https://www.nhtsa.gov/recalls?nhtsaId=19V645
NHTSA Recall ID Number : 19V645
Manufacturer : General Motors LLC
Subject : Vacuum Pump May Decrease Power Brake Assist
Make Model Model Years
CADILLAC ESCALADE 2015-2017
CHEVROLET SILVERADO 1500 2014-2018
CHEVROLET SILVERADO 2500 2014-2018
CHEVROLET SILVERADO 3500 2014-2018
CHEVROLET SUBURBAN 2015-2018
CHEVROLET TAHOE 2015-2018
GMC SIERRA 1500 2014-2018
GMC SIERRA 2500 2014-2018
GMC SIERRA 3500 2014-2018
GMC YUKON 2015-2018
OK, it says they will reprogram the electronics.  Does that really fix the problem?
Thanks for posting Retired Bob
By reading through enough of the attachments, this recall is going to give you more hydraulic brake boost (not through vacuum) when the mechanical vacuum pump is struggling to keep up, but has not yet under performed enough to show a low vacuum pressure fault.
I didn't realize the system had this capability, but seems to me like they are using the ABS solenoids to increase brake boost when the mechanical vacuum pump doesn't have enough boost.
The way I read it, this recall does not directly address the cause of the failing vacuum pumps (claimed to be sludge buildup on oil inlet screen), instead it just attempts to keep the stiff pedal situation from sneaking up on drivers and causing an accident.
I think you will find people will be cleaning and rebuilding the pumps in the future. Also doing line clearing to judge the health of the pump.
I know GM will not switch over, however the electric pumps found on the Corvette seem a better option.
Maybe a little and it’s certainly wayyyyy cheaper for GM to try this than replacing pumps.  Read the last paragraph of this article.
Check out this article from USA TODAY:
GM issues recall of 3.4 million pickup trucks, SUVs to fix brake problem
https://www.usatoday.com/story/money/cars/2019/09/11/gm-recall-chevrolet-gmc-cadillac-suvs-recalled-brake-issues/2284370001/
Edited by paumat
Add USA Today link
That would explain why on Sat I had a front end alignment after I changed the front Tie Rods the service advisor told me their was a safety recall on brakes for reprogramming?  I was planning to replace the dang vacuum pump in couple months...hmmm...now it's reprogramming?  I don't know probably will change it out and get the reprogramming....LOL  It's gotten silly folks!
Scheduled my truck for the reprogram. Dealer says should take no more than an hour. (Mostly because they will also perform their multi point inspection at the same time)
So now we need an extended warranty on the ABS unit to cover premature wear from using it in normal braking?  Seems like yet another band aide to me.  That Corvette electric pump is looking better and better.
  • Like 3
The reprogramming is the cheapest way for GM to be the 'Good Guy."  GM will have a lawsuit 'kitty' put aside when folks gets killed for brake failures and pay out from that.  This method is less expensive than doing the right thing.
It's no different than the drug companies when  they come out with a new wonder drug.  They put $500,000,000 or more aside to cover lawsuits that we see advertised by the attorneys on TV but they still make a couple billion dollars profit just the same.  This is similar to GM's solution.
Edited by Rolling Thunder
Just checked my app and saw I'm on the lucky list for affected VINs.  Taking it in for the reprogram on Tuesday, a free inspection, free tire rotation, free coffee, and other free stuff I'll wrangle from the dealer.  With my maintenance schedule I'm not overly concerned with a failure, but mostly its a good excuse for me to get that free rotation.
I had my truck in for another issue yesterday and they took care of the recall while they had it. Everything was done in less than 2 hours.
How is this reprogramming done? Wondering if it will affect aftermarket tunes for those of us that don’t have handhelds to flash back and forth.
Yes it can cause issues. Best to own a device let the dealer flash in and then read that tune and save as stock file and then compare to your custom tune and copy all changes.
Or just download this new update from gm and do it all from home. Your call.
Discount Tire does it for free [emoji6]
Looks like I'm one of the lucky ones...
Edited by Hogtiming
    • I remember watching one of the auctions on TV. It just happened that they had two little red express trucks. My brother bought one new in 1979, still has it. So I hung on to watch them cross. The retro redone example brought more bids and went for more money than the original one did. My brother has redone his 3 times and raced it. He’s now in the process of making more tame for cruising.
    • I always upgraded the suspension and steering components - bushings and ball joints, and had older cars that I could out-corner ANY modern car with. I used to be able to take my '78 Cutlass on off-ramps at stupid speeds and make the sharp MA corners without even squealing the tires. So much fun. My '72 El Camino must've had work done by the previous owner, since that thing seemed to handle even better than the '78.   I think the suspension & steering on the '72 was much more advanced than the '64, so that probably just made a good system even better.   I'm the same way with vehicles. I hate having to worry about the paint on my '93 W250 Cummins. I'm not used to that, lol.   https://postimg.cc/mzKr55sY
    • BEAUTIFUL!! That a Cutlass F85? Or 442? My side-ID skills are lacking thanks to failing memory, lol. Love that color & year, too!   Yeah I was never big on entering my own stuff, but I always liked seeing what everyone had, the rare models, and what's been modified. That was always fun. These days I have barely enough time to do what needs to be done at home.    Oddly enough, here in MA there are more car shows than ever in history! You'd think up here it would be dead, but it's bigger than EVER!          Took the 940 for its maiden voyage with the carburetor. At first I couldn't get out of the yard! This originally had the "Bosch" system (our other 940 has Regina - single fuel pump in fuel tank, and space-age-looking ignition coil on driver's fender) - that has dual fuel pumps. One in the tank, and one under the center left of the vehicle. I had unplugged the external one thinking I wouldn't need it with the carburetor ... but the way I have the pressure regulator hooked up, 90% of the fuel volume is going back to the fuel tank, so cranked all the way down, the regulator is only supplying a hair above 3.5 PSI to the carb. Turns out the in-tank pump (15 PSI alone, instead of 45) couldn't handle the load. Plugged it back in and went for a rip. Ran great!   Throttle response is always amazing with carburetors. ZERO delay that no FI system can reproduce. Also fires up in half the crank rotations as before. Low end power was DRAMATICALLY improved. There was an ongoing lean issue with the FI that I got tired of figuring out, so this is a MASSIVE improvement! Above 50 MPH on hills it feels SUPER weak, though. This is more than likely due to the timing not being advanced enough by the computer, since it believes there are multiple failures. I can live with that through the winter. Will keep me from passing slowpokes where I shouldn't and getting speeding tickets at least. 😁
    • I like driver quality. I bought a 64 elcamino a few years ago. All original as it turned out. I didn’t know at the time. I made a low ball offer and got it. Black on black factory air 4 speed. It drove like a school bus. It had been awhile I had forgotten just how bad the old cars drove. So I planned on making it more of a retro ride. I would drive it to work sometimes. My brother liked to build cars, I liked to drive them race them. So he noticed the canister oil filter and open blow by tube. He checked the numbers. All original. 327, 250 hp close 4 speed, posi rear end. I put it on eBay made a tidy profit. I didn’t want the responsibility or headache. My wife already had a pristine collector vehicle. It lives in the climate controlled garage. I really don’t care what it is. I like to feel the sensation of speed. Let someone else have the responsibility. I’m too OCD. It used to drive me crazy. I can appreciate people who like to take the responsibility. I’m glad they do. I’ll look and remember back to those days. I’ll jump in the wife’s Genesis to get gas for her. Get my sensation of speed and be happy for awhile.
    • 2014 silverado work truck 5.3.
