I just changed the oil for the 3rd time on my 2020 trail boss. 14k miles. I didn’t pay attention to the amount drained on the first 2, but noticed I drained exactly 7 quarts on this go around....
I let it drain until it quit dripping, there’s no way 1 full quart stayed in the engine...
im going to change it again at 20,000 and if it’s still low, may go ahead and trade this thing in. I love it and it’s the nicest truck I’ve owned but I got it As a long-term vehicle but if my $54,000 truck is going to be burning oil from the get go I don’t think it will be something I want to deal with over the next 10 years
Did you think roughly 1/2 quart or more still in the oil filter and the other coated to the engine? You are not going to get the same amount of oil out as you put in from the start not going to happen. Your not burning oil.
Some motors not only GM will burn 2 quarts of oil in-between oil changes is considered acceptable.
I agree with the above statement. If you love the truck so much, it is under warranty so go speak to a dealership about your concerns.  A certified technician will also speak to you. But he will probably say exactly what @Silverado4x4 stated.
A much more accurate way to check how much oil you used would be to check the dipstick with cold engine on level ground before you drained it.
  • Thanks 1
Wait this makes no sense so your baseing it on how much you seen drain ?? You didn't even check the dipstick?? To check it correctly after running make sure it is on a flat surface wait 10 to 15 minutes and the check the oil level. Hope this helps
I totally agree check with the dip stick after a total oil change  check every 500 miles to see if you are consuming it. You are not going to get all the oil out when doing an oil change especially if you do not heat up the oil (running the engine at least for a 1/2 hr). I have a 19 TB custom TB 5.3 with 20,000 miles purchased new broke in hard been doing my own oil changes PP 5/30  AC Delco every 5,000 miles I go from oil change to oil change dip stick level right at full mark every time no oil consumption. Takes exactly 8 qrts to bring it to full mark. I also agree check on level ground I have a slight incline on my driveway it shows a little low on dipstick then I park my truck on a level surface dipstick reads exactly full. My TB custom is very sensitive to checking oil on a level surface keep that in mind.
Edited by K455
5.3 here and
5.3 here and has not used a drop of oil......
So, you never check the dipstick from oil change to oil change?????
Never heard of anyone trying to measure the oil you drained to see how much was used.......to many variables and a flawed approach.
Check the dipstick (by owners manual and on level ground) right after oil change and every 1K miles and see what happens before you go ahead and jump off a bridge with your wild assumptions.
Edited by BigMick2020
Just trade me for my LT,  Doesn't burn a drop  :D
On 2/13/2021 at 10:34 PM, Colossus said:
This is a somewhat misleading article if read by someone with little to no knowledge of the workings of rings. Ring tension just makes the introduction. Gas pressure does the bull work of sealing. About half way down they get to the truth of it......
Quote {Degraded engine oil is more susceptible to oxidation, which can cause engine oil thickening. When the engine oil thickens due to the oxidation, it provides even more resistance against the low tension piston rings. As oxidation progresses, sludge formation can occur.
So, not only do you have sludgy, contaminated oil lubricating the rings; but also, because the low tension piston rings have such low spring force, they are less capable of pushing back against deposits that may (WILL) form around them. Eventually deposits will impede the rings outward expansion to seal the cylinder wall, which will allow even more fuel and combustion gases to enter the crankcase. Or, vice versa, stuck rings can promote oil consumption and intake deposit formation due to engine oil moving up into the cylinder and into the intake.} End quote. (WILL) is mine.
This entire article is a great argument for shorter OCI's and use of lubricants with less tendency to oxidize.
This 'ring sticking' thing is something that happens no matter what the ring tension is...it just takes longer for them to fail and sticking is the ENTIRE failure mode. Bluto can do more pullups than Olive Oly.
Migration into the combustion chamber is not a failure...it's the design. Just like a hint of oil getting past the valve guide is. But this consumption is measured in teaspoons per tens of thousands of miles not quarts in a few thousand. This usage is well modeled and insignificant. Migration from ring sticking is not part of the design.
Motor cleaners like ERP and the GM upper cylinder ring soaking fluids, that do work by the way, are methods for fixing the issues of a poor oil maintenance program. Not an addition to a good one.  A great program would never require them.
