Trail Boss MPG Competition
21 hours ago, TrailDemon said:
Hey guys, I’m new here and in the truck world.
So I usually use only premium fuel on cars but since the truck can take 89 oct I used at times. The other days did small test with MPG.  I run the tank almost Empty on 93oct & added $20 on 93oct ( it gave me 108mpg).  Next I run the fuel tank to same level as before & added $20 on 89oct ( it gave me 140mpg).  I know cheaper gas burns quicker but isn’t odd that cheaper gas gave me more MPG?
And today on full tank on 89oct I finally got 21mpg lol
89 is cheaper than 93 so when you put $20 for both the 89 gives you more fuel.
  • Replies 60
On 5/6/2019 at 10:26 AM, ShamrockShooter said:
I'm running stock duratacs load range c. I consider them "mud tires". No doubt could do better with highway tires.
Sent from my Pixel 2 using Tapatalk
I wish they had more C-options across the the tire brands, seems it's either P or E.
Even though you consider them mud tires it is a completely different class and act as such. It is a hybrid AT (an AT tread and MT like sidewalls). If they were mud tires you would hear them and winter traction wouldn't be very good with the exception to deep snow; where the duratracs are pretty good in snow. With an actual mud tire you would probably be down another .5 - 1 mpg.
AT
https://www.goodyear.com/en-US/tires/wrangler-all-terrain-adventure
Hybrid
https://www.goodyear.com/en-US/tires/wrangler-duratrac
MT
https://www.goodyear.com/en-US/tires/wrangler-mtr-kevlar
Tyler
Lol, that was a dumb story haha
AT
Hybrid
MT
Tyler
P is not a load range, it is a tire group for Passenger vehicles. They are typically made in a standard load range, but can specify light load by an LL code following the size, or XL for extra load.
Load ratings such as C ,D ,F are ply ratings for LT class tires (light truck).
P-rated (passenger) tires are very inadequate for trucks unless you stick to the pavement and don't have much for a payload. The only reason GM uses them on trucks if to get the corporate fuel mileage as low as possible. You will lose 2mpg from a factory P rated SRA to a same size LT E-load. Most 20" tires are 10ply or E load rating just because the sidewall needs 10 plys to support the smaller sidewall.
I went to a LT rated 33" E load on my 6.2L and lost 4mpg,  6mpg according to the DIC. Each tire is larger and weighs about 20lbs more than the factory tires.
Back to the comment on DIC mpg accuracy. Just filled up 375 mile tank of mixed driving in my trail boss. DIC was 18.4, hand calc (2 click tfl method) was 18.3. so pretty much every tank so far has been within 0.1 mpg of DIC.
Yeah, TFL did 2 videos on this. Each time the Silverado was within .1 of the DIC on hand calculations.
On 06/05/2019 at 10:43 AM, econometrics said:
I'm at a 16.5 lifetime average on it with 1500 miles, and the majority of my driving is a 15 mile round-trip commute on 45mph roads with about 7 stoplights (that I constantly seem to hit reds on, ugh).
I guess that's where the auto start stop chips in to do its part for your fuel economy.
I usually disable it when I start the truck. Probably at least 80% of the time.
I actually don't mind using stop-start, but I find that a lot of my stops are really short. I don't like sitting at a stop sign for 3-4 seconds and having my truck stop, then re-fire only seconds later. Seems needless.
Yeah, that seems silly. Most of my stops are at relatively long lights so I'd probably leave it enabled if I had it.
I read somewhere on here that some vehicle brands set the stop-start to be overridden when you have your turn signal on. I wish GM did that. I would leave it on a lot more if that were the case.
On 5/6/2019 at 10:23 AM, Grumpy Bear said:
My DIC is 'happy' and ranges 5% to 12% per tank but is 8.3% over the truth by a 36 tank composite. Wife's GMC isn't even close and off by some 30%. My Buick will be dead on for a few tanks IF I'm traveling tank after tank but then misses by 3 to 4 mpg over interrupted tanks and both ways. :sigh:
Grumpy, do you do a lot of remote starts to warm it up? I can't believe you average 8% off of hand calc mileage. That means your DIC is routinely between 1-2 mpg high.
