15 hours ago, lworley said:
I have the SU5 in my 2020 RST and the chirping started at 15,000 miles.
Wow, I think you are the first with an SU5 front diff that I have read of having the JingleJingle noise!  :(
Go after them as I did. File for a lemon law buy back. Study your states lemon law rules. Go after them I won my case you can too. No one should have to listen to that racket.
Edited by ILSilverado
Considering there is currently no fix for this issue my GM my dealer told me to call back every month to check if parts are available until then He said there is nothin he can do.  He also said the issue is not safety related so he cannot keep it at the dealership.  How do I file for lemon law for this issue when my lemon law states that there must be 3 attempts made to fix the problem or 30 days out of service?  Considering no attempts can be made because of no parts available I think I do not have a case.  By the way I am new to this site and just turned 8000 miles on my 2019 GMC Sierra Elevation edition and the noise just started and is worse by the day.  Not happy!
On 2/26/2020 at 10:08 AM, ILSilverado said:
No. The new 2020 is jingle free.
So I just discovered yesterday that my 2020 now has the jingle. Discovered it at 2,500 miles. Have you heard it yet on yours? I’ve already gone through the damn buy back and got my 2019 replaced and I’m not going through that again...
The No Parts available for a known defect is a case. Contact the BBB and get going. Trust me this issue is well known to the BBB and GM. Once the ball is rolling I will be willing to help anyone here with there cases. Will be happy to give you my name and case numbers to verify GM re purchased mine for the same issue. just PM me when the time comes. If mine was repurchased yours should be too.
I am currently in the lemon buyback process and have been since June 6th. You have to stay on top of GM to get anything done. Do not give up the fight. They have tried demanding repair attempts and their final repair attempt. Not possible with no parts.
I hate to say it but I will no longer going with the Silverado. This is my second lemon case in two years. Still staying with GM since I do not want to take a financial loss on an inferior product. Going to give the new 21 Suburban a shot. If that one causes trouble, guess I will be doing a lot more walking.
I will be very happy to surrender all of my BBB papers and decision declarations.
I was just told by my service department that there is a fix for this axle issue but due to the Coronavirus parts are not available.  Is this statement really true? I was under the impression that GM does not exactly have a fix for the problem and therefore parts are not available.  Which statement is true?
1 hour ago, Thejet07 said:
There’s no fix
So SU5 axles won’t fix the issue?
I have the SU5 on my 2020 and it’s making the same sound. Was told there was no fix. Beyond ridiculous and embarrassing for GM.
You going to keep it?
Do you have anymore info on this fix such as a TSB or PIP number, I'd like to pass it on to my Service Advisor?
Maybe it's the jingle jangle of a thousand lost souls who spent their lives trying to get their GM trucks fixed:
Meanwhile, Elwood and I are driving down to the RAM dealer to trade the Bluesmobile on a new Power Wagon.
Edited by MaverickZ71
  • Haha 1
No I do not have other info at this time still digging to see if this is malarkey or the truth.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
