Hey folks
Upgraded from a 1500 and absolutely love the truck, but holy hell the turn radius is a huge difference! Getting through tight crowded parking lots has me questioning wether to ever attempt to get through a fast food drive through lol
Is there anything that I can do to improve the turning radius? Or does it just take getting used to?
It is what it is. No you can't change it!
On 11/24/2020 at 4:30 PM, Arkangel said:
Hey folks
There is a burger king by me that has a curb around the drive through and my wife loves oreo milkshakes so we go there every once and a while.  I have learned that I have to just drive straight into the curb and I don't turn until I'm up on top.  You will eventually learn how to deal with tight spaces with the gigantic trucks, it just takes a little while.
LOL I drive on the curbs to get into many places, it's that or like a 3-5 point turn - the tall side wall tires protect the rim/mag from damage - so far
Makes sense that the longer the truck the worse it turns - the ancient 2002 +-  ? with 4 wheel steer were very popular for that reason +-
i too came from a 1500....a dbl cab RST to crew cab 2500 std box....the box is 3 or 4 inches longer and cab probably 10 inches or more......have an el pollo loco (only fast food joint close by) that my 1500 barely made and wont attempt it with 2500....but yeah you learn what you can and cant do.....flipping u turns is another one....even on bigger streets i cant make it from left turn lane i have to use fast lane if no traffic.....i alter my routes a bit to certain places but humans are incredible at adapting to various things
it is what it is.....and while a con in one area a total plus in another so.....steering isnt same either, little more vague and cpl other things as well.....its not just 1500 with stiffer springs its whole different truck altogether......feel nothing alike in any area except the interior which is exactly the same
have no idea.....my first GM truck besides 1500 i had few months
I don't have turning data on the early 2000's (the GMT 800 generation chassis).
The 1500 frame changed for start of GMT900 program (2006ish) but the HD frame did not.
However, in 2011, the HD frame and chassis was completely updated (even though the body/interior was the same between 10 and 11).
The frame/chassis stayed the same from 11 thru 19, even though the body changed half way through that period.
The 2020 HD is all new.
Everything, except the engine -- and it has some external changes -- oil cooler and the huge updates to the cooling system.
2020HD crew standard turning circle is 52.7ft, wheelbase 158.9" (OAL  250.1)
2019HD crew standard turning circle is 51.5ft, wheelbase  153.7: (OAL 239.5)
2020 1500 crew standard (on 20" or 22") 50.2ft. 156.98"   (OAL 241.25)
2020 1500 crew short (on 20" or 22") 46.9ft, 147.43" (OAL 231.7")
1500 turning circles on smaller wheel diameters are about a half a foot less.
2020s have larger turn circles than 2019 and before.  Wheelbase is longer and steering max steer angle is the same.  Only way to get to turn tighter are: shorter wheelbase, make tires turn further, or 4 wheel steer.
#iworkforGM
yes quite a few places i have to avoid in so cal but i dont mind really.......park and go inside isnt really that big a deal and usually its faster here .....our drive thrus are packed especially IN n OUT
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
