21 hours ago, Grumpy Bear said:
How outrageous does a lie have to be before your backers puke...
".....50 MILLION dollars spent on condoms for Hamas."
The original VALID question before we lose the train of thought.  Simple question.  Being ansered by Karnut as essentially riding the TITANIC of idiocy into the deep.
  • Thanks 1
33 minutes ago, Grumpy Bear said:
Supporting documents? A copy of the OFFICIAL investigative report perhaps?
 I haven't bought any condoms lately but seems like allot. All I have SOLID to go on is his video taped televised statement which aired on all networks, left right and center. He said what he said.
Better one today. He's sure DEI is responsible for the air crash. But when pushed by the press pool on the source of his remarks it boiled down to "Well....it could be true". 😬 IT COULD BE TRUE?? :dunno:  Really??
It’s so obvious where you stand. I know I want the best where life is concerned. That’s the point. Wasteful spending was the other point. That’s reality.
He's non political! He's a Christian who wants honesty and rule of law.  Its SO OBVIOUS but OBVOIUSLY NOT TO YOU and your COMPATRIOTS who want change so bad they will play footsie and bird strike on the US CONSTITUTION.
  • Thanks 1
My way of thinking has provided me with a very nice life. By being very conservative in thinking and finance. My trajectory has always been upward. That way is beginning to be practiced now. Eliminating waste, make believe, and pie in the sky. The boat is rising. The hole has been patched.
MY and ME.       USA was founded on self interest my friend,...... but also WE and US.
I’m bored with your drivel. You make no sense. I’m so glad most everyone came to their senses. It’s ashamed you didn’t. By for now.
Don’t be angry or hurt. Grumpy Bear just layin’ some truth on ya.
One of the few people that gets me and I can disagree with without a body count. Thank you Terry, dead on.
As true as that may be, lying to make a point doesn't make a point. I foments distrust. That IS the point. Spinning lies doesn't make them more palatable. Doesn't make them more trustable. Supporting liars does elevate your position.
Look, truth is MY POINT. My only point. ( @txab) He's just the setup. He makes making my points easier.
This is the most powerful man on the planet currently. If this is the playbook then why would anyone think less powerful persons welding the power of marketing  would be one iota less intentional and deceptive?
You think OEM's and Oil blenders are more truthful? Held to what standards? To what measure? How about food and medicine? He's not special. He's just bold. They all are.
Proof isn't likes or pod casts or even a wish.
These are just people that have forgotten they stand before their creator where their lies are laid bare and the piper exacts his due. They can NOT hide!
:rant:
Edited by Grumpy Bear
  • Thanks 1
:rant:
You obviously have never been in a situation where you had to depend on other people for information. I guess you expect the most powerful person to go over the government spending report himself. His point obviously is on cutting expenses. That was an example. There are many others. You want to call the most powerful person a liar because someone gave him bad info. You’re being ridiculous. And showing your stripes. I guess you never gave wrong information based on another’s research. I believe in a perfect person. It’s not you. You called a man a liar. He’s definitely not going to do that willingly. It to easy to fact check. I guess you can’t even consider it may have been a setup. You claim not to political, your statement was. You claim to be fair and not judgmental, you obviously were. Then you quote scripture. Hypocritical.
  • Sad 1
I'm just going to shut up before I pi$$ someone off or hurt some feelings.
You won’t hurt my feelings. I spent my life working with my family. Let her rip. Make it quick the enforcer will be around soon.
  • Thanks 1
Go for it.
As we all watch and discuss HONESTY the most powerful guy in world is purging the FBI and DOJ. Without due process every federal employee is given. Guess what the purge targets have in common? Being assigned to investigate his many missteps. Now that he’s king he purging. None of the lawyers or FBI agents had a choice in their assignments. I’m betting many supported or support him.
Im not against cleaning up governance but do it with HONESTY aligned with constitution.
Civil Service law is under constitution by law.
    • 3.41 Kroger’s in Montgomery TX
    • I really wanted to go to the Fox 2.5's But they were like ~$1,500 vs ~$425 for the Bilsteins. And my research on FOX shocks was that they do not have a great reputation for longevity. I am sure they the FOX's are fantastic, but I know from experience the Bilsteins are rock solid for at least 150k miles.
