10 hours ago, bamorris2 said:
Does King makes shocks for a stock 2019 Sierra 4x4? I can’t seem to find a fitment guide for them.
Two people I know of that would know about new products. Accutune or Filthy Motorsports. Best I can do sir.
I appreciate it, and I’ll check them out.
Just ran across this in my old correspondence. Forgot I had Dane's contact info. Rolodex in the noggin is fading. :)
Dane J. Larsen
Sales / Customer Service
King Shock Technology, Inc.
Phone: (714) 530-8701
Fax: (714) 530-8702
www.kingshocks.com
Edited by Grumpy Bear
I've spoken to Ben at Filthy Motorsports about the King 2.5's... he's very helpful and puts out excellent informative videos about shocks, UCA's, etc
On 8/3/2020 at 10:18 AM, Grumpy Bear said:
Bilstein 5100 and 6100 are digressive.
I love my Kings.
Most irregularities in the road are low amplitude. Under 3". If the shock does not give that force is transmitted to the chassis in lift, bounce, step out. The faster you drive the worse it gets.
What a digressive shock does well is control roll axis movement. Just what a truck needs with high bed or tongue loads. Stability. The OEM believes it's either or but there are other ways to control stability. It's just the cheapest.
Digressive valves work GREAT on smooth racetracks and full payloads.
I always learn a ton from your posts Grumpy.
I’m going to be towing a lot more than I originally expected, 6000 lb trailer. You say a digressive shock like Bilstein 5100 would probably be better for this correct?
How would the King 2.5’s do with a decent amount of towing in this regard? Solely wanting that on road comfort over street bumps and then Solid stable safe highway towing. Probably get them “tuned” specifically for this need right? How often will they need to be serviced with this use (no off-roading)?
Would front King 2.5 coilovers and rear Bilstein 5100’s make sense? Or would mixing the linear and digressive not work well
lastly, does anybody know if the 2020 silverados have room in the rear for piggy back reservoir shocks? Like Bilstein 5160 or the King 2.5. Just casually looking doesn’t seem like a ton of room. I might install a Roadmaster active suspension (RAS) on the rear leaf springs and worry if that could impact a remote reservoir if mounted on the frame in the wheel well during a heavy impact
Edited by Duramax3oh
Thank you. I try to be useful
You can use the Bilstein. As far as 'better' it's better than the factory shock.
Accutune would be more qualified to answer this brace of questions.
I've had my Kings on several years now without a refresh. That said I don't tow or haul more than a few hundred pounds. I've had off the self KYB adjustable shocks last 200 K. I would expect nothing less from a shock like King or Fox.
I wouldn't but that said both ends are not tuned the same so again I defer to Accutune
you can have the kings valved any way you want.....if you inform filthy or accutune or any decent suspension co even king directly and tell them what youll be using the truck for they will valve the shock accordingly and its not that expensive.....i think quoted me like $100 ea.....kings are very nice and especially if they are set up properly.....bit expensive but rebuildable, tuneable and just very plush yet still firm.....am sure fox is similar but only ridden in king setups both stock OEM kit and another custom tuned.....also i believe the kings use a linear piston but have progressive valving....
had bilsteins before and they were good but not really in same league as king and or fox.....but still pretty good and for most thats enough and cheaper....
but they can be setup stiffer for trailering if needed
Edited by Dunn
6 minutes ago, Dunn said:
you can have the kings valved any way you want.....if you inform filthy or accutune or any decent suspension co even king directly and tell them what youll be using the truck for they will valve the shock accordingly and its not that expensive.....i think quoted me like $100 ea.....kings are money and especially if they are set up properly.....bit expensive but rebuildable, tuneable and just very plush yet still firm.....am sure fox is similar but only ridden in king setups both stock OEM kit and another custom tuned.....also i believe the kings use a linear piston but have progressive valving....
The KING OEM for my 2015 do have a linear piston and are valved 12-flutter-12, a linear stack. I never changed them. If they ever need a rebuild Accutune gets the nod. I am very happy with my setup as is though.
So anyone have any feedback on the bilstein 5100s? Im intrested in these myself and was curious if the 2.5 lift on these is for at4/trailboss trucks or non at4/trailboss trucks
interesting.....i used to tune mx bikes but never touched a vehicle
but yeah the 2 vehicles i rode in with KINGs both on and offroad were better than my tundra with billys
Edited by Dunn
I have them on a High Country not a TrailBoss and they lifted 1.5in on the middle setting(I think). Anyway they are about 20% harsher ride then the stockers but the 70's Caddy front end bounce is gone and they're significantly better towing. Towed about 400 miles this past weekend over CO mountains and the control was MUCH better all around.
There are two different part numbers, one for AT4/Trailboss and one for everything else. I put them on my AT4 and the max for these is 1.1" lift up front.
Where did you get them, what is the AT4/TB part number and how much did they cost?
Thanks
    • First off pay close attention to what Newdude pasted as he is a GM tech !.    I have a couple of questions which might cross off some questions others on this forum would be wondering about as well. So when was the engine oil changed prior to this trip, was it almost brand new oil or did it already have a fair bit of use on it before you started the trip.   Did you check the oil level on flat ground and was it at the full mark just before leaving on this trip which I gather from google map is about 700 miles or so. Why I ask and this is not the first time in history that has happened, that either a dealer or some other shop changed the oil on the vehicle and the vehicle left the shop and the owner ( you ) assumed the engine oil was full but in reality the person who changed the oil simply did not put enough oil into the engine .. it happens !. Also that a shop put the wrong viscosity oil in and an engine was not happy with that thinner viscosity and oil got past the rings at a higher rate than the proper viscosity. Not to mention if there was any leaking out of a drain plug or the filter gasket etc.
    • You could, although in the end it really doesn't make much difference what comes out in exact terms since it comes down to putting enough back in so that there is enough volume so that something flows back out once the trans is up to temp for the check procedure. I presume your putting a pan on that has a drain plug but its probably the same pan mold/size as at least a while back no extra volume pan was made for the gas truck version due to the exhaust cross over pipe issue. All I can say as per volume I put back in and this was based on changing out the filter as some is trapped in it that does not come out until its removed because of the way its made inside and my truck had sat over night with the trans having been hot when shut down and dripping internally before I pulled the pan. I went off of what the trans shop suggested as a minimum volume he found worked which was 9 1/2 quarts and I had enough flow out of the stand pipe that I knew I was right on the money once it slowed to a dribble and never wasted hardly any oil but it would be totally fine to throw in a full 10 quarts too. I guess personally I wouldn't ruin a perfectly good pan by drilling a hole in it, not with the cost of replacement pans up here or the dorman one anyway with the drain was 500.00 when I priced one out a while back, totally stupid.    I might not have said before but this trans oil type really expands with heat and I think its been said on this forum and the trans shop said the same so I wanted to try and hit the lower temp of the range vs at the top or go shooting above it as that would allow more oil to flow out which wouldn't be ideal.
    • Since I am going to be replacing the pan, I am just going to drill a hole in the original to drain it so I will be able to catch the fluid easier and measure how much I took out.
