59 minutes ago, Supercup said:
Wish I had done a bit more research before I bought the RL level kit - paid $505 to tire rack for SST kit and a few hundred to have it installed - had I known what I now know I would have  spent extra dollars for BDS lift.  So now I have to decide if I want to return the lift kit to RL and eat the cost and get BDS installed or go back to stock?   If the truck was not leased, I wouldn't even think twice and would go BDS, but with 26 months left on lease, not sure if I want to do all that versus just going back to stock?
Buyer beware when you mod :)
its whatever your comfortable with and how you use the truck....
Sorry to bring this up again. So I noticed Rough Country removed the 2 inch lower spacer again for the 2019 - 2020 Silverado. . Today when I got home from work was going to wash the truck. I decided to jack the front of the truck up. Wheels where straight all the way off the ground. The boot does hit the the top of the bolt and small portion of the shock when spinning the tires. Lowered the truck turned the wheel all the way to the drivers side. Started jacking the front up. I was about 3 inches up with the jack it made contact with the boot even  more. Tire not even off the ground yet. 3 inches!! That's not good. That's like dropping off a 4 inch curb wheels locked. Just not comfortable with this set up. That's why they don't sell them anymore. So I'm looking at the Eibach strut. Or the rough country 2 inch strut replacement. In stead of using any spacers. Have to get a alignment again. Sucks. Xsquid   P S . Order the rough country leveling struts
Edited by xsquid
I am most likely going to head out to Corona and see Eibach this week....my plan is to run their kit and buy TB CV axles and probably pick up a UCA at some point....2.75 in front and 1 in rear....see if Eibach will install everything.... would like a hair more but whateves am gonna get a 2500HD in few years so it will be fine....was gonna do GM kit but just too much rake and don't want a spacer
think eibach fronts are lil cheaper than RC.....$140 ea and less if you get em from dist maybe, just FYI
Edited by Dunn
This is such a great thread. I’ve read through it multiple times, these trucks just look so good.
Based on what you guys are doing I shouldn’t be nervous, but I am. I want to go Icon/Fox 2.5 coil overs set at lowest 1.5” lift setting and no block in the rear. Then add KO2’s in 275/65R20 on the stock oem wheels. The shop suggested 285/60R20 to avoid any rub but I want the taller tire that fills the wheel well more, and don’t want “too” wide.
I have stock 275/60R20 Dueler ATs now. They just seem very very close to the mud flaps when turned. I don’t want to remove or trim. Will 1.5” lift do for my needs or will I need to go 2” up front? This is LT Z71 stock
Thoughts?
Edited by Duramax3oh
So your trucks not leveled at all. Yes the 2 inch level will you should fit the 275-65-20 no problem. I plan on that the same size but a copper tire when the time comes. 2 inch level with a 1.0 or 1.5 block in the rear is a nice set up. Beware of the lower strut spacers as if you plan on doing any off roading. Even the video from ready lift address the problem as by saying. (If you never go to full drop you will never have a problem.) Never say never. Wheel turn full. 3 inch's up with jack the boot starts to make contact. My truck anyway.
On 8/16/2019 at 8:24 PM, rmkmb said:
2” front level ,1” rear block
285/60/20 Toyo’s
Where did you get the 1" rear blocks? Brand?
I used my 2009 Silverdo factory block 1.25 inch.  left over parts with u bolts. But have seen them on e-bay . Before I remember I had them somewhere in the garage.
Which are bottom and which are top leveling kits? Want to do one for my 2wd
How would you feel about that tire on a 1.5” level up front and no block in the rear
Tire sizing . 275-60-20 . Stock tire on 2019 Silverado with 20 inch rim.  275 * .03937 = 10.82675 tire width. Answer 10.82675 - 60% = 6.496. Answer 6.496 * 2= 12.992. Answer 12.992 + 20 inch Rim = 32.992 tire dia. 33 inch's . Using this formula you can figure any metric tire size. 275-65-20 = 34.074 tire dia. Should fit no problem with a 1.5 level or 2.0 level. It the same width just 1.0 taller. Or 1./2 on each side.  Use any leveling kit in a 2 wheel drive truck no problem. Use caution in 4 wheel drive going off roading.  Tire formula will get you very close. Tire manufactures very some with ply,  road tie ect. Best to check manufactures web sight for exact dimensions.
275/65/r20 will fit without any rubbing with a 2 inch level. Regardless of which level. The demo I drove while my dealer did my bed liner had the GM 2 inch level installed on a RST model with 275/65/r20 BFG all terrains. Plenty of clearance. 35x11.50s would clear in my opinion
For the 2” lift spacers what is the actual dimension of the the spacer? Not the lift, the actual spacer?
Changed out the Rough Country 2 inch bottom mount level kit for the Motofab 2.5 inch top mount level kit.
Already had the Rear spacer blocks from my 2014 Sierra installed.
Truck look good Vmax. Will be removing my Motofab 1.5 lower spacer. RC 2inch leveling struts should be here this week. I install my own lowers. When removing the complete strut do you need the remove the axle nut and push the spline through the hub in order to gain enough clearence to lower the lower control are enough without damage to the axle's to remove the complete strut assemble?
    Whit.the.COB
    Whit.the.COB
  • Who's Online   3 Members, 0 Anonymous, 1,236 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
