On 3/2/2020 at 10:48 AM, Jason Milam said:
It can be pretty tricky if you haven't done it before. It took me a few tries and researching where the grill retainers are to get it right. This video has an image in it that shows exactly where the retainers are located. This was the most helpful for me with figuring out how to remove the grill.
Used this as guidance for the install, appears to be the best one on Youtube.  Basically follows the manufacturers instructions but a lot more info in the video most importantly forget the ones where it says to just yank without first releasing the two tabs on each of the four "wings" above and below the headlights.....try that in cold weather and you'll likely break the wing clips or crack one of the wings.
And the only way top do it right is to remove the grille.....the quick and dirty method of just releasing the top clips and tilting inward forces you to run the cabeling over ther shutter assembly and leaving the tail connected to the LED bowtie traveling vertically upward to the top of the shutter assembly where it will flap around at 60-80 mph and and maybe booger the wiring or pins in the connector. Removal of the grill permits attaching the cabling inside the crossbar to the grill itself shielding it from the air traveling through the grille and positioning it at the convenient rubber gasket behind the upper headlight assembly instead of of a hole in the body behind the shutter assembly.
Took almost 2 hours, instead of twenty minutes for the quick and dirty method, worth the time to  mask off paint (necessary on the RST crossbars) and lens assemblies to prevent scratching. Result came out perfect.....finally got rid of that last pioce of chrome......finish on the lighted bowtie blends in with the factor smoked headlights,DRL and light smoke plexi placed over the fogs.
So i did the install today, and I absolutely can't get the dang grille back on. I can get all the clips except either the left or right bottom clip. If i get all 3 bottom clips in, i can't get the wing clips in. It has left me frustrated to the point that I'm gonna take it to the dealer and let them put it back on for me. I scratched the hell out of the bumper trying to wrestle it back on. looks neat tho
17 minutes ago, Lionel Olguin said:
I had my brother help me out or else the same would of happened to me.
Im alone so im sure a helper would have made it a little easier. Im an OTR truck driver so I gotta wait another week to get it to the dealer. Im afraid im gonna break it if i try it again
I installed mine by only pulling one side of the grill off. It's tricky but can be done. You only need enough room to get your hand in behind the grill
Sent from my Pixel 3 XL using Tapatalk
To replace grill, first make sure retainers in wings are properly seated in the grill and not damaged. First you tilt the bottom of grille and locate three bottom clips at the holes/slots, then lift the top of the grille with the four bolt holes up and over the lip of the steel bulkhead and push top and bottom in together....the spring clips on the two ends should be in proper position and push to seat......the wings must clip in last  after the side clips are seated with a push on the inner clips first and then the outer. If you do not pre-seat the clips partially in the bottom holes first then tilt the top vertical and lift the top over the lip the end clips double each side,  will not be in the seating position and replacement will be difficult or not possible..
Yeah man, i screwed around with it for 2 hours trying to seat the bottom 3 first, the clips on the wings are either moving or i have accidentally damaged them
Dealer fixed it for me today, I had broken one of the wing clips so it wasn't lining up. All done now, I have learned my lesson on doing mods myself on something this new haha. Did install my running boards yesterday trouble free tho
On 3/2/2020 at 7:47 AM, lapoolboy said:
Did you pull back on and "unclick" the red locking tab?  You have to do that and then you can depress the tab on the light harness to unplug it.
...I too got the entire job done in about :20 minutes but I can't get the connector off the headlight. I pulled the red locking tab back (unclicked) but I can't find another tab to 'depress' to release the connector from the headlight. I can see from the new harness what has to happen--because it has both ends--but I can't get the one in the truck to release.
Anyone who did this install want to let go of the OEM front Bowtie?  I would like to color match one and would use this to run while I paint mine.
Thanks in advance
  • 3 weeks later...
  • 1 month later...
    • Because single shot injectors are ancient and multi hole injectors provide smoother running engines and sharper throttle response due to the fuel being atomized better..the best lead I have is a 24lb blue top injector almost everything matches up but the injector will put out about 26lb/hr which is just outside the gm threshold.figured id ask here to see if there was an absolute answer
    • Why is my question?   Any change in injectors requires a tune. Unless you are going back with the OEM part number or a newer part number of that same injector.   Any size difference or type difference like the EV6 style injectors all have different injector data for them. And there is no EV6 injector that matches the factory 25 lb/hr size that your truck comes with. I've been messing with these trucks and tuning them for a long time and what you trying to do doesn't exactly make sense to me.
    • My 6.6 gas lt8 had lifter noise with 28000 miles bought new 2026 and while driven to dealer it threw #1 rod bearing “HD my ass” good luck with yours i hope it don’t turn a rod bearing!
    • When a condition becomes a business model.    https://www.gm-trucks.com/gm-truck-suv-incentives-pricing-2026/   Zane posted this in "Latest Articles".    The honest bottom line   Truck buyers have spent three years assuming this is a temporary condition that will break once inventories normalize. GM just presented it to investors as a durable strategy, on a chart, as evidence of good management.   Inventory did normalize. GM is at 511,000 units and squarely inside its own 50 to 60 day target. The discounts still did not come back, because the low incentive number is the goal rather than a symptom of shortage.   Plan your purchase around that reality instead of waiting for it to change. Follow our ongoing GM News coverage for pricing and incentive changes as the next-generation trucks land.
    • Thought it was raining this morning when we woke. Nope. Dew point was over 80 F and humidity 98%. Zero visibility distance. Everything was 'sweating'. I've seen rain come out of clouds but never out of Pepper or the tree trunks.    Wicked storms just missed us sliding off to the east but by blocks. Heat index about 110 F with air temp in the 90's.    This is  our third wave this month of multiple days of this type of weather. And yet the grass is going dormant and the ground is cracking this side of the street and water up the the hood opposite. Just weird stuff going on.
