  • 10 months later...
Year later, still nothing.
Thing is don’t even think they need to crack the ecm or be able to flash it to make hp/tq changes. They could go old school like the old edge piggy back systems with sensor foolers and such.
no way id use that gizmo tuning thingy, if its not hp tuners or equivilent . really from my understanding its encrypted pcm like the c8 vette. my personal dyno tuner guy says its gunna take a serious amount of time and effort for some one to do it. and he tunes 300 to 4000+ hp cars all the time for a living. so until somebody (cracks it open) its going to be damn near impossible. really sucks too, cause id like to do a tvs 2650 blower/ bigger injectors/ 1 7/8 headers/ true dual all 3in stainless and some e85. but i really dont see it happening.
You really can't go wrong with a product where the support for it is described like this "RUSH-RUSH Help Center replaced former Magnum Tech Support"
It appears to not be a tuner, but rather just intercepts various sensors to trick the ecu into putting more fuel into the engine.
Just based off that one web page, it's not a product I would plug into my very expensive truck, even if they paid me to do it.
sure
the BBB gives them a F
with multiple complaints
sky google address is a shipping yard
nothing can go wrong...just send you money
It seems that Whipple has cracked the ECU.
https://www.gm-trucks.com/forums/topic/262716-l8t-whipple-for-2020-2022-2500hd/
https://gmauthority.com/blog/2023/03/whipple-will-soon-launch-a-gm-6-6l-l8t-v8-supercharger-kit/
"The kit includes an HP Tuners RDT flash tool to reprogram the computer, as well as a VCM scanner for data logging and tire / axle adjustment."
Edited by Dr1ft3r
This just out recently. Good news for all:
2020-2023 GM Silverado/Sierra 2500/3500 Truck 6.6L L8T Gas tuning has arrived! DiabloSport has combined their industry exclusive Locksmith device with the required ECM harness, and developed tunes specific to the L8T 6.6L Gas applications. The provided preloaded/preset tunes have shown gains of 28 RWHP and 50 RWTQ over stock, on good 93 octane gas! These are huge gains, that you'll feel when you stomp the go pedal! You can also adjust throttle response, tire size, speed limiter and more!
For those that want numbers thats 429 HP and 514 RWTQ!!! on 93 octane
Just curious would this apply to 2024 Chevrolet 2500 HD 6.6 engines ? Also what would change just using regular fuel ?
93 octane is at least 75 cents more per gallon anywhere I have been.
Part of the beauty of the L8T is that it runs on 87 regular.
Not to mention the issue with warranty if GM finds you cracked into the ECM (and they will no matter who says otherwise)
But thats just me and I am old and dont like drama.
No.  2024's use the GM Global B platform so new ECM and encryption.  2020-2023 are GM Global A.
HP has access for the 1500s 2022.5+current which are also Global B, so I'd imagine they will announce support for 2024+ HD in the near future if they haven't already, so HP Tuners would be the only path I know of so far.
Edited by newdude
I did the program thing all the way to my last new truck. I like to feel I had some control. Eliminating top speed governors, backing off the shift nanny, raising shift points and the premium tune. I didn’t pay for gas so let her rip. That sometimes was the minimum but could be done the first weekend along with exhaust. I drove lots of miles so it helped with boredom. My avalanche I’ve done nothing. Not even exhaust it has a little sound. I only average 18 miles a day with it. The exhaust could still happen. If the engine quits, look out. A 400$ hand held tuner, probably not. That’s a first.
Thank you NewDude !
Karnut Thank you for the reply !   I'm not sure I understand your last sentence could you explain .
Thanks
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
