Holy smokes... UPS plane crashed in Kentucky. It looks like people were hurt. :(
What the heck is going on - more planes have fallen out of the sky in the last year...
Maybe the FAA shouldn't have been Doge'd, maybe pay shouldn't be withheld from ATC's. I'm not saying that's the cause but it sure as heck isn't helping bolster safety.
  • Sad 1
I retired from American Airlines and we were worried 20 years ago about quality pilots that were scratching and sniffing to claw way to majors. The military feed and critical screening is long gone. You make more $$ and get better lifestyle being in military than a pro pilot. We are getting bare minimum quality. I’m sure AI will correct all this need for professionalism. 🥹
  • Sad 1
MD-11 a tricky jet to fly especially heavy ON TAKEOFF. We sold FEDEX and UPS ours when 777 finally showed up.
Both have crashed them more frequently than any should have. Shelter in place a pretty serious order! Gee.
https://www.lpm.org/news/2025-11-04/shelter-in-place-issued-in-louisville-following-reports-of-plane-crash
That sound serious. Also terrifying to think AI could be responsible for flying a plane someday - or would it reduce errors? I don't know. I've heard nothing good about people trying to make their way up the chain being commercial pilots. It's a tough gig, all-consuming, and the pay isn't there like it used to be.
  • Thanks 1
Seriously, hauling cargo and boxes going automated. As soon as the tech bros buy off the administration. PS AA never crashed a MD11.
9 hours ago, txab said:
Looking at a takeoff catastrophic LH engine fire and seems the crew forgot to fly the jet. Fires are terrible and usually you don’t want to take it into air but he ran outta runway. Full of fuel. Vertical stab is a fuel tank too.
On 11/4/2025 at 11:40 PM, txab said:
I saw last night the death toll is now 12 with 16 missing. Crew was only 3. That was allot of fuel. Will be interesting what the authorities find out. Truly sad event.
  • Sad 1
40,000 gallons if I recall.
Edited by customboss
Interesting that the FAA decided the day after the crash to reduce commercial flights by 10%, stating they are doing it to maintain air safety. Pray for our air traffic controllers in these difficult times. They need relief.
  • Sad 1
By Josh Evans
Stephens Ford Flathead OHV conversion is one of the rarest and most fascinating performance adaptations ever developed for Ford’s famous Flathead V8. During the late 1940s and early 1950s, before Ford introduced its own overhead-valve engines, several independent engineers and speed equipment companies designed conversions to give the side-valve Flathead more breathing ability. Among these innovators was Bill Stephens, who developed a unique overhead-valve (OHV) cylinder head conversion that dramatically improved the Flathead’s performance and efficiency while maintaining its original block design.
Stephens’ conversion was designed to solve one of the Flathead’s biggest limitations restricted airflow caused by its valve-in-block layout. By moving the valves to the cylinder heads, the conversion allowed for more efficient combustion, higher compression ratios, and increased power output. The system replaced the original L-head cast-iron heads with custom aluminum heads that featured pushrod-actuated overhead valves, a rocker shaft assembly, and redesigned combustion chambers. This gave the Flathead characteristics similar to later overhead-valve V8s while retaining the iconic Ford block.
The Stephens OHV setup was produced in extremely limited numbers, primarily for racing applications and high-performance enthusiasts. It was seen as a competitor to other conversions of the era, such as the Ardun (designed by Zora Arkus-Duntov) and the Navarro OHV kits. However, the Stephens design was unique because it used a crossflow configuration, meaning the intake and exhaust ports were on opposite sides of the head, improving airflow and reducing heat buildup a common issue with traditional Flatheads.
Mechanically, a Stephens-converted Flathead could easily produce over 160 to 200 horsepower, depending on compression and carburetion a major improvement over the roughly 100 horsepower of the stock engine. Builders often paired the conversion with dual or triple carburetors, a high-lift camshaft, and custom headers to take full advantage of the improved breathing. The result was a smooth, powerful, and durable engine capable of competing with early overhead-valve V8s from Cadillac and Oldsmobile.
Today, a Ford Flathead with a Stephens OHV conversion is considered an extremely rare and valuable piece of hot rod history. Few complete examples survive, and when they appear at shows or auctions, they draw significant attention from collectors and historians. The Stephens conversion stands as a testament to the ingenuity of early American engine builders, who pushed the limits of what was possible with the original Ford Flathead design long before factory overhead-valve engines became the norm.
3 hours ago, asilverblazer said:
To whom, your "false... fairytale" God?
Atheist I assume. An Agnostic believes he exist but doesn't care about his creation? Am I close?
Edited by Grumpy Bear
Looks like UPS and FedEx grounded their fleets of MD-11, at least temporarily. Antiques that probably should have been retired years ago. But UPS especially penny pinches like nobody else. Have a few friends there and it does take a tragedy to get anything fixed. 🙄
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
