1 hour ago, FDHog said:
What truck do you have? I have an AT4 and it's either Tow or Sport
Trail Boss and AT4 only have Sport and Tow mode.  We have 4 low as a button instead of the Offroad mode and Snow mode and the Tour mode is just normal driving
8 hours ago, mafd2 said:
Tow haul turning left? What truck do you have? Left on my RST is snow/ice mode and tow/haul is a push button.
Trail Boss LT
2 minutes ago, Booger T said:
Trail Boss LT
Ok cool thx. I'm seeing several configurations varying from models.
Is yours the 5.3/8 speed?  I have the 6.2/10 speed and have the 4 different modes in my AT4.
Edited by jamez74
My AT4 has tour/sport/off-road/tow-haul.  It also has the button for 4 low.
Edited 8 hours ago by jamez74
Yes, 5.3/8 speed
I think the difference comes down to what cluster your truck has. I’ve noticed that trucks with the large digital cluster do not have drive mode indicators printed on the dial. This theoretically allows for the missing 4th mode (off road) that myself and others with this cluster have. Not based on trim level per-say as LTZ and AT4 without tech package have the smaller cluster display and dial with labels on it.
8710F30B-D97D-4B2D-A633-F81C2028BF63.thumb.jpeg.bf2c5c5c27cc6ee47cabaafaf0f568a0.jpeg1DE2FA71-58DB-42FE-8B0C-8B643DECE817.thumb.jpeg.7ea18a229f32e3a5324feb179b802b29.jpeg
6.2L with 10 Spd. We're talking about the round knob, not the 4 buttons for Auto/2H/4H/4L.
But then again, I don't have the tech pkg. Went for the Offroad Perf Pkg instead.
Edited by FDHog
Yes I know lol.  My AT4 has tour/sport/off road/tow haul with the dial. I only mentioned 4 lo because someone said if you had that then you didn't have the off road mode or something like that.
Too bad the damn Owners Manual doesn't explain this stuff!!!  Surely it doesn't as I know there's no way in hell anybody with a modicum of intelligence would post a very, very, very, very basic question like this without reading their manual first.  The OP most certainly knows they'd be labeled STUPID for posting prior to reading and I know there're no STUPID people on here.!
Edited by rikhek
I can see how you get 10mpg in your AT4.
Take a Xanax.
  • Like 3
Take a Xanax.
I GREATLY prefer amphetamines!!!
  • Haha 1
  • 1 year later...
On 5/18/2019 at 6:05 PM, MX86 said:
https://www.gmc.com/gmc-life/trucks/all-new-sierra-traction-select-system#traction
Overview of the traction select
This link is perfect and explains it nicely. I was surprised that only the top end trucks come with 2-speed 4WD, but with a 10 speed I guess it’s geared so low it’s about the same? So basically all the 4x4 Denalis and only the AT4 with the tech package come with it (i’m un sure about the Chevrolet trucks)
Edited by EXSlider400
I have an X31 Sierra SLT 4WD 5.3 10 speed. The only mode I don't have (that AT4/Denalis do) is touring.
    • This is NOT impact damage nor neglect. There were previous class action lawsuits because of such paint preparation st GM manufacturing plant. Not just the Cherry Red Color. This paint is applied in three processes to obtain the desired color.  The manufacturer will cover for 36 months or 36k miles only. That rust is actually corrosion because of the paint process failure. Corrosion is covered for 100,100 miles or a certain months. However their corrosion doesn't include this type. Go figure. Clearly manufacturer knew from previous paint issues. This started 3 weeks ago out of the blue.
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
