z1boss probably takes the cake in this forum. He got a week one T1 build (July 2018), and has done some work with it.
Edited by econometrics
Well, I've certainly put more miles on my truck than I thought I would at this point and time.
( purchased june29 19 build date march 30 19 )
I'm right at 7k miles. Lol, I just cant stay out of it, truth be told.
* edit, I will say this however; for trips that are maybe an hour long, I do wish the seats were as comfy my 07 classic. BUT.....for long trips, the seats are outstanding.....if that makes any sense at all lol.
Edited by MacLaren
Additional Info
  • 7 months later...
This is the newest one of these I could find so I'm bumping. I don't drive enough to be a good statistic.
Is that a good price for a truck with almost 80 K miles?
I wouldn't pay that.
14k miles and zero issues
2019 6.2 AT4
knocks on wood now
2 hours ago, Mikedfw said:
I've got 24k miles on my 19 sierra, tons of problems unfortunately.
What kind of problems? Curious.
7 hours ago, tinbad said:
I'm pretty sure that's a typo. According to the Autocheck report it had 11,000 miles in February of this year. Probably 13,700 miles is the actual odometer reading.
https://www.redhoagland.com/autoCheckReport.do?vin=3GCUYGED8KG168725&cs:rv=42902CCA22CB618DFCDE37F8B3E707FA
I have a 2019 with 3,700 miles. Two trips to dealership already, leaky back window and transmission issue. Rear window was fixed and the transmission still has the annoying thud which I'm used to. I bought it in April 2019, but I don't use it at the ranch anymore due to tricky rear shocks that gets it fishtailing out of control on certain ripples. I had two Ford F-150's before that, both were trouble-free and both were driven at least 30,000 miles. I usually hit 45 to 55 mph on that road with the 2016 F-150 and co-worker's 2019 RAM, cannot drive above 30 with the Silverado. I thought about replacing shocks but I decided to replace the whole thing instead.
