34 minutes ago, KARNUT said:
How many jobs got lost in the last two weeks? It’s not rocket science.
Don't worry. All the welders can get jobs making solar panels. Easy peasy.
I really am down with the moves to EV. I think the market is just finally getting it right in the past few years. But...yeah... there are a LOT of problems to solve in 15 years if GM really thinks every person in the US can just migrate to EV on a new vehicle.
I would be up for electric. Some of them go like hell. Make them attractive to buy no problem. Being forced into it never works out too well.
[emoji2359]
What happens when water that leaks through the back window comes into contact with electricity? Yep, GM has a lot to fix before they can go full electric.
  • Haha 1
They are dreaming if they think, in 14 years, everything will be electric.
Where is all the infrastructure?
Not to mention the crap they need to mine to make the batteries. Good luck with that one greenies .
There is too many things that need to happen to make it work.
The one thing that I believe will never happen is a long range electric truck . Hell the battery alone would cost $50,000 .
And what about the old batteries? Landfill? C'mon man.
TOTAL JOKE.
Sent from my Pixel 3 using Tapatalk
TOTAL JOKE.
13 hours ago, Black02Silverado said:
It will be interesting to see how much more mining is done for the raw materials for the batteries that will be needed to supply the millions of vehicles that will be produced.  They think drilling for oil  is bad, look at the damage caused by mining.  Not to mention the oil burning vehicles doing the mining process. So is it really a better deal?
no mining neccessary if GM follows honda and Toyota's lead and focus on hydrogen fuel cell and hydradrate sponge technology instead of wasting time and money on battery tech
TOTAL JOKE.
Hydrogen is the infrastructure to replace petroleum and support electric vehicles
Iirc, it would also make Iceland the world's next superpower. I recall reading many years ago that 0.33% of the world's hydrogen is enough to completely sustain everybody and everything for over 300 years. The real question is, with GM and Ford working with BMW on hydrogen fuel cell technology, even putting test mules in fleets like small busses with supercharged V10 engines, "What happened that caused them to turn so heavily to EVs?"
many things stopped its momentum, i think politics is #1 reason.  #2 is the storage system, its kinda a millitary secrect and kept out of the hands of the commercial sector,  so it has to be stored at high pressures and lacks range.  Hydrogen is a bit of a waste in combustion engines as a sole fuel source but if you can produce lots of it cheap, than who cares it works and has no emmisions.
if you add a hydrocarbon fuel and hydrogen mix then this reallly improves the use of both fuels and increases MPG and improves emmissions.
the most effieicnt use of HYdrogen with a Hydrate storage system and a fuelcell is probably the direction EV's are going,  since your not hampered with Batteries and battery managment issues which is the problem with all Lithium batteries.
Edited by flyingfool
GM is dropping out of Fuel cell!
But you know what, so what if the world goes electric. These left wing environment people will be complaining about some other Boogy Man. That is just the way they are.
On 1/28/2021 at 5:36 PM, the wanderer said:
Just to be clear, that's for "light duty". 2500+ are not getting neutered.
1500-3500 are light duty btw. :)
I hope this doesn’t give GM an excuse to let the current powertrains rot on the vine. I need more power. C’mon, make one last new line of kickass V8s...
once we all go full electric and there is no particulate from smog in the atmosphere to block the sun, the Green lefties will complain the UV rays are making life even hotter and more unbearable.
    • I just brought home a 2020 GMC 1500 Denali.  She has 53K miles on her and I want to change out the fluids over the next few weeks.  I see the diff covers don't have drain plugs.  Any suggestions where I can pick up front and rear diff covers with drain plugs?   Thanks,   Bob
    • Well, the dealership got the compressor and installed it. Air at the vents seems nice and cold as it should be. The service manager said the repair has a two year warranty and unlimited mileage. Hopefully I don't have to use it. The dealership i went to was one where I bought my 2014 half ton silverado. In 10 years and 168k miles on the truck anything I needed done and two small recalls they were always very good to me. Not a huge dealer either. I think they treat people well because they want you to come back. I have dealt with a different dealer that was too big to care about an individual. Just my two cents.
    • Hi All, I operate my 2021 3500 SLT most of the time with the tailgate off and in a crate because I have a slide-in camper. However, at least once a year, I take the camper off and put the tailgate back on. Recently I installed the tailgate, but had a hard time getting the connector bail to swing to the fully latched position. The connector seems to fully seat, and everything works, but the bail doesn’t swing to fully latched position.  It swings almost there but stops and I am afraid to push it any harder.    Does anyone have any advice on cleaning or lubrication or anything else I should be doing?  i know how to properly operate the connector. During the time the tailgate and connector are off, i have a double plastic bag over the truck connector secured with rubber bands to keep it clean, but it still had some dust in it this time when I blew it out with compressed air. I didn’t want to spray it with anything other than air without doing some research. Thanks.
    • There are a lot of spammer's that do that, quote something and add some commentary to make it seem legit, but modify the quoted text a bunch making sure when posted it's long enough to be "click to expand", and either immediately insert a spam link, or come back after some time and edit it to add the spam link.
    • Hello @jaszr2 Do you have a link for the item? I put a replacement bumper on my truck and consequently had to relocate the shutters. I studied on them a while, and figured if you left a couple key blades, you could get most of the airflow with probably no throwing codes.
