This sort of thing happens all the time when people hear what they don't want to hear.
Ya know, like your broker calls and says he's lost all your money.
NO!
That can't be true!!
I don't want to hear that!
Your fired.
(to late)
:lol:
What we have here is a grumpy old bear saying, "He's going to loose all  your money" and a third party saying .....
Physics isn't an opinion and the laws of physics are not theory and....they are not mine,
but hey, he is right about the last part and I thank him for making my point for me.
It isn't what he want's to hear no matter how true it is.
So sad....:sigh:
It's a hard way to learn.
It’s kinda like when we were young and naive. I do think they’re neat to look at. Maybe I should buy one, custom build a clear polymer enforced glass hood and then I’ll be happy with it?
It’s pretty though....
Sure is. I use to have these on my tuner Honda's. Injen I believe. Colorful, shinny. Looked good under the hood with the custom ignition and fuel rail 'up grades' and polished tower brace. Added custom tunable cam gear, header...yada yada yada. Chrome, polished alloys..yum..... :)
The only things that actually worked was the short throw shifter and the Red Line MTL which totally transformed the way the box came in and out of 1st gear. And the KYB gas double adjustable shocks/struts.
The ignition system failed as fast as you could swap control boxes. Pretty hard to improve on a Honda ignition. Cam gear did zip anywhere but the dyno room. The header was a total waste of money. A Honda stainless exhaust is 'forever' Header not so much.
Edited by Grumpy Bear
Wow both guys that have modified their trucks for their own taste are chastising people for doing the same. I’ve had several factory hot rods of late that had factory aftermarket looking CALs on them. I agree they don’t add too much today like they use to. But they do add sound. And makes the owner happy. Much like lifting and lowering and buying different rims. Some guy showed his results before and after. Motor Week even showed fuel mileage gains, plus performance gains on one their shows. Even a advertiser on this site has shown gains. So being skeptical is one thing, belittling someone is another.
  • Like 3
  • Thanks 2
  • Haha 1
Posted by Grump Bear “This sort of thing happens all the time when people hear what they don't want to hear.“
Wow!  If this isn’t the most hypocritical thing posted. OntheReel gave us all real life numerical data showing his improvements and this older cynical man makes this comment?  Unreal. Just shows how closed minded some people are.
? yeah I think his quote should more accurately read:
"This sort of thing happens all the time when people hear what they don't want to hear... of course, I exempt myself from this very statement. And should you question my exemption, I'll sidetrack this thread so hard and fast it will make your neck snap."
  • Haha 3
Grumpy does have a point, no one wants to admit anything wrong with what they’ve done especially cause they’re costly add ons that may or may not add horsepower but hey, they make a sound and look cool under the hood.
Although I didn’t buy a truck to race it, you guys think that I’ll definitely get some additional horsepower and torque by adding one, especially being that I’ve got a performance tune on?
Maybe, I should have my engine cleaned before I install one, wouldn’t want to clash under the hood.
I’ve also seen posted on a few threads that some people are swapping out the 5.3 throttle body to a 6.2 throttle body prior to installing a CAI, specific to the new throttle body.
Just circling back after yesterday...
After installing my fuel line magnets last night, I'm happy to report that I got to work 2 minutes earlier today!  Real-world numbers, boys!  That's some science!  Straighten out those fuel molecules and you can see the benefits, too!
  • Thanks 1
Glad those worked for you.  Some people will install the magnets backwards, then just throw them away when they get no benefits...
On 9/16/2020 at 10:28 AM, Ed/2020RST said:
I am not a person to throw money away so I have been doing my research on which CAI system to install on my 2020 Silverado RST (5.3) or if I should put one on at all.
IMHO...No.
All this arguing... Just run your cold air kit of choice, but be sure to install a 2 port catch can and switch to Oreilly brand 10w30 conventional oil and a Fram filter. Did I miss anything?
  • Haha 2
An engine is basically an air pump. The more air you can get in and out of it, the more power you are going to make. This is why heads are ported and polished. Intake manifolds are port matched to the intake runners and headers are matched to the exhaust ports. Is it really necessary to have a 5 angle vs. a 3 angle valve job. If you want the most hp you will get the 5 angle. It will smooth and flow more air around the valve and the valve seat creating hp. Its all about increasing and smoothing the air flow through the engine.
