2015 Silverado 1500 Brake Stuttering
rag0
Hey folks,
I’m pretty new to the forum, so please excuse this if it’s already been mentioned.
I’m a newish driver and new truck owner, my Silverado is actually my first car. My grandfather used to be a mechanic so he’s been teaching me things here and there, but he’s stumped on this and even after all the reading I’ve done, so am I.
Since the day I bought my truck, about 6 months ago to be exact, I’ve felt this bounce within my brake pedal when stopping, typically from 30MPH and up. At times it can be so bad it will throw me forward.  My steering wheel doesn’t shake, nor do I feel any stuttering anywhere other than my brake pedal. It doesn’t happen all the time, and at times it’s MUCH worse than others. I do notice it is more likely to happen if my tires are hot or it’s extremely humid outside.
I don’t think my rotors are warped nor do I think my brake pads are thin as I can stop completely smooth at times. I tested it by going from 56mph and quickly hard braking while on pavement and coceana, and I didn’t have a problem (because I had only been driving 10 minutes and my tires were still cold I assume).
I’m pretty stumped, hopefully one of you guys will know? Thanks in advance.
Edit: truck is a 2015 Silverado 1500 LTZ Z71 V8 5.3L with 149k miles and is a Canadian model
4 hours ago, davester said:
could it be the abs system activating for some reason?
I’m not sure. I feel like it wouldn’t cause as severe as a bounce as it does, which is why I was concerned. Like I said, it will quite literally throw me forward at times. I’m gonna try and find a mechanic open this weekend and see about having my brake pads replaced and possibly if my shocks are shot, just as a safety measure. If there’s nothing wrong then it probably is just my ABS but it’s a lot , lot harsher than any other truck or SUV with ABS that I’ve driven, and my grandfather agreed with that.
A bounce in your brake pedal, and only the brake pedal is also throwing you forward?
Any sensation other than smooth in the brake pedal means that the rotors are warped. I would start with that. How old are the brake pads and rotors? If they are original, get some new ones, at the very least for the front brakes.
Now for the forward throw...
Does the Canadian model come with square wheels?
https://media.giphy.com/media/l2SqgF7dto3rI7Hqw/giphy.gif
Sent from my SAMSUNG-SM-J727A using Tapatalk
My truck used to pulse the pedal and vibrate when braking. I changed the pads and rotors and it has been gone. My truck had 42k miles when I got it and it had the vibration. It's now at 110k miles and no vibs since the change in pads and rotors.
    • Ahh, sorry about that - I got some bad info. Newdude is correct. That's what I get for working 13 hours straight ... on my "vacation", lol.   Should've checked the files I had instead of the internet.   Anyway ... this is GREAT news, since this would've been an absolute friggin nightmare to get working.   I don't think the lack of VVT is causing this - you've got another issue. Wiring, I'm betting.   I'm telling you right now, your computer isn't bad. If it worked before the swap, it's working now. You need to do some more (better) diagnostics and figure out exactly what you're missing. Did you test every wire directly at the MAF? Have 5V reference? Ground? If you're reading ZERO g/s, your Hz isn't much use - it's going to be the wrong value anyway. The MAF is not working, and you need to find out WHY.   I got this off the net, so VERIFY first: Pin A: Black (BLK) wire, Circuit 552, serves as the Sensor Return (Ground).  Pin B: Tan (TAN) wire, Circuit 472, carries the Intake Air Temperature (IAT) signal.  Pin C: Yellow (YEL) wire, Circuit 492, is the primary MAF Sensor Signal output to the PCM. Pin D: Pink (PNK) wire, Circuit 339 or 539, provides Ignition 1 Voltage (Power).  Pin E: Tan/Black wire, Circuit 552 or similar, often associated with the Intake Air Temperature ground or signal return.  Global-A list: https://postimg.cc/KKJnQC85
    • Correct....the end user can't reach to Realtruck directly like they can if they purchase a Bak, Undercover, etc...  It has to go through a dealer.
    • It is 4wd. shop told me it is the slip yoke. But not sure.
    • No, I did not tune out vvt. From what I read it should still be able to run without it, it'll just lose some torque/power.    I can see how that would make it not run correctly, but why would that cause the faulty MAF readings?   EDIT: I just ran a quick test and checked, and as I expected, the computer sees that the VVT cam phaser solenoid is not present, and throws a code for it, and does not try to change the cam angle at all. Commanded position just remains at zero, 100% of the time. This makes me think that the VVT is most likely not the cause of the problem though if anyone has a different/better explanation, I'm all ears.   UPDATE: I was able to find that my scan tool does indeed support reading the frequency (hz) off of the MAF (I thought it wasn't supported but turns out I just didn't know where to look for it). I noticed that regardless of engine state it always however this Is not what I observed with my multimeter. Like I said before, the MAF seems to put out a normal signal during cranking and then the signal drops to a very erratic reading once the engine is running. It seems from what my scan tool is telling me that the ECM is not recognizing this at all, and just reads 0 Hz 100% of the time. This pushes me towards the the PCM itself is faulty. I I have the PCM out of the 2007 donor vehicle, which I may try to connect and program (it's only ~50 bucks to get the software for a one-time programming)
    • Did you tune out the VVT?  07-09 they did not have VVT.  2010-2013 they did.      If you haven't tuned it, its trying to adjust cam timing.
