Installed the Motofab 2.5'' top spacer for the front this weekend. Before installing the measurements were 37.75'' in front and 39.75'' in the back measuring from the ground to the bottom of the fender. Initially after install the measurement up front was 40.25'', but after driving around and letting the suspension components settle it evened out to be perfect at 39.75'' all around.
I put rear blocks on my last 2013 Sierra and after about 2 years I was back to the ''raked out'' look that comes from factory. I'm going to opt out of putting blocks in the back this go around since I assume that it will continue to settle a little over time. With just this I have more than enough room for 35's on the factory wheels without out doing control arms and trimming.
On 8/16/2019 at 8:24 PM, rmkmb said:
2” front level ,1” rear block
285/60/20 Toyo’s
Hey there. Any issues with rubbing with that setup? I want to do the exact thing.   I see ur in a parkade. No clearance issues? What type of leveling kit did u use?
Thx.
2020 AT4 with readylift SST front lift only, 295/60R20 ridge grapplers, 20x9 +1 offset fuel vandals. Mud flap mod will get rid of the rubbing. Only rubs at full lock in reverse.
I’ve been thinking about this size of tire but wasn’t sure how bad it would rub with my 1.5” level. Got pictures of your mud flap trimming?
Tire and wheel Combo look great on that truck.
Thanks dude, I'll take some pics after I'm done. 1.5 I think would be pushing it. The SST lift got me almost 2" and it's a significant rub but not on the frame itself. Just removing the mud flap bracket got rid of it but I still want more clearance.
Here's mine.  2020 GMC Elevation with 2" AT4 OEM lift.  I wasn't happy with the feel of the front Ranchos so I replaced them with the Rough Country 3.5" lift struts, which gives me an additional 1.5" for leveling.
Edited by Kchampagne
35x12.50r20 Yokohamas fit on a 2.5 inch level. But only just. Have to trim the the flap. But UCA's and sway bar are clear.
Didn’t want to start a new thread and I’ve had trouble finding this online. Does anyone know what the factory front coil spring rate/weighting is?
I’m leaning towards the King coil overs for suspension upgrade and leveling. Coil options come at 600lbs (which I’m leaning towards) or 700lbs.
Im just curious how they compare to factory stock oem rates, if they’re 600 lbs too or if it’s less. Thx!
Edited by Duramax3oh
    Afennell19
    Afennell19
  • Who's Online   3 Members, 0 Anonymous, 811 Guests (See full list)
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
    • Anyone install a a supercharger on your 6.6L L8T? Talk to me...
