Man Down!!!
Hey fellas, I purchased a 09 Yukon Denali. Had it for 160000 miles in Feb 2017. Good truck. However, I’ve been putting the wrong gas. Gave me a tick. Took it to a performance shop to get an opinion. He suggested a rebuild since the motor was detonated. I was game. I then asked about getting a little more power. He suggested a slightly bigger cam. I was game. I paid him. He swapped my motor and gave it back. The piston cracked and got stuck in the block damaging the heads and block . I took it to texon motors to get it evaluated and they suggested we call it junk. I was game. So now I am looking for a 6.2. L 9 H . My question is . Would I waste money  buying a used motor and getting it rebuilt vs buying a Reman. I’m just looking for input to make a good decision before I get stuck again.
Did you buy it new? Done regular service to the transmission? Front end in good shape? Drive a lot? How much longer are you going to keep it? Doing the install yourself? A reman is a rebuild. Depending on those answers the choice can be made. You may want to check at your local dealer. Sometimes new is close in cost to a rebuild.
Why go pretty much the same route for another engine?
Get a GM Good Wrench engine.
And as Karnut said, is this Yukon worth it?
X2 on buying a new GM factory motor. Personally, I wouldn’t waste my time and money on anything 09 unless it’s more of a sentimental object which your case it’s not. Junk it, go buy yourself a much newer model or even a used Escalade with very low miles and making sure it’s got extended warranty and then you’re done.
Spending more than the vehicle is worth to repair it is ridiculous!
Sent from above
