Hi everyone!
just hopped into my first GMC Sierra 2020. Traded in my 2017 Tacoma which went 80,000km without an issue. 2-days in now and I’ve got an engine light, and clear water leaking from underneath the truck. It’s leaking from the joint with the two tubes which I’ve attached a picture of. Any thoughts on what this is?? I’ll be calling the dealership but just want to see if this is common?
also... anyone else notice the poor undercoat? Used my thumb to rub the undercoat right off to steel...
Edited by Jbrockltd
First, the water is condensation from the AC. Even Toyotas do it. Everything is fine.
Second, that's not a poor undercoat. It's a wax undercoat. GM offers to use wax on the frame to resist rust because they believe it is better than what everybody uses, and it's self-healing. Give it a little bit of time and that spot where you rubbed your finger on it should smooth out and recover the frame.
And for the CEL, welcome to the world of GM and poor software programming and the total inability to deliver OTA fixes (Sadly - like most OEM's).  GM lives by the motto - "If no one complains, it works just fine"
Chances are, you'll have several software updates needing to be applied to your vehicle.  Visit the dealer.
Edited by steve841
LOL love the self healing part.  Umm no it doesnt thats where the rust starts. Nothings better then a fully primed sealed and painted frame like RAM and Ford and Toyota use.
19 hours ago, Jbrockltd said:
Hi everyone!
Bad gasket if thats where its coming from.  Just good ol GM... more problems to come.
10 hours ago, steve841 said:
GM lives by the motto - "If no one complains, it works just fine" "it's not a bug, it's a feature." lol
Can't help but agree to some extent. All of those with painted frames seem to stay cleaner, for longer than the GM twins; at least around here in MN.
So essentially the frame undercoat isn’t something the dealership will remedy... and I’m assuming best for me to undercoat it myself? Haha
yes, It took me about 40 hours to clean my frame and then prime paint it myself.
Well that’s exciting! Too many pros & cons with full size trucks it’s ridiculous. At $60k plus you’d think they would make em a bit better... hopefully I don’t regret not getting a Ford ?‍♂️ They seemed to have there fair share of problems as well...
Or you coulda stayed with Toyota, i just picked up a new Tundra
Well you are better off than in a Ford, that's for sure.  But what kept you from going to a Tundra?  Just curious.
1) Yet, the fully primed, sealed, and painted frames are rusting.
2) I did point out that's what GM is saying. Those aren't my words. The product GM uses is called Nox-Rust. GM also has a TSB on treating rusty frames.
https://www.google.com/url?sa=t&source=web&rct=j&url=https://static.nhtsa.gov/odi/tsbs/2019/MC-10154649-9999.pdf&ved=2ahUKEwiPtpiN77frAhVIQq0KHUI0BcoQFjALegQIAhAB&usg=AOvVaw0r4K_YpNNsZLqu9ln1KW8L
On a much slower pace.  And it doesn't matter what gm calls it it doesn't heal itself I worked for gm and never seen it
Again, not my claim. It's GM's. However, I'm not seeing anybody provide supporting evidence, such as numbers. It's only anecdotal claims. Here's a counterclaim, but unfortunately no numbers are provided either.
https://chevroletforum.com/articles/is-wax-frame-coating-the-secret-to-success-for-chevy-trucks/
I wasn’t able to test drive a tundra this year but just felt like there should be more motor options. Fuel economy was better on the GMC, and overall just get like more of a truck. Looks a lot better in my opinion too. Which was hard to accept since I love Toyota... just felt like there wasn’t any great options leaving the Tacoma. See the Sierra everywhere, use gmc vans for plumbing and they typically last 300,000+.
    • Because single shot injectors are ancient and multi hole injectors provide smoother running engines and sharper throttle response due to the fuel being atomized better..the best lead I have is a 24lb blue top injector almost everything matches up but the injector will put out about 26lb/hr which is just outside the gm threshold.figured id ask here to see if there was an absolute answer
    • Why is my question?   Any change in injectors requires a tune. Unless you are going back with the OEM part number or a newer part number of that same injector.   Any size difference or type difference like the EV6 style injectors all have different injector data for them. And there is no EV6 injector that matches the factory 25 lb/hr size that your truck comes with. I've been messing with these trucks and tuning them for a long time and what you trying to do doesn't exactly make sense to me.
    • My 6.6 gas lt8 had lifter noise with 28000 miles bought new 2026 and while driven to dealer it threw #1 rod bearing “HD my ass” good luck with yours i hope it don’t turn a rod bearing!
    • When a condition becomes a business model.    https://www.gm-trucks.com/gm-truck-suv-incentives-pricing-2026/   Zane posted this in "Latest Articles".    The honest bottom line   Truck buyers have spent three years assuming this is a temporary condition that will break once inventories normalize. GM just presented it to investors as a durable strategy, on a chart, as evidence of good management.   Inventory did normalize. GM is at 511,000 units and squarely inside its own 50 to 60 day target. The discounts still did not come back, because the low incentive number is the goal rather than a symptom of shortage.   Plan your purchase around that reality instead of waiting for it to change. Follow our ongoing GM News coverage for pricing and incentive changes as the next-generation trucks land.
    • Thought it was raining this morning when we woke. Nope. Dew point was over 80 F and humidity 98%. Zero visibility distance. Everything was 'sweating'. I've seen rain come out of clouds but never out of Pepper or the tree trunks.    Wicked storms just missed us sliding off to the east but by blocks. Heat index about 110 F with air temp in the 90's.    This is  our third wave this month of multiple days of this type of weather. And yet the grass is going dormant and the ground is cracking this side of the street and water up the the hood opposite. Just weird stuff going on.
