DEX-COOL or not?
I haven’t seen a dexcool problem in 15 years.
I used to change intake gaskets daily because of this stuff on the 3.4’s...usually at 40,000 miles...then again at 80,000 miles.
  • Replies 31
Millions and millions of vehicles on the road successfully using DexCool for the past 25 yrs. It is an excellent product. Like anything, it can be misused and misrepresented and blamed for things that are not it's fault. The world is a better place because of DexCool.
6 hours ago, beetle said:
Yep, old myths die hard, just like back pressure is needed for an exhaust system.
Is one of those myths "Crossing the Streams?"  In this case, mixing the colors of coolant.
I was informed that you can NOT mix DexCool and the standard 'green' coolant/anti-freeze.
You can, but don't want to leave it in there forever.
You’re not supposed to, I’ve heard the same exact thing from a very seasoned mechanic, different chemical compositions for different metal alloys. What’s the big deal anyway, just have it drained or do it yourself and fill with DexCool.
Sent from Above
So essentially if you do run low on coolant and don't have the same type, put water in there instead then have everything flushed out once you repair the issue causing coolant loss.
Distilled water would be better, no mineral buildup, this way you don’t have to flush it, unless needed to and just add concentrated GM DexCool when you can.
Sent from Above
distilled water can have an acidic Ph so you should get a  cheap acid test strip and refractometer from chem lab..these are cheap tools to maintain coolant quality.
Simply mixing Dexcool and plain green does nothing. It presumably takes heat and pressure of the cooling system to have any effect. Some years ago as a curiosity experiment, I mixed a jar of half Dexcool and half green and set it on the work bench for a year, and nothing happened. It was still a water-like consistency.
It must take a mixture of pressure, heat and oxygen because believe me, you put that stuff in a car and drive with it mixed for a couple weeks??  Cake batter.
Used to run it in the Vortec's. It (or something in it) would seemingly eat away a white metal fitting on top of the 350's and you would have to change them every few years, did 2 water pumps on that truck too. Stopped using Dexcool after replacing that fitting on my 98. No noticeable difference in cooling performance switching to a generic green antifreeze. If your truck is under warranty, put the recommended coolant in it. You can put anything in these to get you home though. Last rad hose I blew was on one of the class 8's in the middle of no where, get a jug of puddle water from the ditch and filter it through a rag, keep the rad cap off. You'll get home.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
    • I'm glad you have 14,000 trouble free miles. Frankly though, that's a really low bar. A bare minimum of 80,000 trouble free miles as the norm (rare exceptions always exist) across the whole model year should be a starting point. Good maintenance habits should push these past the 100,000 mile mark with only the most minor of issues. Let's hope GM truly leveled up the quality game with these new engines and exploding engines under 50,000 miles are gone.
    • This is exactly the reason our EV has consumed so much of my driving. I don't want to fire up a cold diesel or gas engine just to drive 2 miles up to the store. It's arguably terrible for an engine. If I'm not driving at least 10 miles and don't need to do truck things, the truck stays parked.   Enter the EV. It's immediately heating or cooling the cabin as needed (heat pump). An engine doesn't need to warm up or be driven gently. I can tear off in it with ZERO guilt. Move the car 1/4 mile from store to store and not think "gee, I'm short-cycling a lukewarm engine".   It doesn't idle in a drive-through. Doesn't idle at stop lights. (OK, neither would the diesel, if I let stop-start have its way, but I don't).   Even moving it out of the garage to wash it... HA! It doesn't need to be started just to move 40 feet. I have cars that I will actually put in neutral and push (no start) in/out of the garage or shop if they absolutely HAVE to be moved. My nice Camaros.
    • Some trailer plugs don't work. This one worked for me. Been using it for two years no issues. Amazon.com: Reese Trailer Plug Adapter, 7-Way Male Plug to 7-Way Female Plug, LED Lamp Out By-Pass, Plastic, Black, Each : Automotive
