next time you bring it in...drive it thru the show room floor....tell them you dont know what the problem was and it appears to be intermitten....I HATE when the demeanor of the dealership changes after you take delivery. I havent been back to the dealer i bought my truck from for that very reason. as i said previously these are issues to the over all perfomance and function of the vehicle, not small glitches.
I didn’t get it back yet. They don’t know what to do. I’ll hear from them Monday because I told the service manager I want to be notified about everything and he will reach out to me on Monday he says. We’ll see
Bummer that sucks that your truck is having issues already.  I'm interested in how this is going to play out.
It is a bummer I almost don’t want the truck back but I will tell all when I find out. I am going to have them write everything down that they did.
what ever came of it
Cylinder one was miss firing. So every cylinder has a solenoid. The solenoid went bad and the more they played with it they collapsed a lifter. I got it back and so far so good. I took a 4 hour ride with a car trailer to pick up a new toy and truck operated perfectly. Also handled the car and trailer like a champ
I had the same issue today with the parking brake light coming on and then engine light as well with a rough idle . Brought it to the dealer and they said spark plug wire was loose and now it’s OK they say. Truck only has 62 miles on it. Hoping they’re not full of crap
  • Sad 1
my truck has had a cold start knock since new. Its now at the dealer for a misfire
Edited by ct_corey
  • Sad 1
I have had a number of issues with my 2019 Trail Boss also. The back of my truck is significantly squeaking like the shocks or leaf springs are bad, also hearing a ton of interior noises like rattles, etc. It was a fantastic smooth ride until I put about 5k miles on it. I am headed to the dealership with mine in the next few days.
So has the brakes problems been resolved after a master cylinder replacement? My truck has been back in the shop for 2 weeks waiting on parts!
When I start mine in the morning its has what sounds like a spark knock about 3 of them then all is good and having issues with the radio, the rear end makes a popping noise once in a while also
8800 miles on mine now Custom TB Z71 not 1  glitch,serviced myself  and keeping it that way!!!!
I had the value spring problem, but now it’s cutting off by itself. I’m so sad bc I love my truck. I don’t know what to do. Bc I traded my Tahoe that had 85k in miles and never had an issue. Please help if anyone knows anything.
On 4/7/2019 at 7:42 PM, BLUE TRAIL BOSS said:
just want to know if any one else is having problems with there 2019 silverado trail boss...at 50 miles i had all kinds of engine lights on and rough idle, bring it to the dealer the said spark plug wire was not inserted all the way. ok get the truck back and at 106 miles same thing and also hear noises from the rear of truck so back to the dealer I i go . i tell them to keep the truck and drive it for a week  to make sure there are no more issues .so week goes by they give me the truck back said they didn't find anything wrong with it . so i say ok take the truck back all was good till this morning at 640 miles service  esc and parking brake light came on truck ran rough . so i turn it off wait 5 min start it up and all is fine..i guess ill be bring it back to dealer but  don't think they will find anything so frustrated only have it a month and its going back to the dealer for a 3rd time....also parking brake engages it self every now and then...
Bummer, but it sure is a nice looking truck!!
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
