Can this be installed on a 2019 Silverado? I need to help someone tow a horse trailer but haven’t set up my truck for towing yet. The truck came with a wiring harness for trailer brake controllers. I like the OEM look.
"I know I can do it," Todd Downey said, helping himself to another ear of corn from the steaming bowl.
From other members and from what i heave read you cannot add oem trailer brake after the fact. You will be able to add an aftermarket one though.
Sent from my ONEPLUS A6013 using Tapatalk
Is there a good aftermarket TBC that will fit in the stock location? That would be much cleaner than having some box hanging down under the dash.
I wholeheartedly agree with this, this is what I had on my last truck and it looked super tacky.
As of today, no sir, nothing exists to bolt into the factory spot covered with the push in blank piece of plastic.
Box with wires is all we get. The top smaller glove box mounting location might be an option, or the rarely used top dash cubby hole.
A lot of us are in the same boat with no TBC from factory.
-Patrick-
  • 4 months later...
The blank push in cover has a harness behind it where the stock trailer brake controller goes. Can’t you just buy a stock controller and plug into that?  Why would there be the harness there if it doesn’t work?
Because what you think is a stock controller is in reality nothing more than a mechanical switch.  The brains are elsewhere in the truck and if your truck didn't come with a factory controller you don't have the brains.  An aftermarket controller is the mechanical switch and the brains all in one package.
Yea I get that. Just wondering why they would run a wire and harness to that blank box if it cannot be used?  Doesn’t that wire go to something?
Edited by Bradg
Added pic
It's there because, most likely, it's cheaper to just have one part with that connector, than to have two parts, (one with, one without), make sure the right one is installed, and to stock two parts for 5+ years.
BINGO! And it's not just the trailer wire harness that way. If your truck does not come with it. They just don't use the plug and put a blank over the hole.
Because several years ago GM decided it was cheaper to only make the minimal amount needed of parts, one area this happened in is the wiring harness. For the most part now they use 1 harness for each cab configuration for the trucks. That harness has plugs for features that vehicle doesnt have, IE the factory trailer brake controlled.
To answer your question, can you plug a TBC you buy into that plug, yes. Yes you can.
The caveat is it wont work, as said there are multiple things needed. Wiring harnesses, hardware and software. The problem you are going to run into is the software side, the programming for the TBC is not loaded into the trucks modules. It cant be added after the fact either GM addressed this on the K2xx (2014+) when the same question was brought up.
If you want the OEM TBC then buy or order a truck with it from the get go, you cant add it after the fact no matter how hard you try. I dont care what any dealership tells you, what the bosses boss tells you or what your favorite service tech or service manager tells you. The OEM TBC can not be added to the truck after the fact, GM wont allow it and has came out and said so several times now.
This is true. Tried it myself.
I’m new to the GM scene with my new Sierra. But coming from an F150, there’s a software program called ForScan that lets you turn these types of features on or off or reprogram almost any of the modules, with just an OBD reader and the free software. Does nothing like that exist for GM vehicles?
    • We live in a world where the average person expects more. People say wages and our needs are farther apart. My first new home had 3 bedrooms and one bedroom. My first car and truck had what would be considered a stripped or work vehicle. In my neighborhood back then there were more homes like that and cars too. Middle managers and second home buyers worked their way up to the fancy houses and cars. Car loans were 3 years. GM had different models of cars for different income levels. The cars were pretty much the same size if you wanted a big vehicle. The nameplate designated the opulence. Chevy, Pontiac, Buick, Oldsmobile and Cadillac.  To be fair some of the cost is government mandated. We can’t blame them for giving us what people will pay for. Careful advertising steering people towards more profitable SUVs and trucks. As I learned recently a minivan is a cheaper more efficient form of transportation. Certainly easier to live with. Somebody realized the profit margin wasn’t as big and gave it a soccer mom label. So it lost its coolness. They’re making it the masses are buying it. You hit your hand with a hammer you can’t blame the hammer.
    • Hi All, I’m In need of advice regarding a scan result on my 2023 Silverado HD.  The Sensor Supply voltage relay states ON But…. the following 3 tests show Malfunction. Sensor supply voltage relay control circuit HIGH voltage Test status- Malfunction Sensor supply voltage relay control circuit LOW voltage Test status- Malfunction Sensor supply voltage relay control circuit OPEN test status - Malfunction. No DTC codes are stored. No DIC Lights. Remote Key Fob has been giving a few issues, namely Vehicle will not respond to an Open/Lock command from the key fob. New batteries installed to FOB made no difference, plus on one occasion recently the vehicle unlocked using the Fob, the vehicle started normally via the push button, then a random warning came up on the DIC stating the Remote Key was not found, all this while the key was located next to the central cup holders. Does anyone have any input or advice regarding this scenario? TIA
    • I agree, simplicity and reliability matter more as vehicles get more complicated. A V8 work truck option with fewer electronic features and a stronger warranty would definitely appeal to a lot of buyers who use their trucks for real work. Customizing it with trusted outfitters is often the best way to get exactly what you need
    • I’ve heard similar complaints from newer vehicles where the factory “premium” systems don’t always live up to expectations. A good installer should be able to improve the sound without turning it into a bass-heavy setup. I’d look into upgrading the front speakers, adding a quality DSP amplifier, and possibly improving sound deadening first—those changes usually make a much bigger difference than just adding a subwoofer. Hopefully someone local can recommend a reputable installer in the Las Vegas/St. George area.
