1 hour ago, CamGTP said:
If paint overspray on metal filter body is a concern to you, I don't even want to know what other little things in your life you complain about.
Get a grip people.
If the overspray was on the other end, it’d be a Fram! ?
while you are at it it... make sure that you have a magnetic drain plug. you will then be privy to any issues with hardening of cams and rollers... before you find out acoustically...
see the little pile of iron that the PF 63E didn't get
Edited by PPK
I have ran both the Mobil 1 M1-212A and the Fram Ultra XG10575 on my 14 Sierra 5.3. Both are well made and would recommend.
17 hours ago, newdude said:
ACDelco UPF-63R, the Ultraguard Gold.  These are built like the good AC Delco regular filters used to be, Non E-Core construction.  They are used in the gen III High Feature 3.6 V6 engines and can be used on the Gen 5 V6/V8 engines.
ACDelco® UPF63R - Specialty™ Ultraguard Gold Engine Oil Filter
I use the same UPF63R here
Decided to have a look inside both the 63E and 63R...R has thicker can and tighter media and metal end caps. E has the core and ultrasonic end cap installed and can was thinner.Visually the R wins this contest but the E definitely matches the super tech filters inside and out.
What is it you expect your filter to do?
Filter?
While cutting open filters is fun and informative it can't tell you how well it filters.
UOA's that include cleanliness testing can.
Read the filtration post.
At the end of the day, it really doesn't matter what you use. Engines last 200-300k miles and failures/rebuilds/etc are never due to what type of filters are used in most of vehicles on the road. On top of that, most people on this forum won't even keep their new T1 past 100k miles. So again, it really doesn't matter. Use what you want. Internet search all you want. Watch all the youtube videos. Go down that hole. I've been there too. End the end, it really doesn't matter. I'm sure there will be one person who claims an oil filter blew up or their engine or their cousin's engine blew up and they blamed the filter, etc. I'm more worried about hose crimps failing and dumping oil all over the road or failed valve springs or the window leaking or some other more likely failure on these vehicles. Pick a filter, be happy. Pick a different one, still be happy. :) ymmv.
Edited by UGADawgs
At the end of the day, it really doesn't matter what you use. Engines last 200-300k miles and failures/rebuilds/etc are never due to what type of filters are used in most of vehicles on the road. On top of that, most people on this forum won't even keep their new T1 past 100k miles. So again, it really doesn't matter. Use what you want. Internet search all you want. Watch all the youtube videos. Go down that hole. I've been there too. End the end, it really doesn't matter. I'm sure there will be one person who claims an oil filter blew up or their engine or their cousin's engine blew up and they blamed the filter, etc. I'm more worried about hose crimps failing and dumping oil all over the road or failed valve springs or the window leaking or some other more likely failure on these vehicles. Pick a filter, be happy. Pick a different one, still be happy. [emoji4] ymmv.
Totally agreed. Just had my oil cooler lines replaced under warranty. 31k miles and one was leaking bad. My dealership stocks them because they change them regularly. Gm needs to change the design. Stupid
I have to agree with this for the most part.
I currently run NAPA Platinum in all my vehicles (made by WIX I think)
You can usually pick them up at a good price when they are on sale ($7.50 or less)...otherwise they are approx $12
On 12/7/2020 at 2:08 PM, Kclyatt said:
I am amazed that the 6.2l filter from AC Delco (PF63E) is exactly identical inside and out to the Walmart cheap Super Tech ST 10575 (Bob is the oil guy).  Also there are 50/50 opinions on the quality of the E core filters and with so many options out there I am curious what is everyone using for their ride?
I currently am thinking going with the Purolator Boss PBL22500 based on cut open filter pics, specs and reviews. I want best filter for the engine/longevity especially with DFM and the AC Delco seems ok but what do others think?
Have you verified the relief valve pressures?
Then by a remote kit and loop the inlet back to the outlet and stop buying filters period.
What can a sentence mean that uses Never and Most together. Which is it, Never or Most?
As written this statement means that for motors that NEVER fail the filter is NEVER the problem.
Ya think?
https://www.machinerylubrication.com/Read/28436/story-automotive-filters-engines
Nest to last paragraph reads:
The cost of a synthetic depth filter is almost double of that of the cellulose filter. It may only cost a few extra dollars in the beginning, but there have been multiple case studies on the effect of the cleanliness of the oil affecting component life to the tune of three to four times the life extension of the engine.
Edited by Grumpy Bear
44 minutes ago, Steve-2019 said:
I always like to check what the micron rating is for the filter media. (of course that can be subjective)
From Practical Lubrication & Filtration (Filtration #4)
Filter efficiency is easier to get if you are looking for it correctly. The box isn’t that. You are looking for ISO 4548-12 results. Thing is these test results can have any point of reference that marketing wishes and they wish to look stellar. Usually reference, however is 20 micron. So let’s start with an easy one to get.
This is a MEASUREMENT and as such not subjective.
Any decent filter will give you this information either on the box on on their website. You need to know both pieces of information however. ISO 4548-12 Beta number AND assurance of the 20 micron REFERENCNE point.
Mobil 1 for example states the efficiency as a percentage and in really fine print on the the box notes it is a 30 micron reference. Totally confusing if you don't know how to convert percentages to a Beta value and useless in comparing to other 20 micron reference filters.
Arm yourself with the objective truth. Read the link I provided earlier on this site
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
    • Welcome to the Forum! Always post the code definitions along with the codes. there are over 18000 possible codes, no one remembers them all and most will skip over your post rather than look them up
