On 4/2/2019 at 10:59 AM, Smitty said:
Why does a sun roof change the max payload?
 The sunroof adds weight to the vehicle.  The weight of your vehicle's options gets added to the curb weight.  Subtract the curb weight from the GVWR and you have your payload capacity.
On 4/2/2019 at 8:23 AM, f8l vnm said:
My new 2019 Sierra Denali 4x4 Short bed rated @ 1486 lbs
My old 2016 Sierra Denali 4x4 standard bed was @ 1396 lbs
Not much of a change considering the 2016 standard bed accounted for most of the weight difference?
Yeah agreed.  Little odd actually. Only difference is 22. Vs 20 wheels.  The 2019 has 22 wheels
2018 Crew 6.2L SLT NHT Premium Plus Sunroof 6.6' Standard bed 20" Wheels
7600 GVWR
1847lb Payload
I know GM bragged about making the T1XX trucks lighter, but I have not seen much change in payload # vs a similar equipped K2XX.
I do like the increased cab size, exterior design, and the new HD's with the 6' 9" standard bed.
Just haul what you want and don't think twice about it.  The truck isn't going to fold in half and the drivetrain isn't going to grenade.  Drive sanely and you'll be fine.  I routinely drop over 2k in my F150 without batting an eye, never even hits the bump stops, and been doing it for almost 160k miles.  I once had almost 3k in my '17 Silverado and it did the job just fine.  Stop worrying; GM's marketing departments would have you buy a 2500 just to haul a bass boat.  Very few people who buy trucks ever get anywhere close to its actual limits.
I'll throw this out there: my '84 S10 with a 2.8 V6 (110 hp), 5 speed, single piston front calipers and rear drums has a rated payload of 1500 lbs.  Do you honestly think that ANY 2019 Silverado can only safely handle 1 human body's weight over that????
Unsafe, overweight, blah blah blah.
  • 3 months later...
4 minutes ago, OnTheReel said:
That’s a 6.2 NHT truck.
Oops I originally had a 5.3 truck and saw this one at the last minute. He wanted a non Z71 LTZ.
It all helps for my diesel forecasting.  Local Denali 6.2 CC SB was supposedly 5475curb/1625payload according to the dealer, which isn't that bad either.  AT4 was 5465curb/1535payload.  Where are all the GMC forum members?
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