I have been hand checking most of my tanks since reading about the inaccuracies of our truck models 2 years ago. I have found that mine is almost always within .5 mpg, (about 2.5%) or better. I'd say usually its better than that. I don't chart the DIC readings, only my actual calculated numbers.
There must be some reason why yours is giving such wacky numbers.
15.9mpg  - 200 miles flat straight (alligator alley ) 80-85mph
I did 130 miles tonight with my RST. A bit of rolling interstate at first, but then pretty flat and no tailwinds.
19.8mph on the DIC going 80mph about 80 of those 130 miles, then 70-75mph the rest of the way. ????
I managed 24.2 on a 40 mile run at 60-65 MPH (flat terrain but lots of previous speed traps). So far the DIC estimate is within .5 mpg of the computer calculated value. My 2014 was equally accurate.
I don't get you guys as you seem to feel more MPG is better.  I think I "win" as I'm getting just under 10 mpg over the last 2,135 miles.  And yes, I'm talking about my stock AT4, not the car in my Avatar as that gets 3.9 MPG, on a road course.  The red car drains the tank dry in about 42 minutes on track running slicks.  I drive different than some and am VERY proud of my carbon footprint.  The lower the MPG the better!!!
    • I find it amusing the OP doesn’t realize this threads heading includes several engines. He should have posted in the off topic section if he wanted a more narrow focus. I really appreciate and find amusing that he actually pointed out one of my many vehicles. The Odyssey. That happens to use 0-20 oil. I love pushing his buttons.
    • Maybe, but it seems he is the only one that has backed up data to prove what he is stating. I think he is doing this more because he enjoys it and wants to get the information out to us. He's got the knowledge and access to the proper equipment and having the funds doesn't hurt.  I would love to do what he is doing and would do it if and when I hit the Powerball.  I'm not a Tribologist by any means but love to learn what I can.   I would bet there would be doubting people out there if a completely independent lab with high quality work and highly respected in the automotive industry, put out information like this.  The world can't be pleased, one just has to take the information that they are given, do more of their own research to find actual lab data to back up what they are trying to figure/find out.  Most don't bother, they just want to believe what they first see.     I don't have the minimax but my 6.2 in my 2019 Silverado with 64k miles shows excellent UOA results with 0w-20 and for my own purposes 5w-20.  Since not much of a change using 5w. I liked the data sheet information on the SS 5w-20 and figured I would give it a try.  Still the same viscosity at 100℃.   In the end we all just do what makes us happy, life is too short to get upset over trivial social media.   On a side note, I do feel GM has dropped the ball and just cares about the bottom dollar and not quality anymore.  "Like a Rock" has been long gone.  Seems "Built Ford Tough" has as well.
    • Better than stock but that's like putting lipstick on a pig
    • Hello, my 3 month old Sierra Elevation wont recognize a trailer with electric brakes? All the lights work correctly, but no power to the brakes?   This is the factory installed brake controller. If you manually push the knob, the display shows the power % but does not light up like my 2022 silverado.   I have an appointment with the dealer, but was checking to see if anyone else has seen this issue.    Thanks,
    • Been using SS 0w-20 from new, but wanted to change to the 5w-20 because I liked the data on the data sheet, to me it seems like a little better product. But as you can see, not much difference. This is also with running a mix of 10 gallons E85 to a tank topped with 93. It isn't a flex fuel vehicle so any higher I get a CEL for running lean on both banks. Yes my mileage takes a hit. Instead of 20 mpg I normally get on trips I get 17mpg. This is also using EaO17 filter.  What is amazing is I have the AMSOIL cone filter on it since I have the GM Performance intake installed and that air filter has 44k miles on it.  I just take it out and shop vac it off once a year.  I use the upholstery tool on my shop vac.  Works well.
