On 11/5/2022 at 1:32 AM, Jordy 604 said:
Specs on your setup?
This gentleman says he’s put a 285/65/20 set on his AT4. Stock. No rubbing. Haven’t seen anyone else put on this size tire. Can anyone confirm this?? I’m about to pull the trigger on a set for my ‘19 AT4 if so.
On 9/20/2021 at 5:47 PM, GxOxBxLxN said:
Black Rhino 20x9.5 +12mm
Ridge Grapplers 33x12.50
GM 2” lift and 2” spacer in front
I can’t stop looking at this setup! I have some 305/55s in the garage waiting to go on… this is the look I want!
You say 2” GM + 2” spacer. So, this is a 4” lift? Or, you put 2” wheel spacers?
Any chance you could upload some side pics and a pic from the back? My truck is silver with chrome steps x31 also.
On 3/22/2022 at 3:38 PM, TyAT4_6.2 said:
Stock height? Any rubbing or trimming?
sorry for the late response. That was stock at4 height there wasn’t much rubbing at all except in certain situations it could touch the mud flap a little bit but not enough to worry about trimming.
7 hours ago, Andy Toledo said:
20x9 Fuel Rebels +20
1.5 spacers
37 Falken Wildpeaks
6” RC lift with Vertex COs
What brand spacers and any issues with torque or vibrations?
Awesome ride!
Awesome ride!
KSP hub centric spacers. No issues at all
Why buy spacers instead of 0 or negative offset wheels to get the look/fitment you want?
20 x 9 Fuel Contra  +2
35/12.5s Kenda Klever R/T Hybrids
3" Superlift w/A arms
No Spacers . Slight rub at full lock when hitting a dip. Trimmed Mud flaps and pulled back liner   409056859_Trucknewwheels.thumb.jpg.ae8be0b1ff558186d970e0201cc37aca.jpg
295/70/r18 KO2's on stock AT4 rims, no lift, no level. She rubs but barely at full lock when going up/down an incline on angle. I do have the added on mud flaps which is what they're hitting. With them removed no rubbing at all.
Bought wheels that would work with different lift kit. Lift was in back order so switched lift kits and wheels wouldn’t clear so it was easier to get spacers than buying another set of wheels. Plan to buy new wheels with offset I want in near future to eliminate spacers
Truck looks good! Did you do the clear reflectors on the headlights?!?
More pics of headlights? you do them yourself?
    • It was never mandated.  Ever.    Automakers were incentivized to install it by getting CAFE credits to help with their vehicle fleet fuel economy scores.  They were being handed money/CAFE credits to install it.  Which is NOT a mandate.       The current admin removed the incentives that were behind them installing it.
    • I went another direction after losing a trailer tire, thanks to not being able to access air at ANY of the 5 gas stations and garages I stopped at prior, with a Toyota Tacoma onboard, 50 miles from the Canadian border. They were either out of order, access was blocked, or the hose a few feet too short and I couldn't get any closer without risking damage to someone's property.   https://postimg.cc/gallery/X5QJ55w
