Nothing yet.
Expect it to cost a ton of money if something does come on the market. It already costs a minimum of $1,900 just to tune a 2019+ half ton truck.
Most you can do right now seems to be the pedal monster for improved throttle response. Not sure if that works on the 6.6 gas trucks yet.
Edited by CamGTP
It will be interesting to see what kind of hp and torque numbers they can gain on this engine with premium gas
8 hours ago, CamGTP said:
Nothing yet.
Only thing I can surmise is there just isn't the market.
Reputable Tuner with 5 tunes for the new 7.3 WITH 10 speed is under $650
That's a brand new engine and transmission that several companies have figured out how to tune for well under $1,000.
GM has a new engine but very familiar transmission and no one has figured out a tuner?
Again I think it's they don't believe profit to do it is there.
It's my understanding that it's so expensive now (vs getting older trucks tuned) because the ECM is encrypted, and not many people have figured out how to get around the encryption, so prices are high for it.
The companies that made tunes that mattered have stopped, the government moved in on them and they have stopped.  Now you'll find things that do little things like throttle response or air intake and exhaust, however the factory systems are monitoring this and make adjustments to offset the benefits.  No easy programming left.
The issue as already stated is encryption.  There are plenty of tuners out there, just none that have the know how and/or capital to crack G.M.'s encryption. They're may be some truth to cost analysis isn't conductive to the investment needed.
  • 1 month later...
Its encryption and honestly let's be real here... who buys these trucks mostly?  Fleets.  There is no care for custom tuning with fleet operators.  It's like the 6 liter with the e78 ecm since 2011.  Yes you can half ass tune them but it's only half ass.  Ask anyone who tries to cam one or run a supercharger etc... Guys that grab L96s for a swap like to toss the e78 in the trash and go for an e38 because it has full tuning support.
I can see guys that swap this 6.6 just using the e92 that the 2014 through 2018 half tons, Camaros and Corvettes use.
You will likely be waiting a very long time for any real tuning for these trucks.  The Ford is not really encrypted, Ford themsleves seem to be driving customization to a degree, and honestly there is a lot more fanfare for the 7.3 anyway.. hence they have tuning.  Ford pushing the 7.3 out as a crate engine with ecm and harness for swap purposes really helps here lol.
Edited by SierraHD17
The Diesel guys are purchasing unlocked ecm's to tune their engines for emission removal. Its about 2,500.00 plus new exhaust on the Diesels. I don't think there would be enough benefit for a gas truck. Diesels gain around 100 HP.
This engine is a good candidate for the hot rod crowd. This is where the tuning if it ever comes will be driven from.
Edited by L8T
I find myself leaning more towards the Chevy but man the stuff that is happening with the 7.3 is just impressive!
What's funny is doing some googling you see before either engine was released most places were speculating the GM 6.6 would be the engine seeing all the aftermarket support. I assume that's because of the LS DNA, but that's clearly not the case!
It's just because the GM ECM's are now encrypted, Ford's are not.  L8T 6.6L components like that beautiful forged crank are already in the performance parts catalog and I expect 6.6L crate engines will be available soon.  That doesn't mean much to the 6.6L silverado/Sierra owners that wants to do something to his truck though.
Which is why they need to either bring back 4.10s, give it a competitive transmission, or release the rumored big block.
Or best of all, all 3 available in a truck!
I’d be happy with just a couple or three more gears. Big block and low gears for the dually’s maybe. Maybe as an option for the 1 ton srw’s also.
    • 3.41 Kroger’s in Montgomery TX
    • I really wanted to go to the Fox 2.5's But they were like ~$1,500 vs ~$425 for the Bilsteins. And my research on FOX shocks was that they do not have a great reputation for longevity. I am sure they the FOX's are fantastic, but I know from experience the Bilsteins are rock solid for at least 150k miles.
    • Conditions for Meeting a Cold Start   The ignition voltage is between 10 and 15 V. The barometric pressure (BARO) is more than 75 kPa. The engine coolant temperature (ECT) at start-up is less than 42°C (108°F). The intake air temperature (IAT) is between 2–32°C (36–90°F). The engine is OFF for greater than 6 hours or the following conditions must be met: The start-up IAT minus start-up ECT are within 12°C (22°F). The start-up ECT minus start-up IAT are within 50°C (90°F). Fuel level is between 25 and 75 %.   Circuit/System Verification Verify that all I/M System Status indicators report YES, and that no I/M Test DTCs are present.If any I/M Test DTCs are set Refer to Diagnostic Trouble Code (DTC) List - Vehicle. If no I/M Test DTCs are set All OK. Inspection/Maintenance (I/M) System Set Procedure   Warning: Refer to Road Test Warning. Note: Do NOT touch the accelerator pedal until told to do so. A change in TP Sensor angle or an increase in engine speed may invalidate this portion of the test.   Note: An I/M Test DTC will not be stored or erased from the ECU except at the end of trip processing, which occurs 5 s after ignition OFF.   Ensure that the vehicle meets the conditions for a cold start listed above. If the EVAP I/M System Status indicator displays NO, perform the EVAP Service bay test if applicable. Turn OFF all of the accessories; HVAC system, other electrical loads, including aftermarket/add-on equipment, etc., and open the hood.   Set the vehicle parking brake and ensure the vehicle is in park for automatic transmission or neutral for manual transmission.   Start and idle the engine for 2 min.   Close the hood, release the parking brake and Accelerate at part throttle to 72–80 km/h (45–50 mph) with this speed maintained until the engine reaches operating temperature, 8–10 min.   Continue operation under these conditions for an additional 6 min.   Accelerate at part throttle to 90 km/h (55 mph) with this speed maintained for 2 min.   Release the accelerator pedal for at least 10 s. This will allow the vehicle to enter the decel fuel cut off.   Safely stop the vehicle, with the engine in drive for automatic or neutral with the clutch pedal depressed and parking brake applied for manual. Allow the vehicle to idle for 2 min.   Shift the vehicle to park for automatic and neutral for manual. Turn OFF the ignition and exit the vehicle. Do NOT disturb the vehicle for 45 min.   Observe the Inspection/Maintenance (I/M) System Status with a scan tool. All of the I/M System Status indicators should display YES.   If the EVAP I/M System Status indicator displays NO, turn OFF the ignition, ensure that the vehicle meets the conditions for a cold start, and repeat steps 6-11 three more times, or until the EVAP I/M System Status indicator transitions to YES. If the indicator continues to display NO, refer to the Inspection/Maintenance (I/M) System DTC Table to identify the DTCs that did not run.   If any of the I/M System Status indicators display NO, refer to the Inspection/Maintenance (I/M) System DTC Table for the indicator which did not display YES. The I/M System DTC Table identifies the DTCs associated with each I/M System Status Indicator.   Observe the I/M Test DTC information with a scan tool. Verify there are no I/M Test DTCs present. If an I/M Test DTC is set, diagnose the DTC using the Diagnostic Trouble Code (DTC) List - Vehicle and refer to Inspection/Maintenance System Check.   Observe the engine DTC information with a scan tool. Verify no DTCs are present. If a DTC is set, diagnose using the Diagnostic Trouble Code (DTC) List - Vehicle. After repairs, perform the Inspection/Maintenance Complete System Set Procedure to verify no further DTCs are set.       Looks like one procedure to me.  Repeated as necessary.
    • My 2020 AT4 6.2 has had the valve spring issue addressed at ~200 miles, front cover/pump replaced at 18k, water pump at 34k and idler pully at 65k.  I would agree with ditching by 100k unless you elect to go with upgraded hardware...say built 10l80 and an lt4 or l8p swap.
