I cant seem a way to figure out how to lock my keys in my AT4 without my doors auto unlocking.  I
do this in my other SUV and use the app to unlock so I cant lose my key.  I do this when I go places like amusement \ water parks so there is no chance I can lose my key and be stuck 100+ miles away.
Anyone know what setting im missing to accomplish this?
Thanks
I believe an electrostatic bag might work. You should be able to put you keys in it and lock the truck.
Anyone else have any knowledge on this?
I'm not sure on the new ones since the keys are setup as a keyless fob but on the older trucks you could go into the radio and turn off the safety lock that unlocks the door if you have the door open and hit the lock button. I think it's auto unlock or something like that in the radio.
I'm not sure how but it can be done. I will take a look at my settings. I lock the key fob in my truck all of the time. Also a point of interest, GMC has an accessory keypad (a knockoff of Ford's) that I had mounted on my door. ($250 installed at the dealer) that works great so far. You can lock or unlock the truck and therefore the tailgate without the key fob. I lock my keys in the truck all of the time and dont even need a phone to unlock.
I can lock my keys in my AT4 with my phone, sometimes the button on the door works. There is a setting to turn off the 3 horn honks that tells you you locked your keys in the car, I turned that off maybe that has an effect.
2021 GMC Sierra 2500
I need to be able to lock both key fobs inside the truck. I had a touch pad installed so I could reenter.
The electronics will not allow me to lock the fobs inside. I surmise there must be a way to disarm the auto-unlock.
How can I do this?
How can I do this?
It's on the settings section of your radio
Solution:
I had a GM touchpad lock installed at a cost of $145 plus less than 1 hour labor. Still GM support and the service manager did not know what it would do.
1. I purchased 2 "Faraday" pouches (9.95) for my fobs and hide them anywhere in the truck or the bed. The truck now does not sense their presence.
2. I can open the doors with my custom combinastion. I can lock the doors with the touchpad command.
3. The big difference is that if someone enters the truck they cannot start it because the sensor does not know if the fobs are on board or not and the potential thief doesn't know either.
4. If I have left fobs in the truck I can return from fishing or hiking and get in with combination.
No one at two dealers nor at GM support knew any of this. If there is a disable command in the radio I could not find it or it would not address an on-board fob.
10 hours ago, patischof said:
So, did you manage to accomplish this? I would also like to have this, but I don't know what I need for that. I thought I might need an electrostatic bag. Well, that didn't work. I tried to change some settings in it, still didn't work. I went to the dealer, they told me I should get a newer key that costs almost 1k!
You need the touch number pad for the exterior of the driver's door.  It's available via GM Accessories, and requires the dealership to do a computer programming for the touch pad.
Thanks
get a spare key n put it in your wallet, that's what I did
The easiest non tec way would be to wear it around your neck via a neck chain. I use to keep a spare key on my tailgate post tied to a wire. On one truck I could slide it behind the gas cap lid bracket. So these high tech trucks still have keys? If not then sentence one.
Go camping outside of cell range and accidentally close the door with the keys inside while packing up.  Regardless of the owner's manual saying it won't, it's sure-fire way for the vehicle to lock itself for some reason.  Ask me how I know.
  • Haha 2
I've had that happen too.
yeah i had that happen too, that's why i always leave a window down just enough to get my arm in to open the door.. a smart guy would go to a locksmith and get him to cnc a nonprogrammable key to hide somewhere.
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
