Due to the near invisibility of dirt and the sheer sickness (if that word is still being used today) of the Satin Steel Metallic color on the 2019+ Silverados.. let’s see em!
7 hours ago, maka1500 said:
808: what kind of wheels? ??
24x10 +31 reps from a tahoe I believe. Added 10mm hubcentric + wheelcentric spacers and they sit flush with the fender.
Looks good clean!
did some searching because im interested and these are actually Cadillac replicas FR 72 +30  (at least that's what they say on audiocityusa lol.)
what size tires?
any rubbing issues?
1 hour ago, maka1500 said:
Looks good clean!
what size tires?
any rubbing issues?
yea ur right, there escalade reps. 295/40 Atturo tires, no rubbing at all. If ur local to Honolulu, I may be selling them to buy a drop kit.
Edited by 808 HI
They actually cross the SUV platforms.  My wife's 2019 Denali XL has them OEM in 22".
    • I went another direction after losing a trailer tire, thanks to not being able to access air at ANY of the 5 gas stations and garages I stopped at prior, with a Toyota Tacoma onboard, 50 miles from the Canadian border. They were either out of order, access was blocked, or the hose a few feet too short and I couldn't get any closer without risking damage to someone's property.   https://postimg.cc/gallery/X5QJ55w
    • I took a 12 second video on my iphone but the file is too big to upload. I will have to figure out how to extract the audio or just do another start with an audio recording.
