I saw that Kooks is offering exhaust and headers for the 6.2 and 5.3 models.  Anyone planning on getting them?  I'd like to have the headers/y-pipe combo but it's still a little rich for my blood so far.  Hopefully prices will come down once they've been out a while.
https://kooksheaders.com/collections/2019-chevrolet-silverado-gmc-1500-series-truck
Wow! $4k for a little sound and better flow just to be choked back down by cats. I'd rather spend that plus 2 more on a supercharger
Sent from my SM-G975U1 using Tapatalk
I don’t disagree at all, kooks usually makes really good stuff. I know the corvette guys swear by them but at 3100 for just the headers....I’m gonna pass.
Kooks makes good stuff, but, Man! that's spendy!  Tempting, but I'll wait a while to see what others will be offering and some comments from actual customers; no feedback on their web site yet.  And thinking about getting down in there to reach the old headers and install the new ones doesn't fill me with excitement......  Man, they really buried the engine down in there, didn't they???
Best headers I ever had on a truck were Doug Thorley try-wyes, but that'll never fit on my new truck.
I do wanna get me some headers.......:thumbs:
  • 5 weeks later...
  • 7 months later...
If your going to supercharge headers are a must.  I have stainless works on my supercharged 408 stroker in my 03 2500hd. Real nice quality headers that fit perfect, sad part is the expensive headers last and fit perfect.
Headers are good at all power levels with the flow, the smaller flow tubes help the torque range. A full exhaust with the headers is a must if u want the full potential.
  • 6 months later...
prices went down starting at  $1,389.75.
I do have Kooks headers/cat-less down pipes on my Redeye, with stock muffler and really sounds great!
btw, Kooks products are very good in sound and finish.
at this moment NOT planning on installing headers on my Trail Boss, prefer muffler delete/CAI.
On 5/7/2019 at 5:32 PM, Silverado4x4 said:
Headers are only good if you run your motor and high RPM.
Not true.  5.3's have consistently shown increases across the curve with headers.
Isn't it a good idea to do the exhaust when adding a supercharger?  You are cramming more air into the cylinders and expecting it to flow out the stock exhaust and not take a performance hit?
Yes you absolutely want more flow out when adding a supercharger, but if i went that route, I would eliminate the cats altogether to allow for more out flow. Doesn't matter now since I traded the truck in for a diesel
You can take stock manifolds pretty far in some cases. The CTSV and ZL1 camaro's will do alot more power than stock with factory manifolds. Even back in the day with the Cobra/Terminators, guys kept the stock manifolds because they still make good power.
Even most of the turbo LS's run stock manifolds or at least the drivers side is factory with a new cast turbo manifold on the passenger side.
Has anyone added the kooks headers with ultra green y-pipe and not tuned?  love to see the dyno results.
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 397 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
