https://www.nhtsa.gov/recalls?nhtsaId=19V645
NHTSA Recall ID Number : 19V645
Manufacturer : General Motors LLC
Subject : Vacuum Pump May Decrease Power Brake Assist
Make Model Model Years
CADILLAC ESCALADE 2015-2017
CHEVROLET SILVERADO 1500 2014-2018
CHEVROLET SILVERADO 2500 2014-2018
CHEVROLET SILVERADO 3500 2014-2018
CHEVROLET SUBURBAN 2015-2018
CHEVROLET TAHOE 2015-2018
GMC SIERRA 1500 2014-2018
GMC SIERRA 2500 2014-2018
GMC SIERRA 3500 2014-2018
GMC YUKON 2015-2018
OK, it says they will reprogram the electronics.  Does that really fix the problem?
Thanks for posting Retired Bob
By reading through enough of the attachments, this recall is going to give you more hydraulic brake boost (not through vacuum) when the mechanical vacuum pump is struggling to keep up, but has not yet under performed enough to show a low vacuum pressure fault.
I didn't realize the system had this capability, but seems to me like they are using the ABS solenoids to increase brake boost when the mechanical vacuum pump doesn't have enough boost.
The way I read it, this recall does not directly address the cause of the failing vacuum pumps (claimed to be sludge buildup on oil inlet screen), instead it just attempts to keep the stiff pedal situation from sneaking up on drivers and causing an accident.
I think you will find people will be cleaning and rebuilding the pumps in the future. Also doing line clearing to judge the health of the pump.
I know GM will not switch over, however the electric pumps found on the Corvette seem a better option.
Maybe a little and it’s certainly wayyyyy cheaper for GM to try this than replacing pumps.  Read the last paragraph of this article.
Check out this article from USA TODAY:
GM issues recall of 3.4 million pickup trucks, SUVs to fix brake problem
https://www.usatoday.com/story/money/cars/2019/09/11/gm-recall-chevrolet-gmc-cadillac-suvs-recalled-brake-issues/2284370001/
Edited by paumat
Add USA Today link
That would explain why on Sat I had a front end alignment after I changed the front Tie Rods the service advisor told me their was a safety recall on brakes for reprogramming?  I was planning to replace the dang vacuum pump in couple months...hmmm...now it's reprogramming?  I don't know probably will change it out and get the reprogramming....LOL  It's gotten silly folks!
Scheduled my truck for the reprogram. Dealer says should take no more than an hour. (Mostly because they will also perform their multi point inspection at the same time)
So now we need an extended warranty on the ABS unit to cover premature wear from using it in normal braking?  Seems like yet another band aide to me.  That Corvette electric pump is looking better and better.
The reprogramming is the cheapest way for GM to be the 'Good Guy."  GM will have a lawsuit 'kitty' put aside when folks gets killed for brake failures and pay out from that.  This method is less expensive than doing the right thing.
It's no different than the drug companies when  they come out with a new wonder drug.  They put $500,000,000 or more aside to cover lawsuits that we see advertised by the attorneys on TV but they still make a couple billion dollars profit just the same.  This is similar to GM's solution.
Edited by Rolling Thunder
Just checked my app and saw I'm on the lucky list for affected VINs.  Taking it in for the reprogram on Tuesday, a free inspection, free tire rotation, free coffee, and other free stuff I'll wrangle from the dealer.  With my maintenance schedule I'm not overly concerned with a failure, but mostly its a good excuse for me to get that free rotation.
I had my truck in for another issue yesterday and they took care of the recall while they had it. Everything was done in less than 2 hours.
How is this reprogramming done? Wondering if it will affect aftermarket tunes for those of us that don’t have handhelds to flash back and forth.
Yes it can cause issues. Best to own a device let the dealer flash in and then read that tune and save as stock file and then compare to your custom tune and copy all changes.
Or just download this new update from gm and do it all from home. Your call.
Discount Tire does it for free [emoji6]
Looks like I'm one of the lucky ones...
Edited by Hogtiming
    tararebecca
    tararebecca
  • Who's Online   2 Members, 0 Anonymous, 484 Guests (See full list)
    • I agree, simplicity and reliability matter more as vehicles get more complicated. A V8 work truck option with fewer electronic features and a stronger warranty would definitely appeal to a lot of buyers who use their trucks for real work. Customizing it with trusted outfitters is often the best way to get exactly what you need
    • I’ve heard similar complaints from newer vehicles where the factory “premium” systems don’t always live up to expectations. A good installer should be able to improve the sound without turning it into a bass-heavy setup. I’d look into upgrading the front speakers, adding a quality DSP amplifier, and possibly improving sound deadening first—those changes usually make a much bigger difference than just adding a subwoofer. Hopefully someone local can recommend a reputable installer in the Las Vegas/St. George area.
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
