43 minutes ago, hihosilverado said:
Awesome!  Thanks for passing along the picture.  What’s the noise level like on the tires??
The noise sort of surprised me. It’s not that they are loud, it’s just more noise than the original tire. I should have expected that going to a more aggressive tire. But my wife did not even notice a difference...I’m just a little OCD. But I still really like them. They are smooth and comfy riding like the original tire which was my main priority right now.
Looking into reverse leveling my AT4.  I'm hoping someone could tell me if the stock u bolt has enough thread to simply remove the factory block with no other modifications. Because- free level right?
Bonus question- if I'm only lowering(or if I was raising) the straight axle, would I need an alignment like lifting/lowering an independent suspension? Because- literally free level.
Thanks!
Thanks!
Personally I wouldn’t reuse U bolts. There’s plenty of stories of fails and reasons why not to. Just buy the factory new ones that are on the standard Silverados
On 5/15/2020 at 8:57 PM, 62AT422 said:
2" level
Are you running the RC? What’s your wheel setup?
Just a 2" leveling kit. Wheels are 22x10 -18 offset w/33x12.5s
Thought i had photos with a load but mine squats pretty easily. Eventually would like to solve this because i do tow or haul a decent amount. But also really like the level look when empty.  But even in this photo an empty trailer even though it is a fairly heavy trailer it brings the back down quite a bit. Sorry not the best photo
On 7/28/2020 at 7:46 AM, Duramax3oh said:
Does anyone have pics of your leveled truck while towing a trailer? I'm curious to see the "weight/squat ratio"...
This is trailer empty 4,500 lbs - 900 lbs tongue weight - 2.5" of squat - added load level hitch (1400 lb bars) and with it I got back about 1.5" of the squat - so only about 1" of squat with load level.  Will likely add a Deaver overload spring pack soon as well to help carry the load. Fully loaded will be 9,500 lbs +/-  but tongue weight will not go up much and may go down a bit with moving the car around.
On 5/5/2020 at 5:49 PM, Casey Nelson said:
2020 AT4, Readylift 2” SST with only the front lift. Rear sits .75-1 inch higher as is. I don’t think I got 2” from the lift. I was at 38.5” from ground to the line where the plastic black fender folds in, centered on the hub. After, with stock wheels/tires, I was at 40”. Now with 33’s, I’m at 40.5”. Wish I had measured from the center of the hub. Anyone have any measurements on a non At4 stock?
2019 AT4 - 6.2 Carbon Pro
Before and after photos below - similar measurements to you - I have OEM painted strips where yours are rubber - but about the same specs.    Ready Lift SST - I was 38 before and 40" after up front and back 40" before and 41" after with new rear block added.
723929915_Measure2.thumb.jpg.dbedacb2d5dfcaaa25b35e8e3ca55071.jpg1695835590_HeightAfterLevel-Rear.thumb.JPG.3d9f312e630ab3ecd483dc475c0d4a6e.JPG
On 4/20/2020 at 8:38 PM, Kchampagne said:
I believe so.  Model 501066. I used the  3.5" lift N3 struts with my AT4 lift to get a 1.5" level.
Are you still happy with the set up? I have RL 1.75 and hate the sloppy ranchos. I was thinking of taking out the RL and replacing it with the this. Just to confirm all you have is the new strut/spring assembly from RC, no other spacers.
    Matt Parker
    Matt Parker
  • Who's Online   4 Members, 1 Anonymous, 1,126 Guests (See full list)
