21 hours ago, LSX Z28 said:
I will definitely post what I find. Looking at the breakdown at the dealership, it looks like the camera has two screws that hold it to the 3rd brake light. It also appears that you can order the 3rd brake light with a camera hole, but doesn’t include the camera. Or you can get a light with the camera included, but you can not purchase the camera by itself.
I ordered the harness that connects from the camera in the brake light to the rear view mirror to see what the connectors looked like. (The picture above) I was hoping that it would be long enough to use as an extension and remove the camera from the brake light (or order a new one) and mount it on the cap. But the harness is only about 24” long. My new thought after I got the harness today would be to install the trailer camera, which already has a mount, and Is designed to be outside in the elements, and has a cable that is plenty long. I might try to order one tomorrow.
What does the wire on the harness look like? Do you think it could be cut and spliced with normal wire?
I have a trailer camera waiting for me at the dealer. I thought about mounting it to the back of the camper top and using it as a rearview mirror but wonder if it will work without a trailer hooked to the 7 pin connector. Anyone know the answer to this?
It wouldn’t let me set mine up without it being connected - but I will let you know tomorrow. I have set it all up, and will simply connect only the cam tomorrow and let you know.
Appreciate that
Even if it works it might be awkward running the wires but I'll cross that bridge when I get there
Here is a picture of the wire in the harness next to a piece of RG6. I showed it to a high end A/V installed, and he said he hadn’t ever seen a wire like that. He said it had similar properties to RG6, but you can see it is way smaller. I don’t know what the rear view camera rating is (looks like 4K to me) so I am not sure how the resolution would hold up with trying to splice in a different wire.
I would think that the camera would work in my situation, replacing the camera in the 3rd brake light, as that is already programmed to be on all the time.
I could see something in the programming not allowing a trailer camera plugged into the trailer port to work without a trailer hooked up. But who knows.
I'll get my trailer camera next week, may play with it some if I have time. Will let y'll know
14 hours ago, ArTurf said:
Appreciate that
It did not work without the camper being hooked up as well.  Not sure how the wiring goes - but I would think if you plugged one of the 7-pin test connectors up, and the camera it might work. I don’t have a test connector.
POLLAK 12741EV 7-Way Circuit Tester
Could you take a picture of the plug on the end of that camera wire, please?
17 minutes ago, 2019ArkansasSierra said:
Thanks! I guess that looks like a different connector than what I posted yesterday, so I guess that won’t work for what I was hoping it would. Back to the drawing board.
Well - that is the camera plug that comes with the truck (if it had the optional camera). The other end may just be the one under the bumper before it attaches to the combination plug on the truck itself. I’ll check. Mine didn’t have the “inside” trailer camera plug attached to the combination plug. It’s secured under the rear bumper - and you can see the empty space where it goes in the other pic I highlighted in red.
@Gypsy1962 did you get any good results after hooking everything up?  I'm in the same boat with the technology package and no aux camera option.
On 11/22/2019 at 2:34 PM, Chris Callanan said:
Best I can tell, at least in my 2019 SLT - the hard wire connections are there..  there is a connector behind the license plate that should be for a camera, and from 3rd hand information it seems the cabling is in the door/mirror for the side view trailering cameras...  so if you can get the cameras, great... what you'd be missing is the programming for the head unit to actually recognize them...  the dealer will most likely *not* do this.  Our only hope is to get somebody like WAMS to program it up for us :)
what or who is WAMS
Guys I really need some help I have a 2019 Sierra SLT with the"Trailer View Camera" Package and I have the two Aux ports on top of the 7 pin connector. I purchased the camera today for my 6x12 however whenever I connect the camera it is blank on the screen. Furthermore, I followed the installation instruction closely (not to connect the camera when the truck is running) yet there is nothing simply black blank scree. Is there something I am missing? Also the instruction manual talks about doing a calibration in the trailer app but there is no such a thing. All I have is an icon for the camera in the camera app that has the side mirrors and the trailer camera option but whenever the trailer camera is selected whether with the side mirror or not it just shows blank. PLEASE HELP !!
