Following. There is basically no AT4 stock near me that has the trailer camera package, so hoping I can maybe add it later. I would love this for towing my RV.
I wouldn't hold your breath on that. GM has made it very difficult to add options later.
If you want the cameras you better order one with it already installed to insure you have what you want.
Sent from my SM-N960U1 using Tapatalk
found that out the hard way too.  There was no trucks with the trailer camera package at any dealers around me, so i thought i could add it after too.  GM salesman even said i could of course...  Brought it in for an oil change and to have the camera added and they said its not possible on these new gen trucks...
I am curious if the rear trailer camera will stay on or if you just get an 8 second peek like you do when the camera is not connected.
if I have to activate it for every look that seems to lessen the value.
Thanks.
I have this plug on my 2019 GMC Sierra SLT Premium also.  Could you put this rear camera on a boat trailer?  Been trying to search for answer but no luck.  Thanks in advance!!
Best I can tell, at least in my 2019 SLT - the hard wire connections are there..  there is a connector behind the license plate that should be for a camera, and from 3rd hand information it seems the cabling is in the door/mirror for the side view trailering cameras...  so if you can get the cameras, great... what you'd be missing is the programming for the head unit to actually recognize them...  the dealer will most likely *not* do this.  Our only hope is to get somebody like WAMS to program it up for us :)
1 minute ago, 2k19Sierra said:
13530416
be warned though if your truck didn’t come with this it’s next to impossible to add after the fact...
Thanks!  Appreciate the quick reply.  I'm investigating whether not being able to add this is actually a fact.
Ordered a 2020 DENALI CARBON PRO 1500 and dealer said can't get the auxiliary trailer camera option cause of the technology package .This is crazy,you would think because of the technology package you can get the trailer camera option.
Well. I have the package and the camera on my 2020 NHT SLT.  I have a buddy with a 2020 Denali 3/4-ton that has the connection as well - but since his has the 360* cameras, his didn’t come with the separate cam.
I will go see him tomorrow and take my cam and we will just try it out.
Think the dealer led you astray. That was the case for 2019 but my understanding was they changed it for the 2020 trucks...
Would be great! Let us know!
I have a 19 HC as well as the trailering aux camera kit and just ordered the connector # that 2kSierra was so kind to provide.  I'll connect the existing tied back camera cable that's already present behind the license plate to the new connector once I receive it.  Then, plug in the aux cam kit I already have and see where things go from there.
Keep us updated!
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
