On 8/16/2019 at 6:16 AM, JhevyCTB said:
I want to replace my red tow hooks on 2019 CTB and put black ones in. Anyone want to trade I’ll send the Red hooks for black ones
I will trade. I'm really looking for red ones.
I have the black on my 19 custom. I’ll trade for red ...
  • 4 months later...
I thought I would bump this, since I don't have enough posts to post in For Sale forum. I just installed a bull bar and have my red tow hooks for sale if anyone is interested.
How much you want for them I'm interested
Sent from my Pixel 4 XL using Tapatalk
I am interested as well...
Put me in line as well if those fall through. I'm definitely interested.
I just painted mine last week. Provides some red in the dark plastic fog light surround. 20200203_153753.thumb.jpg.eb8d586b06ac0d4cfaa595c90eae74c1.jpg
Nice truck man, Looks good.
Sent from my ONEPLUS A6013 using Tapatalk
I pulled my factory off, scuffed / cleaned, and painted with multiple coats of Krylon red followed with several coats of clear coat. Easy to do but don't make the same mistake I did and rush trying to put them back on... marked up the paint a bit pushing through the plastic cover. Give them several days to dry and you will not have any issues.
On 2/22/2020 at 5:57 PM, Flatblack83 said:
No more gay stock tow hooks..lol
Those look great any links to what they are or where you got them?
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