The only thing that I could think off that does not align with the manual is the 7 way connector. My trailer only has 4 pin and I am using and adapter to plug into the 7 way on my truck.
Edited by Aalfawaz
    250.3k
    Ragg-Boy
    Ragg-Boy
  • Who's Online   6 Members, 0 Anonymous, 965 Guests (See full list)
    • I had skimmed through that article when you posted the link and honestly I felt rather defeated in a sense and realized that all these years in changing oil that in fact putting in what I was told was a good quality oil was probably not filtered as well as it should be although the filter put on the engine would be what ( as long as it never went into bypass mode ) would be the final filtering of the new oil that the engine components would first see, but then the filtering media itself is not up to par to what is ideal because a full flow filter would be too restrictive to filter fine enough for the engines best outcome in the long run. Only one of our tractors over the years which was a Versatile with a 855 Cummins had a separate bypass filter, some engine manufacturers did spec a partial bypass system within the main oil filter but I don't believe any other trucks or equipment I was servicing used such a filter. No doubt a product like the Amsoil bypass system is of benefit as long as nothing goes sideways with the extra plumbing and filter such as a rupture/leak that could cause the oil to pump out of the engine ( yes that Versatile had a remote canister with hoses routed to it as well ). With the idiot egr system on a diesel and as a result forcing a lot more soot into the oil, that certainly isn't helping the diesel engines cause or as you pointed out the GDI engine issue with creating more soot and aside from having a fancy secondary filtering system, changing the oil more often helping lower the total soot load.     So oil manufacturing and the end product is not something one can control and I wonder if there are specs on what various oil packaging companies produce in particle count or size. As to the filtering, if the OEM is not designing a filter size and spec that is really what it could be, they too are short changing the end user and so what is the answer. Of course as you say the oil side can only do so much if the air side isn't keeping up its end of the picture and air filters are only so efficient and if in a dusty environment such as farm or construction or driving gravel roads there is a lot of dirt to filter out and some of that ends up into the air stream.    Of course the irony in places like where I am where they dump the salt on the highways but also will mix in some calcium or outright pure calcium for problem road area's, or using calcium as dust control on gravel roads, the vehicle that gets used in that environment may rust out before a properly engineered engine and maintenance finally wears out so one has to face that reality in the rust belt.
    • Has anyone run these on their 2500?
    • have you stuck with dealer oil changes since then? I made the same switch after getting tired of crawling around under the truck, but I’ve found some dealers are way better than others about getting you in quickly. Curious if yours has been good about scheduling or if you’ve had to look elsewhere for quicker turnaround.
    • Thank you.   I am set on a 3.0 Duramax as my previous truck with a Ford Ecoboost had just as many, if not more, "common" issues.  Cam phasers, timing chain issues, 10-speed valve body and CDF drum, emissions issues, etc.  So I figured, why not get 2x the fuel mileage (these things got 27+mpg on every mixed city/highway test drive I put them through) and better towing capability with resale value to boot?   My minimum, shortest trip will be 50 miles 1-way and I regularly go out of state with a travel trailer.  I'm planning on using this for a marketing/event promotion business also, which would require regular towing of trailers for bands, DJs, sound and lighting gear, along with my personal camera gear for filming events.   Looked at other trucks in the $30k+ price range but the issues seem to be everywhere, plus too many with gaudy mods.  I'm literally sticking with RWD trucks because they tend to be actually used as trucks, vs. the 4x4 models I've seen with unsafe lifts, huge tires, and general mods that would affect reliability (I'm wondering if some of them were tuned, hence the aggressive throttle response and hard shifting).   So my goal is to find a stock, 3.0 with 1 or 2 owners, in good physical condition, and decently well maintained.  Can't seem to find that up here, everything in the $27-30k range has had multiple owners, smoke smell, issues, or body damage.  Or the ridiculously modified trucks with 80k miles for under $27k but lots of problems...
    • That’s pretty tough Grumpy. I reread the previous few posts. They all reference oil changes. Much like your last thread. In my humble opinion it keeps things interesting.