Time for the disclaimer:
IMHO
She's a burner got another GM burner.....
  • Haha 1
Filter holds near a pint and near that again when you pull the filter from the galley above it. Use the dip stick and count it all.
    MASONV88888888
    MASONV88888888
  • Who's Online   5 Members, 0 Anonymous, 1,664 Guests (See full list)
    • I’m definitely interested to hear the end result here.
    • My 2025 Silverado 1500 had to receive a brand-new engine (long block) under warranty last month at only around 16,500 miles. Before the replacement, the truck repeatedly displayed "Engine Oil Level Low" warnings, even though the Oil Life Monitor still showed around 50% remaining after about 6,000 miles since my last oil change. After seeing the warning several times, I checked the dipstick with the engine cold, and the oil level was completely normal. The next day, the message escalated to "Add Engine Oil." At first, I assumed it was just a faulty oil level sensor, so I brought the truck to the dealership. After inspecting the engine, they found internal cylinder wall scoring and ultimately replaced the entire long block under warranty. Before this happened, I was planning to install a 4-inch lift and suspension upgrade on my truck. After needing a new engine at just 16,500 miles, I honestly don't see the point anymore. I also contacted GM to ask whether my vehicle qualified for a buyback, but I was informed that it does not at this time. Anyway, this experience has left me with serious concerns about the long-term reliability of this engine. I sincerely hope NHTSA expands the current investigation or recall to include 2025 model and performs a thorough inspection of affected vehicles. My biggest concern is that these engines may fail shortly after the powertrain warranty expires. If GM truly stands behind this engine, then at the very least, please consider extending the powertrain warranty to 10 years for affected owners. That would go a long way toward restoring customer confidence.
    • Without exception but then I'm the odd duck, right? I know what goes into that test, how it is calculated and thus how to beat it. But EPA values are often not beaten by the general public and the government has in past years adjusted the means and methods to come to those values to more closely approximate "Joe Average".    The only real trick to beating that EPA average is don't drive like "Joe Average".    It's the same method you used to profit from "Economic Migration" and in doing so beat the 'stats'. But you, like me, are not "Joe Average".     The thing you don't seem to grasp is this "Purchasing Power Index" isn't forward looking. It doesn't predict what it going to be but looks backward and states what it was. They are not telling us what the THINK, they are telling us what they MEASURED. Example:    Wife says "I'm going to lose 40 pounds by Christmas". May she does, maybe she doesn't but the doctors office who weighed her when she made that statement and again at Christmas only REPORTS what the RESULT was. You and I can banter about what was possible and what aunt Tilly did till the cows come home but the result is the result. Arguing otherwise is.....irrational. That's all I'm saying. This isn't about:      What you are calling a 'Statistic' is a RESULT not a CALCUATION and as a result the RULE. Like gravity as a rule, it can not be broken.
    • Just wanted to say thank you for posting this. Years later, your thread is still helping Silverado owners.   I bought my 2025 Silverado 1500 in January 2025, and I've had what feels like the exact same rattle since day one. After reading your findings, I believe my truck has the same issue with the cable carrier contacting the rear sliding window. To be honest, I had pretty much given up on pursuing the issue. It wasn't until I recently drove another brand's pickup that I realized just how quiet their cabin was—and how noisy mine has been all along. On my truck, the rattle happens on almost any paved road, gets even worse on rougher pavement, and I can even hear it during braking and acceleration.   I actually referenced your thread when submitting my case to GM, hoping they'll recognize this as a recurring issue instead of treating it as an isolated incident. The reason I reached out to GM first is because my dealership told me they would need to keep the truck for at least two days just to diagnose the problem. I was concerned that even after two days, they still might not be able to identify the source of the rattle before giving the truck back to me. I had also asked a few dealerships about this issue during previous service visits, but none of them seemed to know what was causing it or had a solution. That's why I decided to contact GM directly first, hoping they might already have an official repair procedure or guidance for this issue.   I also hope GM eventually comes up with an official fix for this problem. I have a feeling there are many Silverado owners experiencing the same rattle, but most either choose to live with it or simply don't know what the cause is.   Really appreciate you taking the time to document your diagnosis. Your post is still making a difference years later.
    • I have 2 choices.
