2020 LT Trail Boss 5.3L with the 10 speed crew cab 4x4
So trucks got about 1300 miles on it now. Im starting to notice a low rpm rumble/ vibration/ stutter? So i noticed it especially from a stop light. 1st and 2nd gear when im at really low rpms (think gently accelerating off the line). I can feel it in the steering wheel and in the seat. Like the only way i can describe it is it feels like im diving over tiny bumps. I wish i could describe this better but my buddy noticed it too this weekend. I also have the same exact feeling on the highway at low rpm when cruising. With this one i can almost reproduce it. If i speed up and slow down to a point where its ready to down shift but i give it slight gas i feel the vibration/ shutter/ rumble and definitely felt it in steering wheel. I know this is probably worlds worst description but best i can do. but once it happens you cant ignore it. The first time it did it i felt like the truck was stuttering to go but it wasnt.
I thought maybe this was a characteristic of the 10 speed with a big motor but not sure.
The obvious would be tires. they are new AT, balanced, and properly inflated.
Gonna take it in to get looked at next week maybe after my trip. But i wanna know if anyone else had this happen.
Vibration under light acceleration like that almost sounds like a bad u-joint, but the vibration at cruising speed sounds like torque converter shutter too.  I'm interested to know what IF anything they find when you take it in.
Imma be outta town till next week but imma get it in to look at.
Yeah low rpm especially second gear its bad. Drove it this morning to keep it in that low rpm range and yeah felt like a big stuttering shake
Check under the leaf springs and see if your truck has pinion shims. I’m chasing a similar issue - and the loaners I’ve driven without shims seem to drive better. I’m going to pull mine out at some point this week.
I cant drop my truck off till the 24th unfortunately.
Can you explain what these pinion shims are? Maybe provide a pic? Im back from vaca soon and will check it out
2020 LT Trailboss w/ the 10spd -  I also am experiencing this same shutter...mine seems to be more noticeable when the truck is cruising at 20-40mph and only when the accelerator is applied. I have 6400 miles on my truck and will be curios if it gets worse. I previously had a 2016 with the infamous "chevy shake" and I HOPE this isn't something similar in the. making with this new truck. I will be following along to see what your dealer says. Keep us posted. Thanks!
It’ could be due to the cylinder deactivation system. However something sounds wrong in your situation.
Are all these trucks equipped with that? My 2015 was and showed me when i was im v4 mode. But this one doesn't say
Yes they do. read my new post in this section.
Just upgraded from my 2015 5.3/6 to a 2020 6.2/10.  The 2015 had AFM and it was quite noticeable when  in v4 mode and going from v4-v8, especilly when driving round at slow speeds, around town etc.  I solved it by putting the shifter in M5 unless I was out on the highway doing 70+mph. So far on the 2020 I really cannot tell when DFM does it's thing. Any change is  negligible. But this can also be solved by putting the shifter Ln and selecting a top gear range. In town where the top speed limit is 35mph, L7 is more than adequate. This also disables the start/stop crap.
Does it do it in 4wd also? Sounds like you are describing chatter. There is a software update available for the 10 speed that may help.
Im not sure. I dont ever put it in 4wd on the road sinces its dry and summer
Where did you read there was a software update?
This is the bulletin below that I found on another thread. A few people reported that it didn’t show up on the gm recall site for their vin but once they went to the dealer it came up.
    • Did you ever find a resolution to this? my 2019 Silverado 1500 is showing the exact same headlights issues with the exact same symptoms.  would help a ton if anyone has any advice on this or better yet a known solution..
