Had this same problem with the 1.5”. Got my money back and ordered up a 1”.
So do you guys not recommend installing the MF 1.5”?
I wouldn’t. I would do a top spacer, coil overs or leveling struts. It’s more expensive but I think better in the long run.
There’s a bunch of people running them without issue according to them.  Mine was contacting at full droop. I checked with it full droop and it barely touches.  I’d go with a top spacer if you want more than 1”.
27 minutes ago, Duramax3oh said:
Looks great! What tires/size do you have on there?
Thanks!
Stock Bridgestone Dueler A/T 275/60/20 and 20x9 stock GMC wheels.
  • Thanks 1
8 hours ago, woychc said:
Thanks!
No issues with the CV boot rubbing? I have a 1.5” I’m looking at installing.
Anything in the rear?
Well, initially a day after install the right CV boot was torn due to improper install by the installing shop. They replaced the CV axel and took care of everything for me. Since then not an issue. AT full droop there's about 1/4 inch of clearance with wheel strait, and full lock left and right. On the ground, there's at least 2 inches of clearance.
So will a 285/75R18 fit on a stock offset wheel under a leveled ltz? This converts to a 35x11.8. I see several people say a 35 will fit an at4 or trail boss. I know that i will need to do the mud flap mod but will that clear with just that?
On 8/8/2019 at 10:43 PM, stevensen5 said:
2.5 in front and 2 in back. Motofab
18 inch fuel wheels
285 70 18 ridge grapplers
Im looking to buy the same level kit from motofab but I am worried about the stock control arm angle with this level. How does the control arm angle look on your set up? also any rub with your tire setup?
I guess i should be more specific, im pretty sure when the dealer leveled it they did a 2” front spacer. Think itll fit a 35 with minor trimming?
    juggernautusa
    juggernautusa
  • Who's Online   3 Members, 0 Anonymous, 421 Guests (See full list)