    • Conditions for Meeting a Cold Start   The ignition voltage is between 10 and 15 V. The barometric pressure (BARO) is more than 75 kPa. The engine coolant temperature (ECT) at start-up is less than 42°C (108°F). The intake air temperature (IAT) is between 2–32°C (36–90°F). The engine is OFF for greater than 6 hours or the following conditions must be met: The start-up IAT minus start-up ECT are within 12°C (22°F). The start-up ECT minus start-up IAT are within 50°C (90°F). Fuel level is between 25 and 75 %.   Circuit/System Verification Verify that all I/M System Status indicators report YES, and that no I/M Test DTCs are present.If any I/M Test DTCs are set Refer to Diagnostic Trouble Code (DTC) List - Vehicle. If no I/M Test DTCs are set All OK. Inspection/Maintenance (I/M) System Set Procedure   Warning: Refer to Road Test Warning. Note: Do NOT touch the accelerator pedal until told to do so. A change in TP Sensor angle or an increase in engine speed may invalidate this portion of the test.   Note: An I/M Test DTC will not be stored or erased from the ECU except at the end of trip processing, which occurs 5 s after ignition OFF.   Ensure that the vehicle meets the conditions for a cold start listed above. If the EVAP I/M System Status indicator displays NO, perform the EVAP Service bay test if applicable. Turn OFF all of the accessories; HVAC system, other electrical loads, including aftermarket/add-on equipment, etc., and open the hood.   Set the vehicle parking brake and ensure the vehicle is in park for automatic transmission or neutral for manual transmission.   Start and idle the engine for 2 min.   Close the hood, release the parking brake and Accelerate at part throttle to 72–80 km/h (45–50 mph) with this speed maintained until the engine reaches operating temperature, 8–10 min.   Continue operation under these conditions for an additional 6 min.   Accelerate at part throttle to 90 km/h (55 mph) with this speed maintained for 2 min.   Release the accelerator pedal for at least 10 s. This will allow the vehicle to enter the decel fuel cut off.   Safely stop the vehicle, with the engine in drive for automatic or neutral with the clutch pedal depressed and parking brake applied for manual. Allow the vehicle to idle for 2 min.   Shift the vehicle to park for automatic and neutral for manual. Turn OFF the ignition and exit the vehicle. Do NOT disturb the vehicle for 45 min.   Observe the Inspection/Maintenance (I/M) System Status with a scan tool. All of the I/M System Status indicators should display YES.   If the EVAP I/M System Status indicator displays NO, turn OFF the ignition, ensure that the vehicle meets the conditions for a cold start, and repeat steps 6-11 three more times, or until the EVAP I/M System Status indicator transitions to YES. If the indicator continues to display NO, refer to the Inspection/Maintenance (I/M) System DTC Table to identify the DTCs that did not run.   If any of the I/M System Status indicators display NO, refer to the Inspection/Maintenance (I/M) System DTC Table for the indicator which did not display YES. The I/M System DTC Table identifies the DTCs associated with each I/M System Status Indicator.   Observe the I/M Test DTC information with a scan tool. Verify there are no I/M Test DTCs present. If an I/M Test DTC is set, diagnose the DTC using the Diagnostic Trouble Code (DTC) List - Vehicle and refer to Inspection/Maintenance System Check.   Observe the engine DTC information with a scan tool. Verify no DTCs are present. If a DTC is set, diagnose using the Diagnostic Trouble Code (DTC) List - Vehicle. After repairs, perform the Inspection/Maintenance Complete System Set Procedure to verify no further DTCs are set.       Looks like one procedure to me.  Repeated as necessary.
    • My 2020 AT4 6.2 has had the valve spring issue addressed at ~200 miles, front cover/pump replaced at 18k, water pump at 34k and idler pully at 65k.  I would agree with ditching by 100k unless you elect to go with upgraded hardware...say built 10l80 and an lt4 or l8p swap.
