I have a 19, all recalls done and just ticked 10k at 18 months and while not all the time and obviously more prominent in wet weather I've noticed my breaks are pretty squeaky on the first few slow breaks. Never had this on any of my silverados before. And normally I wouldn't care if it was a faint squeak, but it's a loud "change your pads" kind of squeak and even my dad commented on it.
Just me?
I've noticed the same on my 2020 AT4 recently, I've got about 18k miles on it.
Mine does it only when backing out of the driveway and applying brakes in the morning...
Never had it squeak while applying brakes in the forward motion.
My brakes squeak occasionally, but I only notice it when it is wet...
Same here.
Also for me. 2019 AT4 with 40k.
Same 29k miles. Only for the first or second stop and then it goes away. Probably just a side effect of the pad, more then likely will be there until you go aftermarket.
On 12/22/2020 at 9:15 AM, blckblt said:
Same here.  First thing/use.  Especially when backing out of the garage.
now that you mention it, mine is only in reverse too. odd.
seems weird that in 100 years of making trucks that this would be a new issue...
    ncleg
    ncleg
  • Who's Online   2 Members, 0 Anonymous, 1,467 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
