirty car.
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
