Hi all,
New to the forum and to Chevy. Long time Ram owner, made the jump lol.
I bought a 2019 Silverado Custom with 4.3L. I got a rattle coming from dash area. Sounds like its in the area of were the headlight sensor is up by the windshield. Only rattles in drive at a stop. Anyone else by chance?
I have had a rattle behind the dash near the drivers door for months now when I go over 50 mph.  I have taken it to two different dealerships multiple times with no solution.  It kills me.
Check the hood release cable. Someone said something about tying it back with a zip tie to fix a rattle.
So it has gotten worse...
Only rattles in gear at a stop. No rattle in neutral or park. Apparently only when there is a "load" if you will, on the engine. Even my kids asked what that is. Sounds dead center of dash. Im hoping just something in engine bay rattling. At this point going to make appt next week at dealer.
Would you guys be ok if they had to tear your dash apart?????
So the ductwork behind the dash is probably rattling against the tie bar that goes the width of the dash. That’s exactly what mine was, little butyl between it and it’s solved. Like I mentioned, you need to remove e cluster for access but it’s not difficult. PM me if you need help
I have a rattle around the A post area when I get to 40mph.sounds like door but could be the dash.could you tell me the area you mean when you say cluster?
Cluster = speedometer. It’s behind that area, I can almost guarantee it. The rattle sounds like door/ a pillar / dash, but it’s that ductwork behind it. It has such slight clearance between itself and the metal tie bar that spans the width of the dash. When it’s warm, it flexes and bounces on top of that tie bar.
I think I have that LH AC duct rattle.  Also found sometimes moving the steering wheel rake up and down has quieted a buzz I had under load on the highway
Thanks for info. The noise has seemed to stop the last 300 miles.if it returns which I'm sure it will I will look at this area. Thanks again.
Just to update everyone:
Took truck to dealer. There was a gm bulletin out about dash rattle. Turns out I had the same problem.
Issue was engine harness above transmission was rubbing on floorpan. They adjusted the harness, so far no more rattle!
Do you have pictures of the area
Thank you!
Also having the rattle in my at4. Seems like if I pull back towards me on the center dash storage tray it seems to go away. Does this sou d like the rattle of the ducting on the bar?
These forums are your best chance at finding a solution to any rattle complaints. I have owned newer under warranty gm trucks now since the mid 90's i can tell you for fact most times a dealer will not solve rattle issues and they just hope to keep pushing you along until your past the 3 year or 36k mark which is when they are completely not obligated to fix interior rattles without charging you.
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
    • It wouldn’t have happened if the government hadn’t mandated outrageous fuel mileage standards. It does very little for the consumer. It adds cost. Back during Covid there was a chip shortage. They gave a rebate for your truck if it didn’t have the chip to turn on cylinder deactivation. It was 50$ because at best you may see 1/2 a mile increase per gallon. Splitting hairs each fuel mileage trick wasn’t mandated. The government doesn’t do the engineering work and say use this until it’s already in use and they like it. The fuel mileage was mandated. And those add ons the results. There’s a mandate and they are the results.