    • tl; dr I've now reached the 6th floor of hell. I'm chronicling my journey for my morning readers.   Pulling the top of the intake apart was moderately easy but it involved a lot of parts, connections, and minutae. I was preparing for the new fuel lines to arrive ("nut and bolt kit" it's called). The fuel line connections are notched and held in place by the manifold and a metal plate with a T27 screw.   It's on the back of the intake, under the firewall, with little clearance, and two hard metal fuel lines in the way. I was using Franken-tools (weird combinations of 1/4 inch ratchet with/without an extension, with a bit holder for my T27) to get in there. One of my sockets and bits fell off and has yet to emerge on the floor. I lost a second setup and that's when I almost started throwing tools. But that was the point at which I had gotten traction on the Torx head, and it promptly stripped. No more traction.   I started humming "1-877-kars-4-kids" because I was about at that point. You know what? I'm $1500 into this thing and I can make it disappear just as quickly. This isn't fun anymore. I had spent a lot of time already "tidying" around the engine bay: Fixing all the "someone's been here before!" BS. The truck has been exclusively dealer- and shop- serviced and I'm reminded of why I never let other people work on my cars unless absolutely necessary.   Speaking of dealer service. This truck has a 1" stack of records going back to 1995. I put them all in an excel spreadsheet, date/mileage/description.   The CPI spider has been replaced 4 times in 85k miles. The EGR? Another 4. Multiple, multiple O2 sensors. One Cat. 4? Sets of plugs and wires, and I swear half the stack is diagnosis paperwork for "misfire, runs rough, extended crank, dies at stoplights".   GM was producing some proper crap back then. And it was still well within the era of brittle/crappy plastic. (Windows 95 was released the same month this truck was sold new, we HAD the technology!!)   There (was) a plastic shroud around the evaporator core and HVAC fan in the engine bay. I noticed a chunk of it missing so I poked at it some more and it literally shattered. Touched it some more and pieces were crumbling off. Had a good laugh. Clearly whatever plastic garbage they were using had broken down over 30 years and was literally turning to dust. That was a good half hour of using a shop vac to remove the rest of it.   Back to it.   I was going to give up for the evening but then decided I'm already level 10 pissed off at the stripped screw: G* D* it, give me my tools back -- and my JOY. We'll do this the hard way: The whole intake is coming off.   Blazer won Round II. After finally finding and accessing the 12 intake bolts and using a pry bar to unseat it from the heads, it popped loose in an explosion of gunk and grime raining down into open ports. Awesome.   6 times I reminded myself: Be careful of the temperature sender on the front of the intake.   YEAH, I forgot again and snapped it clean off in the removal. Add another $20 to the ever-growing list of new parts this thing is consuming.   The shame is, long before removing the intake, I had changed the oil in prep for Tuesday's momentous fuel line replacement that was going to be the magic fix and I'd have a running Blazer to tool around in this next weekend. The intake removal, including raining gunk, also gushed dirty coolant all over the valley. Of course it did. Welp, there goes another $35.   I now need an intake gasket set, bolt set, coolant temp sensor, another 5 quarts of oil, some RTV. Don't worry, I've already got 3 new jugs of Dexcool and a thermostat waiting. I'll fill it with clean water first to get it running, dump it, and then add the Dex later on in case... well, let's not go there. I'm only tearing this down once, next time the truck is going on Marketplace for FREE.   Oh, and I'm going to need vacuum hose for all the stupid connections placed at the rear of the engine which have since disintegrated. Come on, GM....tell me you don't do that anymore?   Oh, and the ears on the distributor where the cap screws down are both cracked. I mean, why not put a new distributor in it too. You get a distributor, YOU get a distributor, Everyone gets a new distributor!   This truck isn't out of the woods yet...I'm already questioning how much more time I'm willing to sink in.
    • That's interesting.   There was a factory wire-hole in the back, top of the rear cab, which had a wire for the third brakelight assembly running through it, as well as several holes (10 of them I believe) for all of the studs coming off of the 3rd brakelight assembly itself.   I sealed all of those holes with RTV/silicone as well.   I found it kind of odd, that none of those holes, were sealed with any kind of sealant by the factory - if there was any there, it wasn't very much.   That said, I've been out in heavy rain and have ran the truck through high-pressure car-washes a few times now and she has been 100% water-tight to this point.   I feel very confident in the repair, we'll see how it holds up.