Why do high performance vehicles use mandrel bent exhaust tubing instead of crush bent tubing? Because it flows more air more smoothly. Just like a cold air intake will flow more air, more smoothly than the factory intake. The factory intake has a restrictive filter, the accordion style adapter, and the huge silencer. These all create turbulence in the air flow which slows it down and causes a reduction in air flowing into the engine (a loss in hp.)
Although each one of these mods mentioned may only give you a small increase in air flow and hp. They all add up to make a noticeable difference.
Edited by Firehawk T/A
All of this post is rock solid. Especially this last part quoted above.
Here's the part that gets lost.
All the air enhancement in the world only shows at.......
WOT
The throttle body is located AFTER the air box so any possible flow increase happens AFTER the blade is open far enough and the rpm high enough to exceed the capability of the original configuration. Actually that would be true if the blade were before it as well.
If the OEM is capable of 325 hp then the increase, if any, isn't being used until the demand on the motor exceeds this number.
When you see that increase in torque 1500 rpm below peak power that number is still being generated at WOT.
When might happen? Towing a steep grade with a load heavy enough to demand WOT in the lowest gear it will hold at the speed being traveled. (Ya need more truck) Drag racing (at the track). Passing in a situation where you shouldn't be (You need better judgement). On the dyno. At Bonneville or Murdock. (All of which are fun)
Give that list a look and ask yourself what percentage of the time you are driving is spent in anyone of those situations.
Got my cold air intake from CAI installed today. Had a bit of a problem with getting the stock PCV valve off until I realized you have to push the little gray tab in, then pull. Took her out as soon as I finished (about 30 min) and immediately noticed an awesome sounding note coming from the engine bay when I gave it some gas. Normal driving I didn't notice anything. But taking her onto the interstate and giving her some gas was pretty awesome!
More info here: https://www.coldairinductions.com/shop/cold-air-inductions-products/cold-air-intakes/chevrolet/silverado/2019-2020-silverado-and-sierra-1500-5-3l-truck-cold-air-intake-textured-black-512-0105-b/
They claim an average 12HP at the rear wheels and increased fuel economy. Although I have no way or desire to test this, I'm definitely pleased with my purchase!
  • Like 3
This is a good read. https://www.hpacademy.com/technical-articles/air-intake-restrictions-explained/  Ultimately any restriction to incoming air in an engine will result in reduced volumetric efficiency. For example a dirty air filter at any rpm range will reduce how efficent the engine is at filling each cylinder with air. The same is true for a cold air intake that is designed to flow better than the stock air box. At any given rpm it will be more efficient at filling the cylinders with air, thus creating more power.
On any vehicle I have installed a cold air intake on, I have personally noticed that I need less throttle pressure to accelerate up to speed, along with a slight increase in fuel mileage. I highly doubt I will ever recoup the investment in fuel costs, but I don't really care. I like the way it looks, sounds and feels while driving it, and thats enough for me.
  • Like 5
    ncleg
    ncleg
  • Who's Online   3 Members, 0 Anonymous, 1,285 Guests (See full list)
    • Your tire pressure issue may just be batteries, you can reset them using tge Ing switch (I think) and the owner's  manual. ChatGTP will b e a faster, better help than Google.
    • The thinking is that starting out in a higher gear makes it easier to avoid applying excessive torque when pressing the gas pedal. In a modern 4wd truck with 4 low and a limited slip or locking rear end, I would use 4 low and try to crawl up the ramp. Sometimes if they are too slippery, you have to back up to let the boat have some bouyancy, and then accelerate briskly to get some momentum to help you pull the through the slippery parts.
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • The recall is for exactly this issue - those drain holes combined with the limited environmental capability of the tailgate electronics card inside the tailgate were a problem. The “safety issue” was the potential for the tailgate to spontaneously open, but all kinds of tailgate misbehavior can occur from water contamination of that control card.    There is no real fix yet. The initial recall just disabled the tailgate. Later, when parts became available, they would replace bad parts with new parts of the same bad design. My dealer is going nuts because the few times I let them get their hands on my truck, my tailgate is off due to a slide-in camper installation. They really want to cut my tailgate wires, but I won’t give them the chance. I will let them get their dirty hands on it when a real fix (redesign) is available.  My tailgate, which works just fine with sealant plugging the drain holes, will remain safe in a dry storage crate until then.
