I just changed the oil for the 3rd time on my 2020 trail boss. 14k miles. I didn’t pay attention to the amount drained on the first 2, but noticed I drained exactly 7 quarts on this go around....
I let it drain until it quit dripping, there’s no way 1 full quart stayed in the engine...
im going to change it again at 20,000 and if it’s still low, may go ahead and trade this thing in. I love it and it’s the nicest truck I’ve owned but I got it As a long-term vehicle but if my $54,000 truck is going to be burning oil from the get go I don’t think it will be something I want to deal with over the next 10 years
Did you think roughly 1/2 quart or more still in the oil filter and the other coated to the engine? You are not going to get the same amount of oil out as you put in from the start not going to happen. Your not burning oil.
Some motors not only GM will burn 2 quarts of oil in-between oil changes is considered acceptable.
I agree with the above statement. If you love the truck so much, it is under warranty so go speak to a dealership about your concerns.  A certified technician will also speak to you. But he will probably say exactly what @Silverado4x4 stated.
A much more accurate way to check how much oil you used would be to check the dipstick with cold engine on level ground before you drained it.
Wait this makes no sense so your baseing it on how much you seen drain ?? You didn't even check the dipstick?? To check it correctly after running make sure it is on a flat surface wait 10 to 15 minutes and the check the oil level. Hope this helps
I totally agree check with the dip stick after a total oil change  check every 500 miles to see if you are consuming it. You are not going to get all the oil out when doing an oil change especially if you do not heat up the oil (running the engine at least for a 1/2 hr). I have a 19 TB custom TB 5.3 with 20,000 miles purchased new broke in hard been doing my own oil changes PP 5/30  AC Delco every 5,000 miles I go from oil change to oil change dip stick level right at full mark every time no oil consumption. Takes exactly 8 qrts to bring it to full mark. I also agree check on level ground I have a slight incline on my driveway it shows a little low on dipstick then I park my truck on a level surface dipstick reads exactly full. My TB custom is very sensitive to checking oil on a level surface keep that in mind.
Edited by K455
5.3 here and
5.3 here and has not used a drop of oil......
So, you never check the dipstick from oil change to oil change?????
Never heard of anyone trying to measure the oil you drained to see how much was used.......to many variables and a flawed approach.
Check the dipstick (by owners manual and on level ground) right after oil change and every 1K miles and see what happens before you go ahead and jump off a bridge with your wild assumptions.
Edited by BigMick2020
Just trade me for my LT,  Doesn't burn a drop  :D
On 2/13/2021 at 10:34 PM, Colossus said:
This is a somewhat misleading article if read by someone with little to no knowledge of the workings of rings. Ring tension just makes the introduction. Gas pressure does the bull work of sealing. About half way down they get to the truth of it......
Quote {Degraded engine oil is more susceptible to oxidation, which can cause engine oil thickening. When the engine oil thickens due to the oxidation, it provides even more resistance against the low tension piston rings. As oxidation progresses, sludge formation can occur.
So, not only do you have sludgy, contaminated oil lubricating the rings; but also, because the low tension piston rings have such low spring force, they are less capable of pushing back against deposits that may (WILL) form around them. Eventually deposits will impede the rings outward expansion to seal the cylinder wall, which will allow even more fuel and combustion gases to enter the crankcase. Or, vice versa, stuck rings can promote oil consumption and intake deposit formation due to engine oil moving up into the cylinder and into the intake.} End quote. (WILL) is mine.
This entire article is a great argument for shorter OCI's and use of lubricants with less tendency to oxidize.
This 'ring sticking' thing is something that happens no matter what the ring tension is...it just takes longer for them to fail and sticking is the ENTIRE failure mode. Bluto can do more pullups than Olive Oly.
Migration into the combustion chamber is not a failure...it's the design. Just like a hint of oil getting past the valve guide is. But this consumption is measured in teaspoons per tens of thousands of miles not quarts in a few thousand. This usage is well modeled and insignificant. Migration from ring sticking is not part of the design.
Motor cleaners like ERP and the GM upper cylinder ring soaking fluids, that do work by the way, are methods for fixing the issues of a poor oil maintenance program. Not an addition to a good one.  A great program would never require them.
Time for the disclaimer:
IMHO
She's a burner got another GM burner.....
  • Haha 1
Filter holds near a pint and near that again when you pull the filter from the galley above it. Use the dip stick and count it all.
    Tbhats2130
    Tbhats2130
  • Who's Online   5 Members, 0 Anonymous, 1,109 Guests (See full list)
    • Google converting 98 4.3 spider injection to carburetor if all else fails.
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
    • I have four that read by the dash 8 to 10% better than miles/pump calculations and I have one that is spot on.
