On 11/8/2021 at 7:49 PM, HotChiliRam said:
Specs??
- 2020 High Country 3.0 Duramax
- 6" BDS lift kit 1803H
- 22" x 10" -18 offset Fuel Blitz
- 35" x 12.5" Nitto Ridge Grapplers
- Bilstein 5100's
- EGR flares
- Hypertech inline calibrator
- Bak Revolver X4s
- Weigh Safe hitch 10" drop
Edited by Bgill
2020 Silverado 1500 5.3 WT 4x4
Snowflake 24X10 +27
Crosswind M/T Mud 37X13.5X24
8 inch ReadyLIFT
No spacers
No rubbing
No trimming
Edited by Lycan LLC
On 7/15/2019 at 1:27 PM, bamulk said:
Method NV 305 18x9 -12 Offset
Cooper Discoverer S/T Maxx 295/70/18
1.5 Level (Trailboss)
Slight Rub on mudflap on full lock.
This is the exact same setup I've been looking at except the Method 705 with +18 offset.  I'm thinking it won't rub at all as it only kicks the tire outboard 3/4"
17x8.5 Method 305 with 0 offset
37x12.5 Toyo RT
Dirt King long travel kit and fiberwerx fenders+bedsides
No rubbing after minor fiberglass trimming near the firewall
Edited by Peter S
  • Like 4
On 9/26/2021 at 7:52 PM, Rich Roche said:
Stock wheels. 35/11.5/R20 Toyo Open Country AT3. 4” Ready Lift. No Rub.
How does this lift hold up? Any issues I have it and mine creaks in the back. (Sorry if not asked in the correct area, just so much information and most of these are trail bosses not LT’s)
On 10/21/2021 at 10:42 PM, HK_Crew said:
Method Race Wheels MR317 in 17x8.5 - 0 offset and 305/70/17 Nitto Ridge Grapplers
Looks great. What lift are you running?
On 9/1/2021 at 5:26 PM, Ithan Henry said:
Fuel Block 17x9 -12 offset with Falken Wildpeak MTs 35x12.5 all on the stock Trailboss suspension. Had to remove the front mud flap brackets and zip tie the liner back but that was expected. No rubbing going forward, just a slight rub at full lock in reverse. Got this setup about 2 years earlier than expected. Found the set of 5 tires and rims, brand new, for about the price of 3 on Facebook. Had to jump at that deal.
Good looking truck!
What front bumper is that?
On 9/11/2021 at 5:06 PM, johnsills1 said:
20X10 Fuel Tech Anthracite with 305/55/R20 Nitto Ridge Grapplers…..
I am having a 4” lift installed on Friday due to rubbing issues and I don’t like the idea of cutting anything to make it work.
Good looking ride!
What bumper is that?  Its rare to see one that blends in so well with the front end geometrical shapes.
Looking to replace the stock rims and tires on my 2020 GMC AT4.  Looks like a lot of people are running 18X9 with -12" offset on 35X12.5X18.  Does this sound correct and will it rub with the stock suspension?
Thanks
Colton
Edited by cjkiefer
Thanks
Colton
It'll possibly rub slightly towards the firewall at full lock. Removing the bracket behind the mudflap will clear up some more space. Pretty much guaranteed to rub while at full bump and turning. If you stay mostly on the streets it won't be much of an issue though.
    jaszr2
    jaszr2
  • Who's Online   5 Members, 0 Anonymous, 460 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
