I’m at 3000 miles and I noticed that it comes from the long trim piece around the tail light on the roof that goes all the way across from door to door . I have the 2019 Chevy custom. And it happens when it’s been out in the heat and when I make sharp turns or over a bumpy road. Not so much in the morning when it’s cool l. It  only happened a little at first but has gotten worse. Almost like the plastic clips underneath the trim strip are flexing. If you push down on it. You can re-create the sound.  Mine is a double cab
Edited by Rkkiz
I thought I was crazy, but I have the same thing happening to me on my Custom Trail Boss. Sounds like a large bird poop hitting the roof lol. Definitely towards the rear like mentioned here.
Yep I get the noise occasionally and at random times (morning in the dark no sun) mid day, evening etc
Hadn't seen if anyone with a double cab had posted yet but mine does a little pop now and then too so I figured I'd mention it's not limited to the CC. Doesn't bother me though. In my wife's 2016 RAV4 we traded a few months ago, you could literally hear the whole unibody creaking and popping when going over un-even pavement or dips. It seriously sounded like every joint and weld was gonna break loose lol.
Edited by batman900
Never had that on my double cab, even on really hot days in the Sun. But when waxing the top, that roof metal is mighty thin and can easily be popped in if too much pressure is applied.....situation would be worse with the larger surface area of a crew cab. Might have something to do with the fact that many of the formerly steel panels have been replaced with aluminum.....maybe working like the biometal strip in a thermostat and dissimilar expansion rates under heat cause a creep or pop.
I've got a sunroof and I DO have the same popping.  I kept thinking an acorn or something dropping out of trees hit it, but then its happened several times with no trees around.  I can live with it, but I sure would like to know what it is.  The noise behind the back seat drives me crazy.
2019 rst cc no sunroof. Popping noise and I too have heard the noise when washing. Seems to be coming from the spoiler. Randomly hear it while driving as well.
On 5/3/2019 at 10:57 AM, DirkDiggler84 said:
Anyone getting a popping noise from their roof?  Every morning when I pull out of my garage and go over a slightly angled transition between my driveway and the street I get a popping from the roof.  I've heard it several other times when driving at low speed as well.  It sounds like the sheet metal is flexing, like if you were to slightly indent a piece of sheet metal, it slightly indents and then you push it in another spot and it pops out of that indent.  I have gotten a very similar noise from the lid on my washing machine.  I do not have a sunroof.
Yes, was figuring it just needs a break-in period.  Doesn't bother me that much...
Edited by BobbyAlton
So much for hasn't happened so far, pulled from the shade into the hot Sun and heard a pop.
I have the same sound on my 2019 trail boss LT with a sunroof. It happens about 3 times every time I drive it. Please let me know if anyone has a fix to this. The truck has 300 miles and it’s driving me crazy.
Edited by Cody2019TB
Same pop here, crew cab SLT and sunroof. I agree with the others, thinking it is just expansion from temperature changes. Going to ignore for now since I don't want my headliner removed.
Trail Boss LT with 1300 miles and have the roof popping. It's been there since day 1 and drives me crazy. Really hope they step up and find a solution for this.
I have only heard the popping sound while washing my truck not while driving. When I spray water on the roof I do sometimes hear a loud "popping" noise.
Same here...noticed the same thing the other day it the touchless car wash. Coincidentally on my way to the dealer for an unrelated item. Dealer says it’s likely roof sheet metal flexing. Going to see if it happens more frequently.
    • What meaningful corrections were done to fix the "machining errors?"   I bet nothing, because the 6.2 is soon to be obsolete. Why would GM implement any fix let alone an "expensive one?"   Until someone can provide any convincing information that GM did ANYTHING to correct the engines - the 6.2 is no for me.    Which means keeping the 2016 Denali longer until the next generation (6.6?) proves itself.
    • If my father took a Sunday off. We did the Sunday drive. Usually stopping at a Geno’s for dinner that we eat in the car. Six of us with my little sister up front. It was always a Buick growing up. In New Jersey you couldn’t get lost. Not like Texas.
    • Hoooooooly smokes, batman!
    • I suppose I am Atlas. It can always be worse, eh?   I had a friend once that rolled one payment into another until he was paying the price of Benz for a 10 year old back marker. Wouldn't be often you start a new payment the month following your old one.
    • I still enjoy the drive   Some people fish when they retire; some golf. I drive. We've lived in the same general area now for twenty eight years and I'm still finding at least monthly some sweet quite little road to explore. When I tell the Mrs. I'm heading out for coffee she knows that could be a five hour event. Often she even goes along.    I like finding new rural routes used mainly by the locals that start nowhere in particular and end the same way. Many in the area of that type are narrow paved and twisty, hilly and run through field and timber. Often along creeks or wetlands. Unfarmable areas of great natural beauty.    After years of this type of exploration they start to fit together. One ending a mile or so from another and you start threading together a new path from a unfamiliar place to a new adventure. Sometimes to a little town of under five hundred that used to be something before the Interstate or some railroad or US highway bled the life out of it that has a small dinner with the greatest slice of pie you've eaten since grandma made her last. A little village museum or library or even a town square park with grand old oak, walnut and Osage orange trees to sit under while you sip you gas station coffee and chat up some locals.    Often they are full of stories about the main streets more interesting buildings and the who's who of the area. Sometimes some hidden attraction or unseen history. Our area is full of old coal mines.     A younger self used to do this going cross country by motorcycle. Only a general area as a destination with no time to get there and no time to be back. Sitting at days end in a 10 unit off the main highway motel under a Sycamore tree yacking with the owner or his one semipermanent guest while I adjusted valves or the chain. Always a wave and a shout "Hey there stranger"!  It's how I came by my love of old Brit iron. There is no such things as a ten minute gas stop when your on a Enfield or a vintage Triumph. Same being true of old cars.    If you take the time to really look I've found everywhere is someplace interesting. Illinois or West Virginia. Different and yet the same.    People are in a more relaxed mood and will talk about anything and everything and if they like you there may be a cupp'a or a lemonade and a sandwich in it. 😉
