On 10/8/2019 at 2:50 AM, FiatDale said:
Can’t remember what list price is, but you’ll find it for around $35-55.
Did you ever get the coax cable?
Not yet. I'm still weighing options. Thinking a non GM way may be cheaper
I haven't seen this in action yet but how does this handle headlights at night for cars?  Love the concept of having this since I always tint my windows so dark.
Edited by fightingmajor
On 10/31/2019 at 10:04 AM, FiatDale said:
Should be coming in tomorrow.
Any update? ?
Looking into doing this to my 19 LTZ.  I know original post was for SLT so was wondering if there could be any compatibility issues or reason why these parts wouldn’t work for the Chevy counterpart. Any info is greatly appreciated thanks
you should think about returning the mirror you got and going with one that has a camera AND auto-dimming.. since you already have the harness.
I can confirm that the harness you have is the same as the one on my 2018 LT (to make my auto-dim mirror work, I had to add switched power to pin 6 and your harness looks to already have it.. )
my LT Z71 came with a manual flip rear view mirror (and OnStar).
The lack of update from fiatdale has me worried the retrofit isn’t going as smoothly as we had all hoped. Hope we hear soon really want to do this mod and I’m ready to order parts just wanted some confirmation it works.
Lack of update is for not coming on the forums daily. Parts were supposed to be in a couple weeks ago, just came in today. We figured shipments would happen sooner than they did after the strike but everything is still very delayed. Plan on installing tomorrow or Thursday. Don’t worry, it will work.
  • Like 4
Good luck on the install.  Please take plenty of pics or even video and post all the parts needed.
So as an FYI, you cannot just buy the replacement light with camera, you need to buy the spoiler with the camera in order to get the complete harness. It’s a 2 piece harness on the spoiler (it doesn’t go all the way back to the mirror, you still need the coax). But if you buy just the lamp with camera, it will not plug into the coax extension to the mirror. I bought both to check it out, you need the whole spoiler to get the complete harness. ~$300. PN for black (not sure if they all come preprinted or not, but you can buy the complete spoiler assembly and remove the lamp / harness and put it in your existing spoiler so no extra painting cost is needed) is 84487008
    Greg3160
    Greg3160
  • Who's Online   3 Members, 0 Anonymous, 463 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
